Author Topic: [GB] Alish 40 - August 12th/September 5th  (Read 8318 times)
Offline NamesReed
  • 40 enjoyer, Cheapskate.
« on: Fri, 05 August 2022, 17:40:48 »
Alish 40 Group Buy.
Start date: 8/12/22
End date: 9/5/22
Kit Cost: 45$ With Pro-Micro, 37$ Without.
Product Page: https://mechwild.com/product/alish/
Discord Channel:  https://discord.gg/bJ7gBZSyJG
The Alish 40 is, as the name implies, is a 40% board with an Alice-ish layout.
This is a DIY Through-Hole, sandwich FR4 board with a bottom plate and an optional switch plate.
It features an optional rotary encoder beneath the left palm, RGB under glow, and a Pro-Micro footprint.
Estimated Fulfillment Date: 3-4 Months after GB Conclusion
There will be a build service available (Diode and Pro-Micro Soldering) for $20.
I have partnered with MechWild to make this possible.
They have a lot of experience in the DIY FR4 kit space and I'm extremely happy to be working with them.
I'm super excited for this board and I hope you guys are too!
« Last Edit: Mon, 08 August 2022, 11:34:48 by NamesReed »
IDK man, be positive, kind and caring.
Offline NamesReed
Re: [GB] Alish 40 - August 12th/September 5th
« Reply #1 on: Mon, 08 August 2022, 11:38:03 »
Reserving for updates and photos <3
Offline NamesReed
« Reply #2 on: Fri, 12 August 2022, 15:03:05 »
GB IS LIVE! <3
Offline NamesReed
« Reply #3 on: Fri, 02 September 2022, 13:39:28 »
Last few days, get one while you can. 💖
Offline Morbii
« Reply #4 on: Fri, 02 September 2022, 17:12:41 »
I’m new to the hobby and have been considering this and will likely go for it.
What’s the deal with the plate?  Is it in case I only have 3-pin switches or something?
Offline Morbii
« Reply #5 on: Fri, 09 December 2022, 10:59:45 »
Just got my shipping notification from MechWild!
