Author Topic: [IC] Koneko40 - A Bakeneko Inspired 40% - Update 7/2023 - PC case!  (Read 21519 times)
Offline hlord2000
Koneko40
IC Survey | Discord
Inspired by the Bakeneko, I present the Koneko40
Koneko means kitten in Japanese :)
Renders + Pics
300480-0
296448-1
296450-2
Credit: https://www.instagram.com/pensa.73/
Sound Tests
The following layouts will be supported.
Stagger board:
300478-3
Ortho board:
300476-4
PCBs will be soldered and will have RGB underglow
Options:
  • Aluminum case: red, blue, pink
  • PC case: frosted
  • Plate: aluminum, FR-4, PC
  • PCB: stagger, ortho
  • Hotswap Knob: linear, clicky
Features:
  • Bakeneko-style gummy o-ring mount.
  • Universal Daughterboard with new connector, center mounted USB-C port.
  • Rotary encoder support in collaboration with SKYLOONG - a hotswappable knob module.
  • Large brass weight.
  • Vial support using the RP2040.
IC Survey | Discord
« Last Edit: Mon, 10 July 2023, 00:00:26 by hlord2000 »
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
Re: [IC] Koneko40 - A Bakeneko Inspired 40%
« Reply #1 on: Mon, 25 July 2022, 12:06:26 »
nice
Offline dededecline
    • Linktree
« Reply #2 on: Mon, 25 July 2022, 12:16:16 »
Damn, can’t even get proper 40% row profiles in our renders
Offline PuNkShoO
  • I make keyboard switches.
    • Check out my projects!
« Reply #3 on: Mon, 25 July 2022, 12:31:23 »
No bad. Simple. Will you be open sourcing the files like the Bakeneko?
Offline hlord2000
« Reply #4 on: Mon, 25 July 2022, 21:01:19 »
I will be providing files for the edgecuts, JST placement, and plates for various layouts.  :thumb:
Offline PuNkShoO
« Reply #5 on: Mon, 25 July 2022, 21:05:10 »
Great! Thanks for the follow up!
Offline hlord2000
« Reply #6 on: Mon, 25 July 2022, 22:36:21 »
275?????????????????????????????
yea maybe with the moq of the one person who wants in on this
Apologies if you're dissatisfied with the price or uninterested in the product. This is a pre-prototype keyboard that is likely to go through another revision before being offered in a groupbuy. The price given above is a very rough estimate.
I have also received over 150 responses to my various interest checks--I am confident that there is a demand for a 40% like the Koneko.
Mod Edit: Removed the quoted post and a couple responses in order to keep the thread clean. Kept this response as it is informative/valuable. :thumb:
« Last Edit: Thu, 28 July 2022, 09:55:48 by HoffmanMyster »
Offline unusuaL_
« Reply #7 on: Wed, 27 July 2022, 04:27:06 »
when the neko is...ko? looks nice
collection: hibike 1/1, garderie tkl, casper60, hhkb pro2, matrix 2.0additional, f1-8x og
Offline hlord2000
« Reply #8 on: Wed, 27 July 2022, 14:11:20 »
ah i should add an explanation. will do shortly.
« Last Edit: Wed, 27 July 2022, 14:21:35 by hlord2000 »
Offline LMarci
« Reply #9 on: Thu, 28 July 2022, 18:11:21 »
Pretty cool
Offline joedinkle
  • Eye Oh Designs
    • Eye Oh Designs
« Reply #10 on: Thu, 28 July 2022, 23:02:10 »
2x2.25 spaces for ortho? gonna be hard to kit. 2x2u works great.
Vixen
Offline hlord2000
« Reply #11 on: Sat, 30 July 2022, 21:49:32 »
Would a 2.25u + 2.75u split be better? Guess it isn't ortho then? Not sure! Thank you for your feedback though, trying to get a better feel on what the ortholinear folks want!
Offline selsik
« Reply #12 on: Sun, 31 July 2022, 01:46:37 »
I'd love to get this with the ortho pcb, but it looks like you didn't put much thought or did enough research to realize the layout options for ortho kinda suck and aren't really viable
I offer this as a suggestion:
Not sure if you can offer an HHKB case so just leaving the idea out there.
« Last Edit: Sun, 31 July 2022, 01:50:35 by selsik »
Topre >>> MX
Offline rpiguy9907
« Reply #13 on: Mon, 01 August 2022, 08:58:57 »
Koneko40 - supports all the spacebars except the one you are likely to own  :))
Offline hlord2000
« Reply #14 on: Tue, 02 August 2022, 23:43:41 »
Apologies for that, I'm relatively new to 40% keyboards. I intend to add the suggestions given above! Thank you for your feedback.
Offline joedinkle
  • Eye Oh Designs
    • Eye Oh Designs
« Reply #15 on: Wed, 03 August 2022, 09:44:49 »
Most ortho folks are going to be used to seeing 2x2u.
Vixen
Offline Shunfry
  • #Yolo.
« Reply #16 on: Fri, 26 August 2022, 08:55:50 »
Love the 10u layout add.
Offline hlord2000
Re: [IC] Koneko40 - A Bakeneko Inspired 40% - Update 2/2023
« Reply #17 on: Mon, 13 February 2023, 19:23:13 »
Update: redesigned after a few months of daily driving. Created a hotswap PCB--will likely do both ortho and stagger hotswap. Working with @pensa.73 on Instagram for renders now. Does a great job!
Offline patcoll
  • !40s
« Reply #18 on: Mon, 13 February 2023, 20:17:37 »
Strongly encourage you to consider 2x2u for ortho. Heck, even stagger layout too.
Offline hlord2000
« Reply #19 on: Wed, 19 April 2023, 17:05:43 »
UPDATE: prototypes have finished at manufacturer. Will update once they are in hand.
298463-0
Offline hlord2000
Re: [IC] Koneko40 - A Bakeneko Inspired 40% - Update 4/2023
« Reply #20 on: Sun, 07 May 2023, 23:22:08 »
Updated with pictures of protos. Everything works! Need to do a refresh of the PCB and get the stagger one ready to go.
298892-0
298894-1
298896-2
298898-3
298900-4
Offline nainaigogo
Cute!
Offline sugarfreemedia
another vote for 2x2u for ortho
Offline hlord2000
Re: [IC] Koneko40 - A Bakeneko Inspired 40% - Update 7/2023 - PC case!
« Reply #23 on: Mon, 10 July 2023, 00:07:07 »
Added pics and soundtest along with more info on layouts, PCB, plate, and case materials.
Offline ToFuMaNiA
« Reply #24 on: Mon, 21 August 2023, 20:38:03 »
clean 40%!
