Author Topic: [IC] Daal - A Plateless O-Ring 60% - Production units ordered!  (Read 69766 times)
Offline chat and team
Re: [IC] Daal - A Plateless O-Ring 60%
« Reply #50 on: Thu, 28 July 2022, 12:05:45 »
Not bad
definitely beats the recent Ics and more
40% bakeneko 275
Kikkou 245 bakeneko
Ladybird 60 415 at 300u
Cringe 395 at 300u 2 piece btw
Just one of the better if not the best ICs I've seen in a while
xyz daughterboard yes
weight yes
50 units in stock for 280 (wish there was more this would sell as hotcakes and would also help out the local food bank more)
I'm against shilling/friends praising geekhack threads so much but, I do think this IC does deserve lots of praise, it really knocks the ball out of the park. Hopefully, clout won't get to your head and you can keep doing projects like this.
Great job op  :thumb:
geekhack mods constantly break tos and refuse to read
Chinese overlords won
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #51 on: Thu, 28 July 2022, 12:13:06 »
neat little keyboard
do you happen to have pictures of the bottom and the back where the port is?
Offline ankit
  • Formerly ankit-sachdeva
« Reply #52 on: Thu, 28 July 2022, 12:39:19 »
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
« Reply #53 on: Thu, 28 July 2022, 13:04:31 »
Not bad
40% bakeneko 275
Kikkou 245 bakeneko
weight yes
thanks chat and team. as always, your opinion is valued by everybody on geekhack
Offline Sleepdealr
  • my name is calliah
    • https://sleepdealer.xyz
« Reply #54 on: Thu, 28 July 2022, 13:08:07 »
Looks like ****. GLWIC
/s
« Reply #55 on: Thu, 28 July 2022, 13:19:34 »
Offline ankit
« Reply #56 on: Thu, 28 July 2022, 13:35:36 »
Just finished unboxing, flashing, and testing strimmer PCBs. Two changes were made from the previous version:
- Changed switch leg holes from 1.75mm to 1.70mm to accommodate more switches
- Added ISO support
These are identical to production PCBs with the exception of WKL support
Some more small changes implemented.
« Last Edit: Tue, 13 September 2022, 12:54:39 by ankit-sachdeva »
Offline caroeggu
« Reply #57 on: Thu, 28 July 2022, 13:58:04 »
this is BUSSIN'. GLWIC and GB!
Offline darthcapn
« Reply #58 on: Thu, 28 July 2022, 14:09:24 »
Nice I am hungry for some "Maa ki daal" now. Looks really really good. Will look out and pick one if I can!
Praxis | Portal | Frog F13 | Vega | Sat75 | F2-84 | Iron 165 | KFE CE | Spring | Pandora | Mr Suit | MGA | Jelly Epoch
Dolice | Glare | Vmax chyuu | W1-AT | Hoshizora | iron 160 | Nazaré | Tomo
Offline Mdark205
« Reply #59 on: Thu, 28 July 2022, 15:54:00 »
board looks great! we love to see another ankit ic  :thumb:
Offline lewisflude
  • Hand Engineering
    • Hand Engineering
« Reply #60 on: Thu, 28 July 2022, 16:33:20 »
I happy someone trying to do something differnt with a good target price of $280 in-stock buy. This looks like a plateless mount using a o-ring around each of the 4 pcb tabs for flex as such this is not a true o-ring mount just because the design use a o-ring does not make it a o-ring mount (i.e. a burger mount use small o-rings around the screw but cannot be called o-ring either). Please change the title of your ic for currently calling this a o-ring mount does a disservice to keyboard community and other great designs that are true o-ring mount which suspend the pcb all the way around providing the the flex GLWIC.
This comment is so factually and spiritually incorrect that I don't even have the soul power to correct you properly. A board with an o ring is o ring mount, simple as, nuffin much more to it. Back in my day, if a keyboard even smelled a whiff of rubber we called it gasket mount and we were happy. You used to get what your're given. Please take this negativity elsewhere!!! You have been warned
RISE UP LENTILHEADS
« Reply #61 on: Thu, 28 July 2022, 16:48:21 »
Looks so good! Good luck Mr. Ankit
Offline paqji
« Reply #62 on: Thu, 28 July 2022, 16:55:29 »
great cause, showing my interest now so that we can get more into food banks together :thumb:
Offline Farhandsome
    • Han Boards
« Reply #63 on: Thu, 28 July 2022, 18:17:06 »
I love daal!! And also this keyboard
Offline LONGZILLA
  • ヽ(`Д´)ノ rawr
« Reply #64 on: Thu, 28 July 2022, 22:45:05 »
Very fresh,gl
Offline jeroplane
« Reply #65 on: Thu, 28 July 2022, 23:00:23 »
Very, very interested in this project. Been following on discord for past few weeks but found my old GH login to comment here to support. GL and I will definitely be picking one up if I can.
My signature hasn't changed since 2012. I should really update it.
Offline elvenmonster
« Reply #66 on: Fri, 29 July 2022, 00:53:50 »
Best of luck icac! Looking forward to some tadka
Offline Deadline.Studio
« Reply #67 on: Fri, 29 July 2022, 01:11:20 »
very nice :thumb:
Offline VXQN
« Reply #68 on: Fri, 29 July 2022, 04:03:49 »
Lovely looking board. Reminds me of the Noxary x60 v1, which I always thought was a well proportioned board.
Offline atkins
« Reply #69 on: Fri, 29 July 2022, 04:06:36 »
You are taking this way too serious, dude. Calm down.
Offline mr_foggy
  • neue = nope
« Reply #70 on: Fri, 29 July 2022, 06:01:58 »
ankit doing good to the scene again
great job, will purchase.
Offline sviz
« Reply #71 on: Fri, 29 July 2022, 22:26:49 »
protos look great, glwic. glad to see all the time you've spent on this pay off, nice to see files will be open source
Offline Darth_Austin
« Reply #72 on: Sat, 30 July 2022, 09:48:15 »
Very nice looking board. The price is amazing. GLWIC.
Offline mr_foggy
  • neue = nope
« Reply #73 on: Sat, 30 July 2022, 13:08:52 »
man I saw the proto in your pp60 live build and damn. I want it.
Offline gotgoodiez
« Reply #74 on: Sat, 30 July 2022, 13:20:33 »
Grew up eating daal and rice so now I need to type on it too. Plus supporting a great cause, amazing everything with this one!
Offline HappyB0T
  • I'm a Piggie
« Reply #75 on: Sun, 31 July 2022, 00:15:46 »
Have a feeling that 50 gonna go fast at your target price. Cool looking board considering WKL
Offline Keeblet_257
« Reply #76 on: Sun, 31 July 2022, 04:22:33 »
looks like a great board :thumb:
Offline treeleaf64
    • treeleaf64
« Reply #77 on: Sun, 31 July 2022, 19:39:20 »
Right now I am going to eat dinner at a nice restaurant
All I can think about is my Frogger Ankit Sachdeva Yayayayyaa!!!
Everyone must pay the cat tax
Offline densus designs
  • * St. Jude Supporter
« Reply #78 on: Mon, 01 August 2022, 15:12:20 »
this is a very solid-looking keyboard, also a good runner and price! would definitely recommend to anyone starting out in the hobby or looking for another board to add to their collection!
Offline ABlazinBlueToe
« Reply #79 on: Tue, 02 August 2022, 11:38:48 »
Looking forward to this, looks like a great board for an impressive pricetag.  Really appreciate the addition of WKL also
Offline conternecticus
« Reply #80 on: Tue, 02 August 2022, 20:02:09 »
Very nice to see WKL. GLWIC!
Offline IconlabsOfficial
  • Where makers make art!
    • Iconlabs
« Reply #81 on: Wed, 03 August 2022, 00:18:15 »
This is next level! Hyped
Offline milka158
« Reply #82 on: Wed, 03 August 2022, 01:25:58 »
ankit putting out one banger project after the other
Offline bow3i
« Reply #83 on: Wed, 03 August 2022, 13:55:34 »
This looks like the Hex 4B's mounting style.
it is
!! That's sick, I love my 4B and this would be a nice addition to the family. Love seeing this mounting style more and more tbh.
Offline HYP3RION
« Reply #84 on: Wed, 03 August 2022, 15:04:45 »
Oh no... looks like my bank account might be getting lighter soon.
Offline cruelworld
  • Formerly 'acruelwrld'
    • cruel world
« Reply #85 on: Thu, 04 August 2022, 00:55:41 »
v excited to see this materialize - glwic homie
Offline blunt
« Reply #86 on: Thu, 04 August 2022, 23:50:56 »
great keyboard at a great price by a suspect designer
« Reply #87 on: Fri, 05 August 2022, 08:28:42 »
suspect deez
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #88 on: Sun, 07 August 2022, 19:32:54 »
ankit makes a lot of things I like. glwic :thumb:
Offline treeleaf64
    • treeleaf64
« Reply #89 on: Mon, 08 August 2022, 00:51:57 »
suspect deez
The Treeleaf Is Suspicious
The puddsy is known to bait certain individuals when they are performing Cuck and  Ruck Activities   Here is a fine example  Suspect Deez and Ruspect Reez
Offline nonuser
« Reply #90 on: Mon, 08 August 2022, 02:01:21 »
suspect deez
please explain in fortnite terms
Offline Riizmaa
« Reply #91 on: Mon, 08 August 2022, 02:02:07 »
Treeleaf is really sus someone should stop him or else i will get sussy also hehe and we dont want super sussy rizzy LOL im coming for you !!!  :p :p :p :p
Offline Meepergon
« Reply #92 on: Mon, 08 August 2022, 12:02:46 »
Daal is very good looking. GLWYIC bby.
Offline ranoro
« Reply #93 on: Mon, 08 August 2022, 13:13:39 »
will be joining but do you have plans to expand this design to 65% too?
Offline ankit
« Reply #94 on: Mon, 08 August 2022, 15:17:53 »
nope  :thumb:
Offline blunt
« Reply #95 on: Thu, 11 August 2022, 00:37:58 »
are there any plans to collab with kneedeep on the brass weight?
Offline irithyll
« Reply #96 on: Thu, 11 August 2022, 07:07:35 »
I really like this project - the design, the effort that went into the IC, the price, and the goal.
Unfortunately, I'm a normie that can't give up my WK haha
Definitely got me interested in future projects though
Offline Backspace2
  • Third most used key on the keyboard is Backspace!
« Reply #97 on: Thu, 11 August 2022, 09:22:45 »
Definetly interested. I would prefer raffle because FCFS has not been kind to me.
Yes
Offline ankit
« Reply #98 on: Thu, 11 August 2022, 12:53:59 »
Still undecided on sales format. With the ways things have been going in this hobby recently, I really doubt there will be enough interest for it to make much of a difference anyways.
Online Rafa_n
  • stuffforrectangles.etsy.com
« Reply #99 on: Thu, 11 August 2022, 14:30:07 »
With the a amount of build streams that you have announced, I expect this to be very popular.
