Author Topic: AEK II plate and case files  (Read 5267 times)
Offline TomahawkLabs
« on: Mon, 04 July 2022, 22:35:42 »
Does anyone have a drawing or model of the Apple AEK 2 Plate and or case?
Always looking for Alps SKCM/SKCL switches. Feel free to DM.
AMD 5600x | RTX3080 | 2x 1TB NVME + 4x 4TB HDD | B550M Pro-P | 32GB RAM | RM850x | Node 804 | Schiit Modius/Magnius + Audeze LCD-2 | 2x Dell S3422DWG
GMMK 1 Full Size Barebones | Zealio 67g ; Apple M3501 handwired | Alps SKCM Damped Cream
SA: Camping
Offline Rayndalf
Re: AEK II plate and case files
« Reply #1 on: Wed, 06 July 2022, 19:25:00 »
I have a plate and PCB from an AEKII whose case was badly damaged in shipping.
Do you want me to send you the plate?
« Reply #2 on: Sat, 09 July 2022, 08:38:28 »
I appreciate the offer, but I am looking for a digital file. I have a few AEKs at home that I want to design a PCB based off of Elmo's drop in replacement for a case I want to design. I was hoping someone had a CAD file of the case and plate to use as a starting point. I guess I will just need to invest in a pair of calipers.
SA: Camping
Offline Rayndalf
« Reply #3 on: Sat, 09 July 2022, 16:30:38 »
Can't you derive the plate information from the KiCAD files?
I'm not super familiar with that stuff (and Elmo's PCBs aren't 100% accurate) so the caliper route it probably preferable.
« Reply #4 on: Sun, 10 July 2022, 12:53:57 »
It is likely possible if I was a better at either software. I are relatively new to both software. Elmo's schematic is more what I was looking for. Full size, through hole parts, etc. I figure I can start with a sandwich case while I prototype PCBs before designing it's final case. The hard part with the AEK plate is some stabilizers are flipped and the AEK uses a spacebar stabilizer via a hole in the PCB. I attempted to make a rough copy in KLE, but was unable to make the small adjustments unique to the AEK. I think a nice set of digital calipers and some time in Fusion360.
SA: Camping
