Author Topic: [IC] Vessel Artisan Display by Nyhxis - New Mini Vessel Prototypes  (Read 4057 times)
Offline Xonuss
Vessel
by Nyhxis
Artisan Display
290323-0
IC Form
Full Render Gallery
Prototype Gallery
Updates
03/10/2022
Prototypes for the Mini Vessel have arrived, with a few update compared to the style of the original Vessel prototype:
- Increased angle for better view.
- Made the walls between the caps thinner.
- Decreased the depth of the slots. This is both to make caps more visible but also to make shorter artisans easier to pick up.
- Updated back design to include just the Nyhxis logo. This was the preferred back design from the form.
- Updated feet design to include the custom angled rubber feet.
All of these design changes will also apply to other versions aswell.
291977-1291979-2
291981-3291983-4
291985-5291987-6
Colors are not chosen to be part initial sales, but feel free to share your thoughts. May reshoot imagines for better quality at a later time.
Initial Prototype
290325-7
290327-8290329-9
290331-10290333-11
The Case
The primary version is the Vessel, a 5x4 slot display case made from CNC milled 6063 aluminum, with stem holders to keep your artisans centered and presentable:
290335-12
290374-13
290376-14290361-15
290363-16290365-17
Edit: Initially the bottom featured full branding on the bottom, but comments was made on this, so decided to include different kinds of bottom renders. Branding was part of the prototype, so decided to leave it in the initial render. Leave your opinion on this in the IC form.
Other than the Vessel, I've also worked on two other variants, the Mini Vessel and the Container Vessel.
The Mini Vessel is a 4x3 slot display with the same design language as the Vessel:
290337-18
290367-19
290369-20290371-21
The Container Vessel has the same 5x4 slot footprint of the Vessel, but features high walls and a transparent lid for more permanent storage:
290339-22
*Early render, still work in progress.
Possible Color Variants
Blue
290335-23290337-24
Red
290341-25290343-26
Green
290345-27290347-28
White
290349-29290351-30
Gray
290353-31290355-32
Black
290357-33290359-34
Price
*Prices are still TBD, but these are expected prices.
Vessel is expected to be at most $100/€100.
Mini Vessel should slightly less than the Vessel.
Container Vessel could cost a fair bit more than the Vessel, but I dare not say how much at this time.
Thank you for checking out this IC!
Discord
Do please consider adding this signature to your profile
297451-35
Code: [Select]
[url=https://geekhack.org/index.php?topic=118122][img]https://i.imgur.com/SUv0lzt.png[/img][/url]
« Last Edit: Mon, 13 March 2023, 16:24:36 by Xonuss »
Offline Xonuss
Re: [IC] Vessel Artisan Display by Nyhxis
« Reply #1 on: Wed, 17 August 2022, 14:16:31 »
Reserved
Offline Cujo26
« Reply #2 on: Wed, 17 August 2022, 14:41:18 »
Gawjus my little Xonnie! If I was into artisans, I'd definitely go for this!
Please help I am trapped in your computing device
[url=https://geekhack.org/index.php?topic=112457.0]
Offline clickpig
  • naisu naisu naisu
« Reply #3 on: Wed, 17 August 2022, 18:00:56 »
*chefs kiss*
Offline Xonuss
« Reply #4 on: Mon, 03 October 2022, 15:41:40 »
The first Mini Vessel prototypes has arrived and I think they look great! Check them out in the Updates section in the original post. Would love to know what you think :D
Offline hiddensong
  • this too shall pass
Re: [IC] Vessel Artisan Display by Nyhxis - New Mini Vessel Prototypes
« Reply #5 on: Tue, 04 October 2022, 02:04:57 »
I’d like to see an updated high wall design. The box is confusing. If it’s not what the final product will look like, maybe remove it as many people don’t read, but only look at the pics. Samples look delish!
