Author Topic: [SEARCH] Makro Keyboard with Onboard Memory  (Read 3524 times)
Offline CeeSA
« on: Thu, 23 September 2010, 11:02:53 »
@work my keyboard is behind a raritan SwichtM KVM with PS/2.
i would love to hold some text (not only single letters) in some "hotkeys".
looking for a keyboard that has his own memory to save makros onboard.
do you know one or more?
Offline WhiteRice
« Reply #1 on: Thu, 23 September 2010, 11:06:01 »
You could always install texter on each machine and sync the hot script files.
Offline CeeSA
« Reply #2 on: Thu, 23 September 2010, 11:12:35 »
i could but @work this is against the policy
Offline WhiteRice
« Reply #3 on: Thu, 23 September 2010, 12:32:29 »
You could run it from a flash drive. Do your it guys monitor what services you run? Even in some of the most strict corporate environments you have every day Joes running Firefox and chrome.
The only reason I suggest it is because the feature set of texter is much more robust than anything you could program on a keyboard.
Offline itlnstln
« Reply #4 on: Thu, 23 September 2010, 13:04:55 »
You could do what I do, and boot a separate OS from another drive, and get around all the corporate IT bull****.
I am not your role model.
Offline WhiteRice
« Reply #5 on: Thu, 23 September 2010, 13:10:16 »
Quote from: itlnstln;225848
You're awesome
Offline CeeSA
« Reply #6 on: Thu, 23 September 2010, 15:48:40 »
so dump is our sercurity not. no usb, no bios pwd etc
Offline CeeSA
« Reply #7 on: Thu, 14 October 2010, 02:59:12 »
my keypad G84-4700 could handle up to 24 char per key
sometimes the solution is so easy.
another fullsizekeyboard Cherry MultiBoard G81-8308
