Author Topic: KEYCAP MANUFACTURERS list (Last update: 03 January 2023)  (Read 89686 times)
Offline 1pctipaday
  • The show must go on
« on: Sun, 21 August 2022, 07:37:05 »
Hello everyone!
I have created the following list with all the keycap (keysets, not artisans) manufacturers I know:
MANUFACTURER  |  MATERIAL(S)  |  MAIN PROD. METHOD(S)  |  MAIN PROFILE(S)  |  PRICING ($-$$$$|  QUALITY1        *NOTES
1 Basic < Not bad < Good < Very good < Top tier
2 Yellow color means "Lack of information / Possible known mistake"
AIFEI / GLIGING / SUMGSN / VENIT KEYS / YONG-QIU    ABS / PBT    Doubleshot / Dye-sub & Reverse dye-sub    Cherry, SA    $    Basic        *Clones
AKKO-EPOMAKER    PBT / PC    Doubleshot / Dye-sub & Reverse dye-sub / UV print    ASA, Cherry, OEM, OSA    $$    Not bad
ALL.CAPS    PBT    Dye-sub    Cherry    $$$    Good
ANGRY MIAO    PBT / PC    Dye-sub / Laser etched-engraving    Unique-Unknown    $$$    Good
BSP EUROPE (BSP)    PBT    Dye-sub    Cherry    $$$    Good
CANNONCAPS    PBT    Dye-sub & Reverse dye-sub    Cherry    $$$    Very good        *Property of CANNONKEYS
OG CHERRY    ABS / PBT / POM    Doubleshot / Dye-sub / Laser etched-engraving / UV print   Cherry    $$$$    Top tier        *Only found in vintage keyboards sold in second-hand market
CONTRAKEY    PBT    Dye-sub    Cherry    $$    Good
CREATEKEEBS a.k.a. ESC.HIT    ABS-PBT    Dye-sub & Reverse dye-sub    Cherry    $$-$$$    Good        *Cooperating with ALOHAKB
DEADLINE STUDIO (DEADLINE)    PC    Laser etched-engraving    Cherry    $$$    Good
DOMIKEY (DMK)    ABS / PBT   Doubleshot & Tripleshot / Dye-sub   Cherry, SA    $$$$    Top tier
DROP (Artifact Bloom Series, DCX & MT3)    ABS / PBT    Doubleshot / Dye-sub & Reverse dye-sub    Cherry, MT3    $$-$$$    Very good
DUCKY    PBT    Doubleshot    OEM    $$    Not bad
ENJOY PBT (ePBT)    ABS / PBT    Doubleshot / Dye-sub & Reverse dye-sub    Cherry    $$$-$$$$    Very good
GEEKARK    PBT    Dye-sub & Reverse dye-sub    Cherry    $$$    Very good
GLORIOUS (GPBT)    PBT    Dye-sub & Reverse dye-sub    Cherry    $$    Good
GLOVE    PBT    Pad print & UV coat    WDA    $$$$    Good
GMK-UNIQEY    ABS    Doubleshot / UV print    Cherry    $$$$    Top tier        *Owner of the original CHERRY molds
HAMMERWORKS CRP    PBT    Dye-sub & Reverse dye-sub    Cherry    $$$    Top tier
HK GAMING    PBT    Dye-sub    Cherry    $    Basic
IDOBAO    PBT    Dye-sub & Reverse dye-sub    Cherry, MA, OEM    $-$$    Not bad
INFINIKEY (IFK)    PBT    Dye-sub & Reverse dye-sub    Cherry    $$$    Very good        *Property of THE KEY COMPANY
IV WORKS    PBT    Dye-sub & Reverse dye-sub    Cherry    $$$    Very good
JKDK    PBT    Dye-sub & Reverse dye-sub    Cherry    $$    Good        *AliExpress legit/original manufacturer?
JT KEYCAPS (JTK)    ABS    Doubleshot & Tripleshot    Cherry    $$$$    Top tier
KBDFans    PBT    Dye-sub & Reverse dye-sub / Laser etched-engraving    Cherry, DSA    $-$$    Good
KEEBMONKEY    PBT    Dye-sub & Reverse dye-sub    Cherry    $$-$$$    Good
KEYBEE (KBM)    PBT    Dye-sub & Reverse dye-sub    Cherry    $$$    Very good
KEYCHRON    PBT    Doubleshot / Dye-sub & Reverse dye-sub    Cherry, OEM, OSA    $-$$    Not bad
KEYKOBO (KK)    ABS    Doubleshot    Cherry    $$$    Very good
KEYREATIVE    PBT    Doubleshot / Dye-sub & Reverse dye-sub    KAM, KAT    $$$    Very good
KINETIC LABS    PBT    Doubleshot / Dye-sub    Cherry    $$$    Good
KONO DESIGNER SERIES (KDS)    PBT    Dye-sub & Reverse dye-sub    Cherry    $$$    Very good
KPREPUBLIC    PBT    Doubleshot / Dye-sub    Cherry, CSA    $-$$    Good
LELELAB    ABS    Unknown    Unknown    $$    Good
LEOPOLD    PBT    Doubleshot    OEM    $$    Not bad
MAX KEYBOARDS (MX)    ABS / PC    Laser etched-engraving / UV print    OEM    $$    Basic        *Can produce individual custom keysets
MAXKEY    PBT    Doubleshot / Dye-sub & Reverse dye-sub    SA    $$-$$$    Good
MELGEEK (MG)    ABS / PBT    Doubleshot / Dye-sub    MDA, MG    $$$    Very good
MILKYWAY KEYS (MW)    PBT    Doubleshot / Dye-sub & Reverse dye-sub    Cherry    $$$$    Top tier
MODE DESIGNS (MODE)    ABS    Doubleshot    Cherry    $$$    Good
MONOKEI    PBT    Doubleshot    Cherry    $$$    Very good
MONSTARGEAR    ABS / PBT    Doubleshot / Dye-sub    Cherry, MG, OEM    $-$$$    Good
"MVKB (MV)"    PBT    Dye-sub & Reverse dye-sub    Cherry    $$$    Very good        *According to designer, Max Voltar, MV means "Sets produced by a variety of factories that have been approved by him"
NicePBT    PBT    Dye-sub & Reverse dye-sub / Laser etched-engraving    Cherry, DSA    $$$    Very good        *Property of CANNONKEYS
NOVELKEYS (NK)    PBT    Dye-sub & Reverse dye-sub    Cherry, DSA    $$$    Very good
NUPHY    PC+ABS / PBT    Doubleshot    Cherry-like, Low profile    $    Good
OMNITYPE (OTC)    PBT    Dye-sub & Reverse dye-sub    Cherry    $$$    Good
OSUMEKEYS (OSUME)    PBT    Dye-sub & Reverse dye-sub    Cherry    $$$    Good
PBTFans    ABS / PBT    Doubleshot & Tripleshot / UV print    Cherry    $$$    Top tier        *Property of KBDFans
PG    PBT    Dye-sub & Reverse dye-sub    NP/PG    $$    Not bad
QUALITY PBT (qPBT)    PBT    Dye-sub & Reverse dye-sub    Cherry    $$    Not bad
RAMA WORKS (RW)    PC    Doubleshot    Unique    $$$$    Very good
SHENPO    PBT    Dye-sub    Cherry    $    Good
SHURIKEY    ABS    Doubleshot    Cherry    $$    Good
SIGNATURE PLASTICS (SP)-PIMP MY KEYBOARD    ABS / PBT    Doubleshot / Dye-sub & Reverse dye-sub    DCS, DSA, DSS, SA    $$$$    Top tier        *Include Comptec keycaps
SwagKeys (SW)    PBT    Doubleshot    Cherry    $$$    Good
TAI-HAO    ABS / PBT    Doubleshot    Bobo (unique), OEM    $$    Not bad
TEACAPS (TeaPBT)    PBT    Dye-sub & Reverse dye-sub    Cherry    $$-$$$    Good
TECSEE    PBT    Doubleshot    Cherry    $$    Not bad
TEX ELECTRONICS (TEX)    ABS    Laser etched-engraving    TEX ADA    $    Not bad
TOMATOCAPS (TMT)    PBT    Dye-sub & Reverse dye-sub    Cherry    $$$    Good        *Partnering with zFRONTIER
TOMO CAPS (TOMO)    PBT    Dye-sub & Reverse dye-sub    Cherry    $$$    Very good
TRAITORS    PBT    Dye-sub & Reverse dye-sub    Cherry    $$    Not bad
VARMILO    PBT    Dye-sub & Reverse dye-sub    OEM    $$    Not bad
VORTEX KEYBOARD (VTK)    PBT / PBT-POM    Doubleshot / Dye-sub    OEM    $    Not bad        *Also known as VORTEXGEAR or simply VORTEX
WASD    ABS    UV coat    OEM    $$    Basic        *Can produce individual custom keysets
WINMX    PBT    Doubleshot / Dye-sub & Reverse dye-sub    Cherry, OSA, SA    $-$$    Good
WORK LOUDER (wrk.)    ABS / PC    Laser etched-engraving    Low profile Kaihl choc    $$$    Good
WuquePBT (WS)    PBT    Doubleshot / Dye-sub & Reverse dye-sub    Cherry    $$$    Good
YMDK    ABS / PBT    Dye-sub & Reverse dye-sub / Laser etched-engraving    Cherry, DSA, OEM, XDA    $    Basic
XIAMI (XMI)-21KB    PBT    Dye-sub    Cherry    $$$    Very good
Last update (03 January 2023): OG CHERRY, DMK and ePBT modified, SW added.
Data are based on public info, since obviously I have not tested a set from all of them. There can be mistakes; so please, feel free to give me feedback to amend them.
It is an open and editable list. My idea is that people can fulfill gaps, giving their "most objective" opinion, in such a way that The Community can maintain the list updated.
PD: It is not my aim to create a "fandom war" among people. The main goal of this list is giving a quick consulting guide to designers, customers and enthusiasts in general who look for basic information about keycap manufacturers.
« Last Edit: Fri, 13 January 2023, 06:54:10 by 1pctipaday »
Offline Fraaaan
Re: KEYCAP MANUFACTURERS list
« Reply #1 on: Sun, 21 August 2022, 08:06:30 »
Looks like the start of something cool.
Firstly for the price and quality columns I'd go with a more legible rating like x/10. Counting the symbols isn't very intuitive. Also I would suggest locking the document to avoid trolls and make adjustments yourself after collecting feedback.
At a quick glance I noticed some things that need to be fixed. Signature plastics has DCS in the name for some reason, it says they do doubleshot only but their PBT is dyesub, and the profiles are wrong; SP doesn't do Cherry profile, they do DSA, DSS, DCS, SA and G20. AFAIK Xiami doesn't do reverse dyesub, Tai-Hao does ABS as well as PBT, I am not aware of JTK doing dyesub PBT but I know for sure they do doubleshot/tripleshot ABS which is missing, PBT fans does doubleshot ABS as well as PBT, Keykobo does doubleshot ABS and there's reverse dyesub missing from GPBT.
Blacksimon did a keycap tier list stream if you want to check that out for a point of reference.
Good luck with the project!
Offline 1pctipaday
« Reply #2 on: Sun, 21 August 2022, 09:45:43 »
Thanks for the feedback! I've deleted the original link to an open document and included all the info here to a faster and easier consultation.
« Last Edit: Sun, 21 August 2022, 09:48:33 by 1pctipaday »
Offline TyPo.mk
« Reply #3 on: Mon, 22 August 2022, 08:09:12 »
A lot of these are keycaps from the same factory just rebranded. It’s actually pretty funny you have the same manufacturer listed twice, once as “top-tier” and once as “not bad”, the only difference being the price and legends
Offline 1pctipaday
« Reply #4 on: Mon, 22 August 2022, 09:02:52 »
I'm sure of that you read there can be mistakes and the necessity of feedback. I do know there must be mistakes, since I found some "interesting" duplicities when looking for particular keysets.
That's why, as it is an OPEN and EDITABLE list, IMO it would be more constructive sharing your knowledge with everyone and making me able to amend these funny mistakes (even those less funny ones).
TIA :thumb:
« Last Edit: Mon, 22 August 2022, 09:14:50 by 1pctipaday »
Offline TyPo.mk
« Reply #5 on: Wed, 24 August 2022, 20:39:29 »
TIA :thumb:
Sorry I didn’t mean funny as I’m laughing at you, more funny as in interesting how the community perceives products
Offline 1pctipaday
« Reply #6 on: Thu, 25 August 2022, 10:23:07 »
No problem!
I will consider all the extra info you have and modify the current list.
TIA :thumb:
« Last Edit: Fri, 26 August 2022, 06:09:45 by 1pctipaday »
Offline vhaarr
Re: KEYCAP MANUFACTURERS list (last update: 26 August 2022)
« Reply #7 on: Sun, 28 August 2022, 11:36:36 »
Thank you for starting this list. Great initiative!
Let the Holy Handgrenades rain.
Hammering on an old Happy Hacking Pro 2. Still going strong!
Offline 1pctipaday
« Reply #8 on: Sun, 28 August 2022, 11:55:36 »
You're welcome!
I arrived at a point that I needed to get all this info out of my head, for healthy reasons mainly haha :eek:
« Last Edit: Sun, 28 August 2022, 14:20:34 by 1pctipaday »
Offline 1pctipaday
Re: KEYCAP MANUFACTURERS list (Last update: 03 January 2023)
« Reply #9 on: Tue, 03 January 2023, 05:51:43 »
Happy new year to everyone!!
Offline koe
« Reply #10 on: Sat, 27 May 2023, 06:20:20 »
Milkyways quality needs to be lowered. Recent sets have QC issues. https://www.reddit.com/r/MechanicalKeyboards/comments/y00kyw/milkyway_recent_string_of_extremely_poor_qc/
I have MW Demon Girl and can confirm scratching and oil issues.
Offline Aregs Keyboard
« Reply #11 on: Wed, 31 May 2023, 12:14:30 »
They are very detailed and comprehensive! Very useful for me, thank you very much, you are my hero haha
Offline Aquarius
« Reply #12 on: Fri, 09 June 2023, 04:36:01 »
The list is very useful for me! because i'm a new keycap designer. :thumb:
Offline krautcat
  • local the flammable man without identity
« Reply #13 on: Thu, 26 October 2023, 19:07:18 »
Thank you for your work. I really find it useful.
Do you consider adding Devlin?
Offline spongebobss
« Reply #14 on: Mon, 15 January 2024, 03:04:42 »
Introducing Oshid Precision Intelligent Manufacturing Technology Co., Ltd!
Founded in January 2005, as a leading force in precision manufacturing. (Is really a manufacturer!)
OSHID is a prominent supplier for many mainstream peripheral brands. Initially focused on mold manufacturing, it delved into the peripheral molding accessories industry in 2014. The factory’s product range includes keycaps, keyboard upper and lower covers, mouse shells, etc., with a primary emphasis on double-shot injection molding in its manufacturing processes.
The keycap processes include PBT and ABS double-shot injection molding, PBT and ABS single-shot injection molding, pad printing, PBT dye-sublimation, and resin keycaps, available in different profiles.
Offline dvorcol
  • Discord: dvorcol_5071
Offline Fede_Feo
« Reply #16 on: Mon, 08 June 2026, 05:27:47 »
Thank you, I didnt know this exisited and upto date.
Thanks
Offline dvorcol
« Reply #17 on: Mon, 08 June 2026, 14:34:02 »
Thanks
Actually, KeycapLendar is much better source. Its filter is pretty comprehensive. To get links your best bet is to filter Previous Sets for only the vendor(s) you're looking for.
https://keycaplendar.firebaseapp.com/previous
