Author Topic: [IC] GMK Densus | Updated Kitting  (Read 28265 times)
Offline densus designs
  • * St. Jude Supporter
Re: [IC] GMK Densus | updated kitting
« Reply #50 on: Thu, 08 December 2022, 09:04:12 »
Kitting has been updated again,
will be looking into vendors soon
Re: [IC] GMK Densus | Updated Kitting
« Reply #51 on: Thu, 08 December 2022, 09:06:35 »
Any target when this will run?
Currently no target, hoping for sometimes in 2023
I like this very much. I got Dolch R5 because I wanted to try R5 but hated its colours in the end, so I think this might give me what that couldn't.
Please consider an accent colours add-on kit. I get only wanting to have one kit and I think that's wise to avoid a queue clogger situation. I just think that it might really help this look more glamorous and potentially appeal to a few more people.
Thank you for the support, I'm not one for accents and think that this set doesn't need it.
Offline whirlwind
« Reply #52 on: Thu, 08 December 2022, 09:49:27 »
Impressive, very based
Offline aicyborg
« Reply #53 on: Sat, 10 December 2022, 00:11:09 »
Did you mess up the renders or has ISO-UK support been half-removed? If it's been removed intentionally, your terminal ISO support is wrong - the R3 @ and tilde are UK-specific. Terminal ISO is R3 pipe and R4 <>. But please reconsider your decision to remove ISO-UK because then I'd be out and sad.
Offline mamahuhu
« Reply #54 on: Sat, 07 January 2023, 06:50:26 »
Cope!
If you can add a stepped Control in R3, it would be nice :)
