Author Topic: [IC] GMK Euler Group Buy will live on December 28, 2022  (Read 37220 times)
Offline iamtienng
« on: Sat, 13 August 2022, 06:42:20 »
GMK Euler
“Die Mathematik ist es, die uns vor dem Trug der Sinne schützt und uns den Unterschied zwischen Schein und Wahrheit kennen lehrt.” ― Leonhard Euler
Group Buy will live on December 28, 2022.
Group Buy Thread Here.
Contact
Email: iamtienng@gmail.com
Instagram: @iamtienng
Discord: iamtienng#3485
Special Thank
Oblotzky for letting me use Cadet Sublegends.
Zaum for helping me improve Render Quality and letting me use Werk One for Rendering.
Flex for your FLX Virgo Render File.
Geon for your F2-84 Render File.
Everyone show the support to this project. I can not finish it without you.
Everyone submit Interest Check form, I read all of them and I truly appreciate it.
I know there are many things I can not do at this round, I will try my best if it can has another round.
Color
Inspiration from the colors on the chalkboard.
Color Comparison
Colorways
Kits
Click for larger images
[Base Kit]
About Cadet Sublegends: I got approval to use Cadet Sublegends from Oblotzky.
Do Cadet Sublegends increase production costs? "the legends don't cost more to use no, as they've already been made" said Oblotzky.
Disclaimer: The Cadet Sublegends in Renders may not be the same as the actual product, the final product will be the same as GMK Space Cadet.
[Spacebars]
[Novelties]
Novelties are constituted by:
Euler's two most famous constants:
γ (gamma): Euler's constant (sometimes also called the Euler–Mascheroni constant), is defined as the limiting difference between the harmonic series and the natural logarithm.
e: Euler's number, is a mathematical constant approximately equal to 2.71828 which can be characterized in many ways. It is the base of the natural logarithms.
Euler’s Identity: 'The Most Beautiful Equation'.
Euler characteristic: is a topological invariant, a number that describes a topological space's shape or structure regardless of the way it is bent. The polyhedra in novelties are: Icosahedron, Tetrahedron, Hexahedron, Octahedron, Dodecahedron.
HIBI
GMK Euler & HIBI — Icosahedron
Finish                  Icosahedron            Profile          Size
Black AnodizingGray AnodizingR11u
Deskmat
Mathematik
Renders
There will be more renders.
FLX Virgo by Flex
Werk One by Zaum
F2-84 by Geon
Vendors
US: Captus Keycaps
UK: Proto[Typist]
OCE: Daily Clack
Canada: DESK[H]ERO
Asia: kibou
Korea: Swagkeys
China: zFrontier
EU: MyKeyboard.eu
Timeline
GB: December 28, 2022 to January 28, 2023
Price
TBD
Collaborations
GMK Euler & 15Cables
Based on GMK Euler colorway and novel design, we created these matching custom cables.
More Photos
More Detail
The collection has 3 option choices: a coiled cable, a straight cable, and a braid cable
- Coiled cable: Double sleeved with paracord&techflex, 7in coil, 4ft host side length, GX16 laser engraved connector, heatshrinked type A and C plug. The coil is tight, springy by using heat treatment and reversed-coil process.
- Straight cable: Double sleeved with paracord&techflex, 4in device side length, 4ft host side length, GX16 laser engraved connector, heatshinked type A and C plug.
- Braided cable: 4ft length, black FEMO connector, heatshrinked type A and C plug. Inspired by audio IEM cables, this cable has 100% braided by hand.
We use high quality signal wire <2x24awg + 2x28awg>, double shielded.
All joint are secured with hot glue and heatshrink. All guarantee your cable will be stable and long time lasting.
Price & Shipping Date
Price for each:
- Coiled cable: 40$
- Straight cable: 25$
- Braid cable: 50$
Shipping info:
- US&UK: 10$
- Others: 15$
Expected delivery: 3 months after closing GB.
The process will be updated on our Discord server.
15Cables Contacts & Discord
Artisan
TBD
To do
Pricing.
Start Group Buy.
Changelog
Changed the shape of Octahedron.
Changed the design of deskmat.
Changed colorway for a better look.
Kitting changed: Add accent color spacebars and a little in base kit.
Added Cadet Sublegends.
1.2:
Kitting changed: added R1 ~ ` and R2 1.5u \ | with mod color. Removed R3 1u Home.
Signature
Code: [Select]
[url=https://geekhack.org/index.php?topic=118090.0][img width=180 height=120]https://i.imgur.com/OCTYzvq.png[/img]
« Last Edit: Fri, 30 December 2022, 16:26:22 by iamtienng »
Offline Fraaaan
Re: [IC] GMK Euler
« Reply #1 on: Sat, 13 August 2022, 06:48:40 »
Color: Simulate colors on a chalkboard.
What does this mean and what are the colors?
Also consider an ISO novelty.
Offline iamtienng
Re: [IC] GMK Euler
« Reply #2 on: Sat, 13 August 2022, 06:59:56 »
I mean colours are inspired by a chalkboard like this:
I will publish colour after group-buy (if interest is high enough for GB).
For ISO novelty, I am trying to do it.
Thank you for your opinion.
Offline IOVERCALLHISTIOCYTES
Re: [IC] GMK Euler
« Reply #3 on: Sat, 13 August 2022, 08:26:49 »
Like the theme and the novs. GMK GBs are fickle things right now. If you don’t get the interest you want for the base kit, maybe consider taking the novs to CR black and ws1 white and making it an add on nov kit for WoB and vendors could sell along w a deskmat. Getting that kit to MOQ 100 might be doable.
Offline bigdonnerz
Re: [IC] GMK Euler
« Reply #4 on: Sat, 13 August 2022, 09:17:50 »
Looks nice but it's very similar to GMK Apollo and GMK Shashin. I'd be interested to see a comparison
Offline Keeblet_257
Re: [IC] GMK Euler
« Reply #5 on: Sat, 13 August 2022, 10:07:59 »
a clean set, but im not a big fan of the novelties personally
Offline iamtienng
Re: [IC] GMK Euler
« Reply #6 on: Sat, 13 August 2022, 10:29:09 »
Please look to color compare at the first of IC.
« Last Edit: Fri, 02 December 2022, 16:51:59 by iamtienng »
Offline iamtienng
Re: [IC] GMK Euler
« Reply #7 on: Sat, 13 August 2022, 10:39:34 »
Really appreciate your opinion, I will think about it carefully.
After today I will try to perfect it. I made this set months ago and the laziness has taken over me those days. Thank you for your opinion. <3
Offline nvh2092
Re: [IC] GMK Euler
« Reply #8 on: Sat, 13 August 2022, 12:22:27 »
I recommend adding accent bars and arrows to the bar kit, also re-echo this: please add novelties for ISO enter  :thumb:
Offline 4milk
Re: [IC] GMK Euler
« Reply #9 on: Sat, 13 August 2022, 16:02:21 »
Why keep the colors secret?
Offline //gainsborough
  • ALPSの日常
Re: [IC] GMK Euler
« Reply #10 on: Sat, 13 August 2022, 23:20:26 »
Ahhhh Euler.  The most mispronounced name for math undergrads everywhere.
I'm in!
Offline Cylent
  • Formerly cylentshadows
Re: [IC] GMK Euler
« Reply #11 on: Sun, 14 August 2022, 00:03:17 »
Your inspiration shows a classic deep green chalkboard but you went with 100% neutrals? Confusing. As others have pointed out, this is extremely close to GMK Apollo and GMK Shashin. Yes the colors are not exactly the same, but nothing about this set makes it stand out from the other 2 that have come before it. At least the kitting is decent, though you're missing mod tilde, and I don't understand the point of R3 1u Home.
I'll pass on this one. Best of luck.
Offline ankit
  • Formerly ankit-sachdeva
Re: [IC] GMK Euler
« Reply #12 on: Sun, 14 August 2022, 00:05:12 »
why 1.5u delete instead of backspace
collection:
  Daal, Emp Mini, HHKB x5, Horsey, Prophet, RS60, Seis Cero, Unikorn, Pixy Mini
Offline weekendkeyboard
Re: [IC] GMK Euler
« Reply #13 on: Sun, 14 August 2022, 09:50:26 »
I'm very interested. I hope this goes to GB!  :)
Offline akameyyy
Re: [IC] GMK Euler
« Reply #14 on: Sun, 14 August 2022, 11:13:05 »
Going with RAL 6028 (or some other chalkboard-ish green) as an alternative/primary alpha kit color would be very nice to see, otherwise love the theme.
GLWIC
Offline ManiacMarc
    • Twitch
Re: [IC] GMK Euler
« Reply #15 on: Sun, 14 August 2022, 13:36:53 »
Reserved. While it’s similar to Apollo, I think I like the slight color diff of this set themed after the chalkboard. I’m not a big fan of the novs, but I understand the theme you’re going for.
« Last Edit: Sun, 14 August 2022, 13:43:57 by ManiacMarc »
Offline dallman5
Re: [IC] GMK Euler
« Reply #16 on: Sun, 14 August 2022, 14:32:53 »
should use cadet legends or something, otherwise this is basically just dolch/apollo/etc and doesn't really evoke any famous Swiss mathematician influence
LF: OG Cherry APL (lasered), Artisans
Current collection:
Norbatouch (Galaxy Blue) | Mira SE (Lunar Grey, WKL) | HHKB Pro 1 (KB300BN) | Noxary X60 (Grey, HHKB) | KBDFans 5 Degree (Silver) | AEK64 (Grey) | Norbaforce (Tactical Black, WKL)) | Realforce 86U (White) | TGR 910 RE (Polycarbonate) | LZ-SQ (Black) | LZ-CLS (Grey, WKL) | Duck Orion v1 (Silver, WK)) | Nissho KB106DE | HHKB Pro 1 (KB300B) | LZ CLS-S (Blue, Poker) | Realforce 87U 10th Anniversary) | Realforce 104UK | TGR Alice (Grey on Pink) | Singa (Blue, WKL)  | Quantrik QXP (Blue Grey, WKL) | LZ-GH v2 (Black, WK) | KMAC Happy (Red, Poker)) | IBM Model M SSK (APL) | TGR 910 SE (Pink on Blue) | GSKT-00 (Silver, Poker) | OTD Koala (Silver, WKL) | Realforce R2 PFU Edition (Ivory) | IBM 3279 Beamspring (APL) | TGR Tris (Blue) | LZ-GH v2 (Blue, WKL)) | TGR Jane v2 (Blue-grey, WKL) | LZ-MP (Shine Grey, WKL)  | TGR x Singa Unikorn (Purple) | Justsystems x Realforce 108UG) | IBM Model F Unsaver (APL) | TGR Jane V2 CE (Multicolor, WKL) | Realforce 87U (Blank Black) | Lin Montage (Light Blue, WKL) | GSKT-00 AEK R2 (Grey, HHKB) | Leopold FC660C (Blank Black) | Duck Viper v3 (Grey on Black) | Rama Works M6-C RWxRW | LZ-GH v1 (Black, WKL) | Gok 7v (Grey) | biso x beaming Kei (SS, HHKB) | zacheadams x bisoromi little z | Matrix Noah (Silver/Grey, WKL) | Lin Whale (Pink, WKL) | TGR Alice (Polycarbonate) | Rama Kara (Noct) | Lin Whale75 (Burgundy, F13) | Realforce 89 (Ivory) | Hand Engineering Haus (Bluegrey) | Haytco CAKE60_R1 (Pantone 4167C) | LZ-XE (Grey, WKL) | Noxary X60 V2 (Grey, WK) | Daji Ochocuatro (Grey, WKL) | HHKB Hybird Type-S 25th Anniversary (Snow) | LZ-REs (Grey, WKL) | Matrix 8xv 3.0 (Blue-Black/Deep Grey, WKL) | Realforce 23UB | Biso RS60 (Black, WK) | TGR x MXF Koala (Grey/Black, WKL)
Italics = Incoming, Black = Gone
Offline xjack312
Re: [IC] GMK Euler
« Reply #17 on: Sun, 14 August 2022, 17:02:42 »
Really like the theme behind this set, I think sublegends could be interesting to look into as well. Also another vote for 1.5u backspace
Alice enjoyer
Offline CHAOSERA
    • official website of chaosera
Re: [IC] GMK Euler
« Reply #18 on: Sun, 14 August 2022, 20:18:41 »
This is to my liking and I will buy a set.
Offline Tyson
Re: [IC] GMK Euler
« Reply #19 on: Mon, 15 August 2022, 11:18:28 »
I agree with others in the thread, if your inspiration is a chalkboard you should look into using a dark green chalkboard color for the alphas. It would make the set different from the current dolch/apollo/etc look.
Offline WaynaPawiasek
Re: [IC] GMK Euler
« Reply #20 on: Mon, 15 August 2022, 12:19:27 »
why is it not green
Offline VXQN
Re: [IC] GMK Euler
« Reply #21 on: Tue, 16 August 2022, 04:13:25 »
Octahedron angle looks a little off compared to the others.
Offline iamtienng
Re: [IC] GMK Euler
« Reply #22 on: Wed, 17 August 2022, 02:40:34 »
I will think about it. Thank you so much.
Because I could use GMK stock color instead of custom color so it's not the final color, but it would be similar.
I'm in!
In my country, we even called him \ə'le\  in the past :)
I will checkout on the R3 1u Home. Thank you so much.
Because 1.5u Delete/Backspace is usually uses in HHKB layout, and the OG HHKB has Delete instead of Backspace.
Offline iamtienng
Re: [IC] GMK Euler
« Reply #23 on: Wed, 17 August 2022, 02:44:22 »
Thank you so much.
GLWIC
I will look at it, thank you so much.
Thank you so much.
I'm working on Cadet Sub-Legends. I could do more but I would like to get it to GB for R1 first.
Thank you so much, I will look at it.
Offline iamtienng
Re: [IC] GMK Euler
« Reply #24 on: Wed, 17 August 2022, 02:47:28 »
Thank you so much.
why is it not green
Maybe I took a wrong example image. Where I live since I was a kid, chalkboards usually have a black background and white chalk.
Yes I see it too, will look at it now.
Offline milka158
Re: [IC] GMK Euler
« Reply #25 on: Thu, 18 August 2022, 16:05:50 »
Speaking of sublegends, considering the sets inspiration, "cadet" sublegends are the way to go
Novelties are very underwhelming imo
Offline Starston3
Re: [IC] GMK Euler
« Reply #26 on: Thu, 18 August 2022, 16:13:55 »
I second this, or ascii
Offline iamtienng
Re: [IC] GMK Euler now with Cadet Sublegend (Oblotzky approved)
« Reply #27 on: Sat, 20 August 2022, 21:53:09 »
Please look for color comparison at the first of IC.
« Last Edit: Fri, 02 December 2022, 16:52:40 by iamtienng »
Offline xjack312
« Reply #28 on: Sat, 20 August 2022, 22:37:04 »
oh yeah this is much better, definitely in
Alice enjoyer
Offline eulers
« Reply #29 on: Sun, 21 August 2022, 01:06:52 »
Considering the fact that I have Euler's identity tatted on me, I'm gonna need to buy this set.
Offline Magnificent Bureaucrat
  • Sooooo much red tape
« Reply #30 on: Sun, 21 August 2022, 01:27:56 »
Have you considered including <> instead of cursed double \ for iso coverage?
Offline milka158
« Reply #31 on: Sun, 21 August 2022, 01:30:17 »
Please list the exact colors you are using
Offline Omnias
Re: [IC] GMK Euler
« Reply #32 on: Sun, 21 August 2022, 03:02:24 »
I would love a deskmat that has denser writing like that sample image, the current deskmat design is neat but a little sparse for my taste
Offline nostr
« Reply #33 on: Sun, 21 August 2022, 05:24:39 »
I simp symbols. In for 2 if it runs
Offline Fraaaan
« Reply #34 on: Sun, 21 August 2022, 06:03:19 »
This. If you want to do terminal ISO (basic support) there should be a r4 <>, not 2 pipes. Check GMK Classic Retro Zhuyin if you're unsure how to kit terminal ISO.
Also consider adding navigation sublegend to the numpad. It looks a bit empty in contrast to the busy alphas.
Offline iamtienng
« Reply #35 on: Sun, 21 August 2022, 07:53:05 »
Fixed R4 / | with R4 < >.
For the numpad, I would like to keep it for my aesthetic.
Offline nvh2092
« Reply #36 on: Sun, 21 August 2022, 10:54:04 »
I also suggest adding mod color keys for R1 tilde and R2 pipe too. These are very important for aesthetic in some layouts. Hope you consider adding them. About the new renders, are those N9 and CR? They look a lot like them, however the alpha color is not N9 like Shashin in the comparison you make. I would love to see some deep green for board color  :thumb:
« Reply #37 on: Sun, 21 August 2022, 18:50:42 »
normally not a huge fan of sets with subs but cadet subs actually make this set amazing, will buy when it gets to GB
QFR | MJ2 TKL | "Bulgogiboard" (Keycon 104) | ctrl.alt x GON 60% | TGR Alice | Mira SE #29 | Mira SE #34 | Revo One | z | Keycult No. 1 | AIS65 | First CW87 prototype | Mech27v1 | Camp C225 | Duck Orion V1 | LZ CLS sxh | Geon Frog TKL | Hiney TKL One | Geon Glare TKL
Offline Nuap
« Reply #38 on: Sun, 21 August 2022, 19:47:34 »
The addition of cadet sublegends has made this a lot more appealing. Good one.
Offline Seunghyun Lee
« Reply #39 on: Sun, 21 August 2022, 23:29:02 »
cadet reserved.
Offline DeMechanica
« Reply #40 on: Mon, 22 August 2022, 03:57:13 »
I haven’t loved cadet before, but on this it’s just gorgeous
Offline wxstc
« Reply #41 on: Mon, 22 August 2022, 04:23:53 »
I'm sold!
« Reply #42 on: Mon, 22 August 2022, 10:05:37 »
also can you make a comparison image w dolch
maybe you did and i just missed it?
Offline mr_foggy
  • land of the worst vendor(s)
« Reply #43 on: Mon, 22 August 2022, 18:33:42 »
yes
Offline ankit
« Reply #44 on: Mon, 22 August 2022, 19:16:24 »
so so so so much better  :thumb:
collection:
Offline iamtienng
« Reply #45 on: Tue, 23 August 2022, 04:26:17 »
Hi there, I updated the post with some color comparison. Hope that you find it's useful.
Offline iamtienng
« Reply #46 on: Tue, 23 August 2022, 04:29:17 »
Pretty sad I probably won't be able to do this at R1 to save on production costs. Thank you very much for your opinion.
Offline Cylent
« Reply #47 on: Tue, 23 August 2022, 06:02:27 »
Includes R3 1u home for some unknown reason but won't include standard keys like mod pipe and mod tilde to save production costs. Makes sense.
I also wanted to point out the obvious dodging on all the people saying that a dark green fits your inspiration much better.
Re: [IC] GMK Euler (now with Color Comparison)
« Reply #48 on: Tue, 23 August 2022, 06:10:38 »
The color comparison GMK Nord is as good a guess as what we’ll get as any out there
Love the work you’re putting in. The alphas being darker than N9 are gonna be real dark in non-sunlight and I’m looking forward to it.
Offline LXVRGS
« Reply #49 on: Tue, 23 August 2022, 08:43:05 »
adding mod tile and pipe are not going to bump the price up exponentially dont be that guy
