Author Topic: quick question  (Read 3433 times)
Offline PlayBox
quick question
« on: Sun, 07 August 2022, 17:13:02 »
planning on making a soldered keyboard into a hotswap one while also changing switches. which way of doing it is better change the switches the change to hotswap or make it hotswap then change the switches? i would prefer doing the 1st but if its not good im okay with the 2nd
propably sent from my amazon kindle 10th gen
Offline vincesatsong
    • Vince Satsong
Re: quick question
« Reply #1 on: Sun, 07 August 2022, 21:50:40 »
Not sure about what you're saying from the half. But for making the soldered PBC to Hot-swappable, use mill-max sockets
Sent from my XQ-AT52 using Tapatalk
Offline PlayBox
Re: quick question
« Reply #2 on: Mon, 08 August 2022, 04:25:11 »
yeahi know about the millmax sockets. im basically asking if desoldering switches will damage them so i wouldn't be able to use them back in a hotswap keyboard
Offline Leslieann
Re: quick question
« Reply #3 on: Mon, 08 August 2022, 10:21:09 »
Unless you have good desolder equipment, you will probably lose a few switches.
Note:
You shouldn't put desoldered switches into a hot swap socket, it can damage them.
Also mill max do NOT fit all boards, the holes need to be large enough and you also need to clean them out really well. If you have junk desoldering equipment, good luck doing it without damaging the pcb. There used to be a database of pcbs could fit them, not sure if it still exists or if your pcb is listed even then.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline PlayBox
Re: quick question
« Reply #4 on: Mon, 08 August 2022, 11:52:16 »
ok so ill do the mill max first option.
i think i have decent desoldering equipment at home maybe not desolderiing gun but still decent
