Author Topic: IBM Model M 1996 with Teensy2.0++  (Read 9120 times)
Offline fer2d2
« on: Tue, 23 August 2022, 06:51:57 »
Hello!
I have an IBM Model M with part number 1391405.
Instead of having two ribbons, it has only one attached to a PS2 controller.
Here are some pictures:
I would like to replace the PS2 connector with a USB, and I also wanted to put a board with a Teensy2.0++ and flash QMK firmware to remap some keys and have multiple layers.
I have seen many projects for IBM keyboards with two ribbons, but none for this keyboard.
I would like to know if someone can help me. I would like to know:
- Which pins of the ribbon represent rows and which represent columns of the matrix.
- This keyboard has 25 pins, when in those with two ribbons there are usually 16x8 (24 pins in total). What is the pin number 25 for?
Thanks in advance.
Offline Tactile
Re: IBM Model M 1996 with Teensy2.0++
« Reply #1 on: Tue, 23 August 2022, 07:36:24 »
If the controller is working there is no need to replace it. You only need to convert the controller PS/2 output (that white connector on the board) to USB. As an added bonus you only need to work with 4 wires instead of the whole matrix.
Here's one way to convert, or you could go with this solution.
REΛLFORCE
Offline fer2d2
« Reply #2 on: Fri, 26 August 2022, 05:29:30 »
Hi!
Thank you very much for your response. I was able to use teensy with the TMK Firmware.
This is the result:
Cheers!
Offline Tactile
« Reply #3 on: Fri, 26 August 2022, 06:54:23 »
XLNT!  :thumb:
Great job!
REΛLFORCE
Offline Slywanin
  • Abdul Lutfi is my name.
« Reply #4 on: Fri, 30 December 2022, 12:16:42 »
why......
It's so pure. & you desecrated it but cutting it open.....
 :D
Offline TomahawkLabs
« Reply #5 on: Tue, 03 January 2023, 19:35:34 »
Where did you find your Teensy? I just used my last one and I want one more, but cannot find any.
Always looking for Alps SKCM/SKCL switches. Feel free to DM.
AMD 5600x | RTX3080 | 2x 1TB NVME + 4x 4TB HDD | B550M Pro-P | 32GB RAM | RM850x | Node 804 | Schiit Modius/Magnius + Audeze LCD-2 | 2x Dell S3422DWG
GMMK 1 Full Size Barebones | Zealio 67g ; Apple M3501 handwired | Alps SKCM Damped Cream
SA: Camping
« Reply #6 on: Tue, 03 January 2023, 21:26:51 »
Go to the source :
https://www.pjrc.com/teensy/
Presumably "Out of Stock" is temporary.
"Starting in 2011, the deficits again started to shrink. During Obama’s term  the deficit was reduced by $900 Billion  before finally in 2015 the GOP managed to wrangle a “reconciliation” bill out of Obama where he again cut corporate taxes, as well as made permanent some of George W. Bush’s original tax cuts. This is the year everything reversed. Before this, under Clinton, Bush and Obama the deficit in almost every year was gradually decreasing. The balance we had of taxes and the economy was bringing the deficit down, the money coming in was slowly catching up with the money going out until 2015. Trump’s subsequent tax cut has continued the new trend even after the rest of Bush’s cuts have since expired. Obama had an average GDP of 2.3%, with 11.6 million jobs created and unemployment peaking at 10% in 2009, then falling to 4.3% in 2016. If we had continued on that downward deficit track, we would have again reached balance and another surplus in 2017-2018.
– Frank V Walton 2025-07-01
« Reply #7 on: Wed, 04 January 2023, 19:30:36 »
Those have been out of stock for almost 2 years. There was some b stock a while back. It’s deprecated hardware. Just hoping to find a second one for another project.
SA: Camping
« Reply #8 on: Thu, 05 January 2023, 08:18:12 »
That is most unfortunate. I have a few more "projects" that I was planning to use them in ....
« Reply #9 on: Thu, 05 January 2023, 21:07:52 »
Guess I will just have to learn how to design a RP2040 board and MicroPy.
SA: Camping
Offline Maledicted
« Reply #10 on: Sat, 07 January 2023, 16:11:22 »
Do you need the extra pins, or can you just use a Pro Micro? RP2040 is even cheaper than Pro Micros at this point anyway though.
