Author Topic: Victor 12PD - Calculator  (Read 7001 times)
Offline HaaTa
  • Master Kiibohd Hunter
  • Kiibohds!
    • http://kiibohd.com
« on: Fri, 24 September 2010, 19:11:39 »
Another find.
A Victor 12PD Calculator.
Nice keys...
Oh wait, they're doubleshots :D
Cherry like plungers,
And, huh, plate mounted switches?
Unfortunately, the keys have a very weird feel. Similar to a rubber dome or Cherry MY, but not really either. I'd open it up further, but I'll need to unsolder all of the switches to see...and I really don't want to do that.
As a bonus, it works :D
More pics on picasa.
Kiibohd
ALWAYS looking for cool and interesting switches
I take requests for making keyboard converters (i.e. *old keyboard* to USB).
Offline WhiteRice
« Reply #1 on: Fri, 24 September 2010, 19:24:55 »
Would it be too much to ask for a sound clip :3
I always enjoyed the sound of the printing
Offline HaaTa
  • Kiibohds!
« Reply #2 on: Fri, 24 September 2010, 19:38:15 »
Quote from: WhiteRice;226479
Hmm, don't really have a good microphone. Perhaps tomorrow though.
Kiibohd
Offline a_fluffy_kitten
« Reply #3 on: Fri, 24 September 2010, 19:43:29 »
Quote from: HaaTa;226475
Another find.
But can it run Crysis?
2x Filco Blue Tenkeyless (and boy are they nice)
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #4 on: Sat, 25 September 2010, 17:29:16 »
The µPD1224G seems to be a typical chip used in business calculators like these around 1981 (matching the date code on the ICs), it also found use in this TI.
Parts quality looks to be standard Japanese consumer electronics grade for the time. The board looks quite repairable in case the unit should ever decide to act up (dead electrolytics being the most likely failure mode, the regulator pass transistor is a 5 amp type and unlikely to be toasted), though I'd be very careful with that film cable... the technology wasn't that mature yet at the time, and they can be rather fragile.
Offline HaaTa
  • Kiibohds!
« Reply #5 on: Sat, 25 September 2010, 18:36:48 »
Thanks for the info.
Quote from: keyb_gr;226787
...though I'd be very careful with that film cable... the technology wasn't that mature yet at the time, and they can be rather fragile.
Good to know. Thankfully, I have no desire in dismantling the calculator anymore than it already is.
Kiibohd
Offline ricercar
  • mostly abides
« Reply #6 on: Sun, 26 September 2010, 16:44:24 »
I'd be very careful with that film cable... the technology wasn't that mature yet at the time.
A similar ribbon in my 1995 Kinesis Contour just cracked/broke on me. I wsh I had been more careful.
Offline didjamatic
« Reply #7 on: Sun, 26 September 2010, 16:59:18 »
Nice score!  I keep hoping I find a nixie display calculator but haven't yet.  I've seen a few of this vintage but not this clean.
Offline Phaedrus2129
« Reply #8 on: Sun, 26 September 2010, 18:18:25 »
Betcha half the weight of that calc comes from the step-down transformer for the linear power supply. Low-tech and bulky, but much simpler than an SMPS, where you'd have roughly five times as much circuitry. Instead just a transformer, rectifier, and capacitor. Nice, KISS.
« Last Edit: Sun, 26 September 2010, 18:20:42 by Phaedrus2129 »
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
Offline keyb_gr
  • Cherrified user
« Reply #9 on: Mon, 27 September 2010, 15:19:32 »
That, and you won't get any starting problems with a linear power supply. No worrying about highly variable loads either (which is why audio amps are only built with SMPS if weight/size is a concern, typically in pro applications - the few SMPS equipped home amps around in the early '80s were quickly found to be less reliable and definitely much more difficult to service).
