Author Topic: [IC] GMK Macros - Paused  (Read 15750 times)
Offline mcmcmc
« on: Sat, 30 July 2022, 09:04:12 »
GMK Macros
Another GMK set? Yes, it has been in IC for almost 2 years now. Using R1 for macro column hurts my brain. I want this. - Big thanks to Pwner for letting me take over this project.<3
IC Form
Any feedback is appreciated.
Details
Material - ABS
Legends - Doubleshot
Colors - GMK WS1, CR, U9, N9, CP
Kits
Keyboards
OGR by AKB
Eerie by dudeship
Discord
Follow more of my projects here.
Thanks
dudeship for lovely renders.
You for reading this IC.
« Last Edit: Sat, 13 April 2024, 05:20:52 by mcmcmc »
Offline mcmcmc
Re: [IC] GMK Macros
« Reply #1 on: Sat, 30 July 2022, 09:04:47 »
reserved
Offline DeMechanica
Re: [IC] GMK Macros
« Reply #2 on: Sat, 30 July 2022, 09:09:40 »
Lit
Offline roostrc0gburn
  • its just plastic
Re: [IC] GMK Macros
« Reply #3 on: Sat, 30 July 2022, 09:09:41 »
yes
Offline stomaha
Re: [IC] GMK Macros
« Reply #4 on: Sat, 30 July 2022, 09:11:00 »
I love you for doing this.
Offline Adelscott
Re: [IC] GMK Macros
« Reply #5 on: Sat, 30 July 2022, 09:16:07 »
Yes!
Please think about ISO users, add a split left shift to your "alice style" keyboards
Offline aa212121
Re: [IC] GMK Macros
« Reply #6 on: Sat, 30 July 2022, 09:27:08 »
Can this be merged with Beige addon if possible please? At this point I'm buying all those and this.
Offline mcmcmc
Re: [IC] GMK Macros
« Reply #7 on: Sat, 30 July 2022, 09:36:25 »
no. i myself will go all-in for both beige addon & hineybeige which will go to gb soon. i don’t wanna spend a lot of money on keycaps in a matter of 2-3 months yk. with that said gmk macros will most likely be running in Q1-2 next year.
Offline ankit
  • Formerly ankit-sachdeva
Re: [IC] GMK Macros
« Reply #8 on: Sat, 30 July 2022, 10:13:36 »
i love you mcmcmc, thank you for running this
Offline hkhawk
Re: [IC] GMK Macros
« Reply #9 on: Sat, 30 July 2022, 10:23:01 »
Please, I need this. Thank you
Offline plag
  • Formerly pepperonichicken
  • i also go by plag
Re: [IC] GMK Macros
« Reply #10 on: Sat, 30 July 2022, 11:35:27 »
Awesome
Offline Ella
  • Why is it called an oven
Re: [IC] GMK Macros
« Reply #11 on: Sat, 30 July 2022, 12:13:46 »
How dare you, I’m telling pwner!
  • its just plastic
Re: [IC] GMK Macros
« Reply #12 on: Sat, 30 July 2022, 12:22:00 »
couple questions:
have you considered adding R0?
are these going to be offered in 10pc and 5pc kits?
Offline mcmcmc
Re: [IC] GMK Macros
« Reply #13 on: Sat, 30 July 2022, 22:10:28 »
couple questions:
1.yes, i have considered adding it. but the number of boards that has a macro column up to f keys is small. it’s not worth doing it imo.
2.there’ll be 2 kits offered - Monochrome (BOW&WOB) and Classic (Beige&Dolch)
i might split the kits into 4 (BOW, WOB, Beige and Dolch), but that depends on the response
« Last Edit: Sat, 30 July 2022, 22:16:44 by mcmcmc »
Offline mcmcmc
Re: [IC] GMK Macros
« Reply #14 on: Sat, 30 July 2022, 22:19:46 »
Offline synthetics
  • very cool
Re: [IC] GMK Macros
« Reply #15 on: Sun, 31 July 2022, 13:49:28 »
Cool, I'd get these.
Offline TjarleN
Re: [IC] GMK Macros
« Reply #16 on: Mon, 01 August 2022, 01:31:18 »
nice to see this moving again, will probably pick up beige if its split into its own kit.
Offline VXQN
Re: [IC] GMK Macros
« Reply #17 on: Mon, 01 August 2022, 03:20:44 »
Yep. I want 'em, I'll buy 'em, wait times be damned.
Offline syntxtypes
Re: [IC] GMK Macros
« Reply #18 on: Mon, 01 August 2022, 08:57:16 »
Holy **** im in
Offline EdgeOfInfinity
Re: [IC] GMK Macros
« Reply #19 on: Tue, 20 September 2022, 14:21:59 »
fingers crossed!
Offline vonk
Re: [IC] GMK Macros
« Reply #20 on: Thu, 06 October 2022, 08:36:45 »
These *NEED* to happen!
Offline herfalerf
Re: [IC] GMK Macros
« Reply #21 on: Thu, 06 October 2022, 14:06:20 »
Yes.
Offline MMJ1999
Re: [IC] GMK Macros
« Reply #22 on: Thu, 06 October 2022, 22:30:53 »
Must have
Offline synthtastic
Re: [IC] GMK Macros
« Reply #23 on: Fri, 07 October 2022, 17:03:01 »
Sad this is not GMK Macross. GLWIC!
Expensive plastic makes me sigh.
Offline mcmcmc
Re: [IC] GMK Macros - Paused
« Reply #24 on: Thu, 10 November 2022, 08:12:19 »
unfortunately, i don't see this set hitting MOQ. gmk macros will be paused for an indefinite period.  :(
edit: this has nothing to do with beige addon gb. beige addon numbers is great, don’t worry. considering the amount of ic responses is very low, i don’t see it hitting moq. in addition, hobby has settled down a lot, it’s really really risky to go forward with the current state of the hobby.
« Last Edit: Thu, 10 November 2022, 10:29:52 by mcmcmc »
Offline stomaha
« Reply #25 on: Thu, 10 November 2022, 12:07:33 »
NOOOOOOO
Offline IOVERCALLHISTIOCYTES
« Reply #26 on: Thu, 10 November 2022, 12:16:44 »
Thank you for running the child kits for beige we do get to have!
In for at least one of each of these if they ever do go.
Offline VXQN
« Reply #27 on: Thu, 10 November 2022, 12:18:19 »
Oh god damn it. Feels like one of those kits that doesn't exactly excite people, but would actually do well. Perhaps that's just wishful thinking...
« Reply #28 on: Thu, 10 November 2022, 13:22:23 »
The X factor w this one is that some people (me being one) might buy a couple kits. Conceivable 5-6 individuals would buy 20.
Offline stomaha
« Reply #29 on: Thu, 10 November 2022, 13:27:27 »
I own 2x Jubi, 2x, Zenith, and soon 3x Nox 378. I’d buy at least 10 kits.
Offline chigi22
« Reply #30 on: Thu, 10 November 2022, 14:57:18 »
Chiming in to say I'm also sadge this kit is getting postponed. I didn't initially fill out the IC but am definitely in for a kit if/when it ever does run.
« Reply #31 on: Thu, 10 November 2022, 16:43:31 »
Chiming in to say I’d buy 2-4 kits if this ran. Either way, thanks for all your work :)
Offline hkhawk
« Reply #32 on: Thu, 10 November 2022, 22:18:53 »
I am in for two of each. If GMK UWU made MOQ then I don't see how this wouldn't even with the hobby "settling down" this is more flexible overall than that was (and I got UWU). Very disappointed if this isn't running.
Offline vonk
« Reply #33 on: Fri, 11 November 2022, 03:22:31 »
Aww crap.  I needed at least one of each.
Offline lunaterra
« Reply #34 on: Fri, 11 November 2022, 03:39:46 »
Cross your fingers!
bitlife
[/url]
Offline Crabzul
« Reply #35 on: Thu, 01 December 2022, 10:56:22 »
I have some boards that desperately need macro keys. I'd buy 4-5 sets of each kit. Hope this GB will happen some day.
  • its just plastic
« Reply #36 on: Thu, 01 December 2022, 11:16:11 »
UNPAUSE
« Reply #37 on: Wed, 11 January 2023, 14:44:16 »
my 2023 resolution is to only use appropriate row keys for macro columns :p
Offline stomaha
« Reply #38 on: Wed, 11 January 2023, 17:02:50 »
unpause please
