Author Topic: [IC] DCS Superweld  (Read 119926 times)
Offline adi518
Re: [IC] DCS Hyperfuse
« Reply #50 on: Thu, 04 August 2022, 06:06:15 »
At last! it seemed odd to me that this set was not getting another run after so long.
Offline el_lento
« Reply #51 on: Thu, 04 August 2022, 06:15:24 »
ne alps avail
Thank you.
Offline Pontus
« Reply #52 on: Thu, 04 August 2022, 06:36:11 »
Finally another run! I'll definitely buy into this  ;D
Offline pixelpusher
« Reply #53 on: Thu, 04 August 2022, 07:45:33 »
No chance for purple accent?  Maybe just esc and enter?  I own every HF set so far, so I’ll def pick this up as well if it runs.
Offline Ella
  • Why is it called an oven
« Reply #54 on: Thu, 04 August 2022, 08:08:13 »
This is the best key to ever set
Offline lewisflude
  • Hand Engineering
    • Hand Engineering
« Reply #55 on: Thu, 04 August 2022, 08:23:25 »
reserved
« Reply #56 on: Thu, 04 August 2022, 08:33:07 »
can you post some renders without that weird paper effect? i have trouble seeing and the visual artifacts aren't helping.
thanks
i'll probably buy regardless though
Offline Friendship
« Reply #57 on: Thu, 04 August 2022, 08:33:25 »
niceeeeeee
Collection: LZ GHv2, Esheu Fallacy, Moesode Bliss, Daji Ocho Cuatro, Ace Saturn60, Bolsa Midway60, MLI NUM1, MLI VISION, PW ROTR
Offline rpiguy9907
« Reply #58 on: Thu, 04 August 2022, 08:43:45 »
Can someone tell me why the GMK Hyperfuse (ran by Originative) and JTK Hyperfuse (Novelkeys) don't count as cylindrical runs of the set?
I think it looks better in DCS, but seemed like an odd statement to discount the above.
Offline pixelpusher
« Reply #59 on: Thu, 04 August 2022, 09:22:51 »
I think the devil is in the details.  He says "a proper cylindrical rerun"
Perhaps implying previous runs lacked in kit options or color choices?
« Reply #60 on: Thu, 04 August 2022, 09:47:36 »
oco hasn't run the original colorway of GMK hyperfuse in a couple years now, lots of hyperfuse redux/revamped/re-whatever but not the OG colorway
Offline LazerFox
« Reply #61 on: Thu, 04 August 2022, 11:20:02 »
Please include UK/Internationals kitting.
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
« Reply #62 on: Thu, 04 August 2022, 11:30:00 »
r2 escape doesn't get an accent color?
gonna be forced accent mb
gib
also:
* accent r2 1u esc and r3 1.5u enter pls
* r3 1.25u tab is missing
* consider adding accent arrows to base or extension
* no idea what the r2 1.25u tab in extensions is for, you can probably remove that. if it's meant to be 1.5u as the size indicates, still not sure what it's there for as there isn't alt alphas or anything. (edit: looks like different legend, in that case just fix the size)
* consider adding additional staggered 40s support in ext: r3 1.25u enter, r3 1.75u accent enter, r4 1u shift would be sick
* your 2.25u spacebar is mislabeled as 1.25u. also you're missing 2u spacebar
glwic/gb  :thumb:
will do accents; i forgot the tab; arrows will be considered; xt tab is labeled wrong; extra 40s will be considered; will fix bars
you’ve got your A & S swapped in the renders. SAD!
looks cool tho!
 :eek:
Hopefully can actually happen. Consider DailyClack for OCE vendor
Timeless classic, very keen. Consider SwitchKeys for OCE vendor.
No 2U Spacebar?
Non-stepped Caps lock with window would be nice too.
mb about the bar; full touch windowed caps lock probably not happening
Any chance of UK ISO support?
Centre stepped is my new vibe. :cool:
maybe international
Alps kitting? :please:
Any chance of adding an Alps kit?
ne alps avail
Thank you.
maybe alps, but harder
Ommit F8 for the memes
there is no f8 in the bars kit
probably
this
This is great can we actually make it happen
not bad! might join the gb
Consider my interest checked  :-*
Such good ****. Might go all in :thumb:
GIMME GIMME GIMME this ticks all the boxes! Laur ftw
in
In for every kit. DCS to the moon
All I can say is, good luck with this IC.
If this ever runs GB I'm definitely joining. Nice renders btw!  :thumb:
Hot
Yes.
That is one sassy extension kit. Hopefully, SP is nice to you / us. Would buy.
in for all kits
yes, yes, a thousand times yes
I'm in
Definitely in.
This is very nice.
Will buy if the price comes in looking reasonable.
I love DCS and I love Hyperfuse, glwic.
Very nice, gib
hyperfuse that will actually arrive? and gorton? yes
niceeeeeee
<3 thanks
Noice.
a
Offline VXQN
« Reply #63 on: Thu, 04 August 2022, 11:38:06 »
Please sir, may I have some UK ISO?
Offline Antiquary
« Reply #64 on: Thu, 04 August 2022, 11:50:19 »
Definitely interested :)
Offline rpiguy9907
« Reply #65 on: Thu, 04 August 2022, 12:15:04 »
I was going to refute you, but I forget how much time has passed (feels like two years are missing because of COVID). It has been a long time since this ran!
Offline puggo69
« Reply #66 on: Thu, 04 August 2022, 12:45:57 »
lit
« Reply #67 on: Thu, 04 August 2022, 13:08:27 »
i only knew because i kept wanting to buy a set and then not being able to
« Reply #68 on: Thu, 04 August 2022, 13:09:14 »
oh also do you have permission from SP/bunny to run this? i believe this has come up before on other sets
Offline beelzking
« Reply #69 on: Thu, 04 August 2022, 13:41:48 »
Alps Kitting, please.
GLWIC  :thumb:
Offline 4milk
« Reply #70 on: Thu, 04 August 2022, 13:45:00 »
I am interested
« Reply #71 on: Thu, 04 August 2022, 15:03:52 »
Will join for sure if this set can be run. GLWIC!
Offline LMarci
« Reply #72 on: Thu, 04 August 2022, 16:30:03 »
Very nice, might get a set.
Offline ZavaZ86
« Reply #73 on: Thu, 04 August 2022, 18:34:32 »
Surely OCO won't ruin this like they tried to last time
« Last Edit: Thu, 04 August 2022, 22:17:06 by ZavaZ86 »
Offline nostyle_au
« Reply #74 on: Thu, 04 August 2022, 18:37:50 »
Judging by the thanks to bunny for ghosting portion I'd guess no, that's the concern I have with this actually going ahead too. Would love to see it happen but SP has a history of blocking sets based on previous runners not supporting it :/
« Reply #75 on: Thu, 04 August 2022, 18:39:23 »
Definitely something to figure out before you get vendors on board and not after. OP could have already solved it, though. I'm just speculating.
Offline kibrens
Re: [IC] DCS H̶y̶p̶e̶r̶f̶u̶s̶e̶ WIP
« Reply #76 on: Thu, 04 August 2022, 22:00:03 »
Will love to participate in the gb
Looks great and appreciate 3-key support
Offline giuliano.cz
« Reply #77 on: Thu, 04 August 2022, 22:12:04 »
GLWIC! I see an extra B with the base kit, all it's missing are split spacebars for Alice layout, and that'd make me want to grab a set  ;)
Other than that, beautiful colors and hopefully everything goes well :thumb:
Offline MoarCoffeePlzzz
  • Formerly Deeptek
« Reply #78 on: Thu, 04 August 2022, 22:48:46 »
One of my favorite sets. I’m in.
Offline Wicky
« Reply #79 on: Fri, 05 August 2022, 00:41:29 »
please make this happen, I will love you forever
Pok3r RGB | Planck | Lightsaver v3 | HHKB Pro 2 | Rama Koyu | Lubrigante | TGR Alice | Unikorn | Unikorn Poly | Thermal | KFE CE | 7v | Pandora | Viper v3 | Moment r0 | Bias r2
Offline leexy
« Reply #80 on: Fri, 05 August 2022, 04:23:30 »
DCS SAD
Offline cosmo10292
« Reply #81 on: Fri, 05 August 2022, 10:00:53 »
Sign me up!
Offline hineybush
  • student of error
    • hineybush keyboards
« Reply #82 on: Fri, 05 August 2022, 14:37:58 »
very excited for this version of SuperWeld
Offline PvtSkittles
« Reply #83 on: Fri, 05 August 2022, 15:17:52 »
This is a set I would go all in on. Extensions kit, 10u spacebar, I want it all.
Offline Magnificent Bureaucrat
  • Sooooo much red tape
« Reply #84 on: Fri, 05 August 2022, 17:42:34 »
Hyperfuse was the set that first drew me into the hobby so I'd definitely be down for picking this up. Stepped bottom row calls to me
Offline plag
  • Formerly pepperonichicken
  • i also go by plag
« Reply #85 on: Fri, 05 August 2022, 17:49:38 »
stepped bottom row keys?! im not really a huge fan of hyperfuse colors, but i may have to get this just for stepped bottom row and 10u for the w1-at.  :)) glwic  :p
Offline superdoedoe
  • ( ͡° ͜ʖ ͡°)
« Reply #86 on: Fri, 05 August 2022, 19:44:39 »
This isn't the first time someones tried rerunning hyperfuse. GL getting SP to run it as it currently is.
Offline s.ja
  • asj
« Reply #87 on: Sat, 06 August 2022, 02:55:40 »
please, Add one person who wants the Alps kits.
Offline ottagerreip
« Reply #88 on: Sat, 06 August 2022, 04:05:59 »
Why previous attempts failed ?
Offline DirtyGingy
« Reply #89 on: Sat, 06 August 2022, 05:52:16 »
Is that some gorton legends I see?
Offline mason.
  • dn
« Reply #90 on: Sat, 06 August 2022, 10:20:42 »
looks extremely thocky  :thumb:
« Reply #91 on: Sat, 06 August 2022, 12:36:05 »
SP typically won't rerun sets that they've run previously with a different designer.
Offline XiXora
« Reply #92 on: Sat, 06 August 2022, 19:21:49 »
One more 1u alt in the extension kit would enable full hhkb/Mac compatibility, if possible, please.
Offline nonuser
« Reply #93 on: Sat, 06 August 2022, 23:43:57 »
why does the keycaps have wrinkles on it? maybe you should of done a render of the set on the iron165 LOLOL  :)) :)) :)) :)) :)) (you get it because the other renders are wrinkled looking and you usually flatten out wrinkles with an iron. So the board the iron165 would make the keycaps flat and it fits with the keyboard theme LMAOOO)
Offline DeMechanica
« Reply #94 on: Sat, 06 August 2022, 23:55:05 »
Putting aside the lack of permission, why do people like comic sans sets?
Offline q83n87
« Reply #95 on: Sun, 07 August 2022, 09:35:09 »
alps please
Offline treeleaf64
    • treeleaf64
« Reply #96 on: Sun, 07 August 2022, 14:47:54 »
This is not Comic sans   This is the treeleaf
Everyone must pay the cat tax
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #97 on: Sun, 07 August 2022, 15:11:51 »
This was a set that originally ran in 2013. There hasn't been a proper cylindrical rerun, so Hali and I are doing that. This one has the addition of Icon + Text mods, 10u, and cool center-stepped keys.
What about KAT Hyperfuse which ran in 2020? - https://geekhack.org/index.php?topic=107175.0
Offline Zanhana
« Reply #98 on: Sun, 07 August 2022, 15:45:27 »
>KAT
>cylindrical
Offline linell
« Reply #99 on: Sun, 07 August 2022, 21:54:36 »
>:D
bro this a **** set, just be thankful you even getting 1 base running fr
