Author Topic: [GB] IV Ashes | In Production Queue  (Read 14587 times)
Offline Tyson
« on: Fri, 01 July 2022, 15:59:51 »
Time to link the flame once more, Ashes returns in PBT! IV Ashes, a revamped take on GMK Ashes in collaboration with IV Works!
Follow these links to join the groupbuy!
July 1st, 2022 - July 31st, 2022
NA:IV Works
CA: DeskHero
EU: MyKeyboard.eu
UK: Proto[Typist]
CN: zFrontier CN
Asia: zFrontier
SEA: iLumKB
JP: BaseKeys
AU: SwitchKeys
Ship date: October/November 2022
Pricing:
__________________________________________
Artisan collabs:
DreadKeys: https://dreadkeys.com/
Pi caps: https://www.instagram.com/pizzza013/
SodieCaps: https://www.instagram.com/sodiecaps/
Finch Caps: https://www.instagram.com/finchcaps/
WinKeys: https://winkeebs.com/
Zouabee: https://www.instagram.com/zouabee/
More to come!
Cable collab:
KKonaCables
6ft Lemo-esque USB-A to USB-C Cable colormatched to Ashes
Full Keyset
Deskpads
Ariandel
Darkroot
Darkmoon Linear Switches
Metal Artisans
Bonfire
Darkfire
Sample Photos
Artisan caps designed by Pi Caps
Renders
AV4 by IV Works
Frog TKL by GeonWorks
Check for Updates on IV Works Discord & my Discord
Thanks
Thank you IV for the amazing renders and all the support on this project being the main vendor!
Thank you for the supporting GMK Ashes! I'm glad you guys love the set as much as I do!
Thank you to my Discord for all the love and support!
If you want to support this Group Buy, please consider adding the following to your Signature:
Code: [Select]
[url=https://geekhack.org/index.php?topic=117667.0][img]https://i.imgur.com/t8cnJQH.jpg[/img][/url]
« Last Edit: Thu, 29 September 2022, 13:07:01 by Tyson »
Offline factoryofidols
Re: [GB] IV Ashes | GB LIVE!
« Reply #1 on: Sat, 02 July 2022, 16:39:22 »
I remember the IC had mentioned a cap on sets (to 500 I think), is that still the case or was that changed for the GB?
Offline Tyson
« Reply #2 on: Sat, 02 July 2022, 19:19:07 »
The set has since moved to an unlimited GB. There is no cap :)
« Last Edit: Sat, 02 July 2022, 19:36:10 by Tyson »
Offline AmethystDCVR
« Reply #3 on: Sun, 03 July 2022, 00:51:33 »
Who is the keycap manufacturer?
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #4 on: Tue, 05 July 2022, 12:15:50 »
US vendor's order numbers only.
Other vendors not yet reported.
Edit: clarified switch order numbers
« Last Edit: Mon, 25 July 2022, 16:17:33 by dvorcol »
Offline Tyson
« Reply #5 on: Tue, 05 July 2022, 13:08:56 »
The manu's name has not been disclosed but is a manu that is said to have worked with Cherry before and has never made custom designed keysets for the hobby. This is their first project. I have been working with IV Works for the past year to improve the quality of the caps before running the GB!
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #6 on: Tue, 05 July 2022, 15:15:46 »
Come on ... you can do better than that ... ;)
«How much wood could a woodchuck chuck if a woodchuck could chuck wood?»
Offline tiberria
Re: [GB] IV Ashes | 195 Kits Sold Opening Weekend!
« Reply #7 on: Tue, 05 July 2022, 21:52:48 »
When asking $120 for a keycap set, I think that the manufacturer information being disclosed is a minimum acceptable standard.  We have seen so many issues with new manufacturers over the past couple years that it's hard to trust a group buy that refuses to disclose this information.  Doubly so for a set that is full reverse dye sub given the problems that even major manufacturers like ePBT, Keycreative and Infinikey have had with reverse dye sub quality control and lead times.
Offline Tyson
Re: [GB] IV Ashes | zFrontier added as CN vendor!
« Reply #8 on: Thu, 07 July 2022, 10:49:08 »
Small Update:
I was able to get ahold of zFrontier to get them to run the set in the CN/Asia region! I will make sure to bump the thread again when they get everything going for the set on their sites!
Offline Tyson
Re: [GB] IV Ashes | Over halfway to MOQ!
« Reply #9 on: Mon, 11 July 2022, 18:17:34 »
The group buy is up on zFrontier's site!
Offline dvorcol
« Reply #10 on: Wed, 13 July 2022, 18:21:06 »
Edit: corrected switch order numbers
« Last Edit: Thu, 04 August 2022, 14:11:53 by dvorcol »
Offline dvorcol
« Reply #11 on: Wed, 20 July 2022, 19:49:52 »
« Last Edit: Thu, 04 August 2022, 14:11:20 by dvorcol »
Offline JvMil
« Reply #12 on: Fri, 22 July 2022, 10:53:15 »
What is that Alice-like keyboard in the renders? Is that for sale anywhere? The combo looks amazing!
Offline hvn111
« Reply #13 on: Mon, 25 July 2022, 03:16:35 »
Its IV Ashes - the GB is until the end of July, some links here - http://www.mechgroupbuys.com/keycaps/IV%20Ashes
Offline HungHingDaiLo
  • 無間道
« Reply #14 on: Mon, 25 July 2022, 06:57:05 »
Sample looks great  :thumb:
Nice numbers as well. Grats (& hopefully I can join by the end of the GB), Tyson!
Will there be extras available for those who missed the group buy, btw?
Offline dvorcol
« Reply #15 on: Mon, 25 July 2022, 13:12:12 »
« Last Edit: Thu, 04 August 2022, 14:10:48 by dvorcol »
Offline Tyson
« Reply #16 on: Mon, 25 July 2022, 13:14:18 »
Thanks! And yes! There will be extras once the set ships! :)
Offline dvorcol
Re: [GB] IV Ashes | MOQ REACHED!!!!
« Reply #17 on: Sun, 31 July 2022, 13:53:41 »
« Last Edit: Thu, 04 August 2022, 14:10:13 by dvorcol »
  • 無間道
« Reply #18 on: Mon, 01 August 2022, 02:17:01 »
Awesome!
Offline dvorcol
Re: [GB] IV Ashes | [Closed] Waiting to confirm final numbers!
« Reply #19 on: Thu, 04 August 2022, 13:49:35 »
<-- without extras
Offline att1cus
Re: [GB] IV Ashes | In Production Queue
« Reply #20 on: Wed, 28 September 2022, 10:34:20 »
Any updates on production? Still on-track for October/November delivery?
Offline valyrris
« Reply #21 on: Wed, 28 September 2022, 13:59:24 »
