Author Topic: [IC] Kitsune - A F13 TKL | Top/O-Ring Gummy Mount | GB November 3rd  (Read 25180 times)
Offline Dunne
    • Dunne
Kitsune
GB Thread: https://geekhack.org/index.php?topic=118708
Hi, I'm Dunne, this is the first TKL design that I want to share with you all, and a board that I’ve been working on for a while.
I’ll keep the inspiration stuff short since it is a TKL.
IC Form
Specs
Mount: Top and Gummy O-Ring
- Layout: F13 TKL | WKL
- PCB: Infinity 87.5 variant from Mechlovin'
- Materials:
    o Top and Bottom Case: Aluminum 6063
    o Weight: Clear Coated Brass or Aluminum 6063
    o Plate: Aluminum 5052, Polycarbonate | ANSI and ISO support
- Colors:
    o Top and Bottom Case: Anodized Silver, Burgundy & Black
    o Weight: Clear Coated Brass and Aluminum weight color options (Black, Silver, Gray, Burgundy and Red)
- Top arrow cluster engraving: Hiragana or no engraving options
- Heft: 1.6kg (Alu Weight Configuration), 2.1kg (Brass Weight Configuration), 2.48kg built
- Adjusted Front Height(s) & Typing Angle:
- Supported Layouts:
Alu plate render
PC plate render
- Exploded View:
Photos
Prototype 1
Front with engraving (the engraving is optional)
Sides and weight
Side profile
External Red aluminum weight
External brass weight
Plate and O-ring mounting showcase
Prototype 2
Proto 1 & 2 showcase
Side profile
Bottom view side profile
Proto 1 & 2 bottom showcase
Revisions
Prototype 1
- Screws: Adjusted screw head diameters, removed x1 bottom screw above the mask, adjusted internal screw threading
- Side profile: Adjusted side profile to be less sharp
- Adjusted case alignment pillars
- Front height: Adjusted front height by -1mm (now sits at 19.2mm)
- Internals: Adjusted internals for more breathing room for specific builds and their sound profiles
- Plate: Adjusted plate flex cuts for aluminum and PC
Prototype 2
- Internals: Adjusted it back to be the 1st prototype's sound and feel, with slight resonance hollowness in proto 2
- Adjusted top case's height to be 19.8mm
Typing tests
Proto 1 - Top Mount
Proto 2 - Top Mount
Sales Info
- Vendor: Mechkey
- Unit Total: 60
- Sales Format: FCFS (Google Form Format)
- Price:
    o $400 for Alu weight config.
    o $430 for Brass weight config.
Timeline/To-Do
- Revise current proto and order 2nd prototype
- Gather necessary feedback to gauge unit allocation, external aluminum weight color options, and sales format/pricing
- Send to Scuffed_Boards and LightningXI for review
- Start GB when all the above aspects have been finalized and I'm happy with the board's state. GB Late or Early November.
Socials
Discord
Instagram
« Last Edit: Sat, 29 October 2022, 08:59:38 by Dunne »
Offline Dunne
    • Dunne
Re: [IC] Kitsune - A F13 TKL | Top/ O-Ring Gummy Mount
« Reply #1 on: Tue, 12 July 2022, 01:20:12 »
Reserved
Based on Poll and Decisions
[07/23/2022]
- External Alu Weight Options: Burgundy, Black, Gray, Silver, and Red will be options
-"Keeping it WKL" is outweighing WK option: WKL is solely sorry
- FCFS is outweighing but I would favor that everyone has a fair chance to get a board instead of a faster WiFi connection. The sales format will be raffled
[09/28/2022]
- Videos added
- 2nd Prototype photos and revisions added
[10/18/2022]
- Protos sent to streams
- Pricing set
- GB Format and Date TBA shortly
« Last Edit: Tue, 18 October 2022, 06:38:36 by Dunne »
Offline Oraeth
« Reply #2 on: Tue, 12 July 2022, 01:47:30 »
So pretty :D
Any chance at halfplate?
Good stuff :O
Offline nonuser
« Reply #3 on: Tue, 12 July 2022, 01:52:54 »
fortnite tkl so zesty  :cool:
Offline ankit
  • Formerly ankit-sachdeva
« Reply #4 on: Tue, 12 July 2022, 01:54:03 »
n e plate photos avail or is just standard jane v2
Offline Riizmaa
« Reply #5 on: Tue, 12 July 2022, 01:55:00 »
FORTNITE FORNITE FORTNITE!
I LOVE FORTNITE AAAAAAAAAAAAAAAAAAAA
CRANKING 90s ON THESE NOOBS  :p
Offline //gainsborough
  • MATRIXの日常
« Reply #6 on: Tue, 12 July 2022, 02:15:56 »
I call my wife "kitsune".  I even address any letters I leave around the house to her with きつね.  I need this keyboard.
Offline Dunne
    • Dunne
« Reply #7 on: Tue, 12 July 2022, 02:52:56 »
Yeah it's a standard Jane V2 but I'll take more pics of it when the 2nd proto comes in.
Offline Dunne
    • Dunne
« Reply #8 on: Tue, 12 July 2022, 03:09:33 »
So pretty :D
Good stuff :O
Thanks! I'll consider it as an option too and/or release plate files via Discord.
Offline bigdonnerz
« Reply #9 on: Tue, 12 July 2022, 04:26:50 »
This is very nice. The only thing I'm not a fan of is the engraving – something about the proprotions of the face make it look more like a human than a kitsune. Apart from that, looks great GLWIC :thumb:
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #10 on: Tue, 12 July 2022, 10:34:44 »
Nice and simple. I like the weight personally.
Offline linell
« Reply #11 on: Tue, 12 July 2022, 13:37:07 »
:eek:
bro this a **** set, just be thankful you even getting 1 base running fr
Offline LMarci
« Reply #12 on: Tue, 12 July 2022, 14:08:44 »
:blank:
  • MATRIXの日常
« Reply #13 on: Tue, 12 July 2022, 15:04:37 »
don't judge me!
Offline treeleaf64
    • treeleaf64
« Reply #14 on: Tue, 12 July 2022, 22:12:19 »
Lol  yayayayaya!!!!!!
Everyone must pay the cat tax
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #15 on: Wed, 13 July 2022, 10:02:22 »
how flexy is this ? :cool:
Offline ZAND4
« Reply #16 on: Wed, 13 July 2022, 10:51:08 »
WK plz
Offline Dunne
    • Dunne
« Reply #17 on: Wed, 13 July 2022, 21:55:08 »
Thanks Lightning!
Offline Dunne
    • Dunne
« Reply #18 on: Wed, 13 July 2022, 22:10:50 »
It's not crazy flex but it has a decent amount of bounce (from the board's vibrations and mounting positions) when typing normally in both Top/O-Ring, I'd say.
Offline superjackie
« Reply #19 on: Wed, 13 July 2022, 23:29:49 »
is there any hotswap option
« Last Edit: Thu, 14 July 2022, 01:45:31 by superjackie »
Offline Dunne
    • Dunne
« Reply #20 on: Thu, 14 July 2022, 07:32:16 »
Thanks a bunch, it might be the angle of the mask via the pics since it's quite rounded IRL whilst looking at it top-down
Offline Microck
« Reply #21 on: Sat, 16 July 2022, 13:59:17 »
If you produce a WK version im in  :thumb:
Offline Homiezoned
« Reply #22 on: Sun, 17 July 2022, 11:32:49 »
Love the engraving. Def interested, GLWIC
Offline Mcnos
    • GMK Fuyu
« Reply #23 on: Sun, 17 July 2022, 12:20:38 »
i really like it
Offline LumiP
  • A lil Faedude on the net. Fave layout is FRLTKL!
    • Sometimes I do builds on Twitch! :3
« Reply #24 on: Sun, 17 July 2022, 16:47:54 »
This weight is gorgeous  :eek:
Current Boards: Aaru TKL Old Dark Sand, Drop + Planck Purple, Mr Suit WKL Black w/Gold Chamfers, Sangeo60 Black, KBD67Lite White, D45 E-Grey, Wind X Pink, NCR 80 Beige, QK65 Dark Green, Gentleman65 Black, Av4 Claymore, TGR x Monokei Tomo Suave Blue, Heracles80 Holy White, Snake60 Rust, Array E-White, Capsule E-White, QK75 E-White, Zoom75 Milky Green, QK80 Black, Envoy 65 PC, Mode Sonnet Ice Blue, Cycle 7 Lavender, E-White; Neo70 Retro White, Black; Reflection Chocolate, Neo80 Champagne, Matra Alice 90 Glossy Red;
Offline StanGetz
« Reply #25 on: Sun, 17 July 2022, 16:52:32 »
This one will be an instant buy from me should we see it. Really like it.
Offline armani_
« Reply #26 on: Mon, 18 July 2022, 01:38:51 »
Fun design, but perhaps doing a near 1:1 with the Jane v2 CE plate should be reconsidered.
One of v2 CEs biggest shortcomings was how subpar the top-mount experience was for it. Offering some sort of relief on those tabs, which only requires modification of the plate itself without you having to rework the case itself, could be a good play to just make it a better typing experience.
Overall, like what you've done with this design, definitely digging that side profile!
Offline Dunne
    • Dunne
« Reply #27 on: Tue, 19 July 2022, 17:49:31 »
Thanks for the nice words and mention regarding the plate tabs! I adjusted the plates now and added+/- flex cuts to try to optimize a better top mount experience for both plate variants (Alu & PC).
Offline Kajoler
« Reply #28 on: Sat, 23 July 2022, 08:36:14 »
Great looking board, very interested! Is the engraving design final?
>:0
Offline pr0ximity
« Reply #29 on: Sat, 23 July 2022, 19:44:13 »
Love the front lip and back weight, very classy
Offline Dunne
    • Dunne
« Reply #30 on: Sun, 24 July 2022, 09:51:12 »
Ty! Yeah engraving on the back is final.
Offline Dunne
    • Dunne
Re: [IC] Kitsune - A F13 TKL | Top/O-Ring Gummy Mount | 2nd Prototype
« Reply #31 on: Tue, 27 September 2022, 21:29:05 »
Updates on second prototype pics, revisions and both typing tests/demonstrations
Offline suishibe
« Reply #32 on: Sun, 02 October 2022, 03:00:43 »
kitsune
Offline Kokoboro
« Reply #33 on: Fri, 14 October 2022, 10:36:03 »
Im a red weight simp
Offline mr_foggy
  • neue = nope
« Reply #34 on: Fri, 14 October 2022, 18:06:15 »
if it actually won't exceed 400 I'm in
Offline Dunne
    • Dunne
« Reply #35 on: Tue, 18 October 2022, 06:37:31 »
I've set the prices for the brass and alu variants to be in that ballpark.
Offline VXQN
« Reply #36 on: Tue, 18 October 2022, 07:47:36 »
Weight engraving is honestly kinda bad (small eyes, low nose relative to the eyes make the cat look odd. Is the idea that the eyes and whiskers are constructed from typographic glyphs?) but the rest of the board is very nicely designed so I'll be trying for this!
Offline Dunne
    • Dunne
Re: [IC] Kitsune - A F13 TKL | Top/O-Ring Gummy Mount | GB Thread
« Reply #37 on: Sat, 29 October 2022, 09:01:44 »
GB Thread is live with prices and GB date! The product page link will be posted here, Discord and the GB thread this weekend:
