Author Topic: [IC] KBM Bioluminescent | GB Update - Indefinitely delayed for now  (Read 25327 times)
Offline BeesKeys
  • Formerly Beesley
    • BeesKeys
KBM Bioluminescent
A glow in the dark Dyesub set
Inspiration
Inspired by sea creatures that invoke that natural bioluminescent glow
Jellyfish, coral, starfish, squids & octopus
Glow in the Dark
The intention for this set is to be glow in the dark
There are no renders depicting this as I want samples to speak for themselves and will be available shortly
Kitting
Deskmats
There are minor changes to these deskmats that will be apparent it updated samples. Including solid black edges
Renders - By Beesley
TypeBox - Its.Hymn
Man60 & Man40 - Geon
Glare TKL - Geon
GB Details
Expected GB Date: TBD
Vendors
US - OtaKeebs
EU - Keygem
CN - Zfrontier
CA - AlphaKeys
UK - Protozoa
JPN - Basekeys
OCE - ALLCAPS
Support this kit by using the signature below
Code: [Select]
[url=https://geekhack.org/index.php?topic=118166.0][img]https://images.squarespace-cdn.com/content/v1/62bc3ca4a736e83f2e63134b/fb661e02-0246-459d-83fe-3e22b9429a5b/Bioluminescent+Gif.gif?[/img]
Special thanks to everyone who supported me through the design of the and dealing with my constant pestering ensuring things are on schedule
OtaBen, SpikedSynapse & The KCC Discord Server
« Last Edit: Wed, 12 October 2022, 02:59:29 by Beesley »
Offline Wintea
Re: [IC] KBM Bioluminescent
« Reply #1 on: Tue, 23 August 2022, 07:36:20 »
 :thumb: Good luck with IC!!!!
Offline spikedsynapse
« Reply #2 on: Tue, 23 August 2022, 07:39:15 »
Damn that's a fine looking keycap set.
Offline irithyll
« Reply #3 on: Tue, 23 August 2022, 07:58:20 »
Okay, this does seem look quite fire
Offline norb
« Reply #4 on: Tue, 23 August 2022, 11:19:47 »
are they doubleshot or reverse dyesub? judging from the novelties my guess would be dyesub?
Offline CONIN
« Reply #5 on: Tue, 23 August 2022, 11:27:03 »
The intention for this set is to be glow in the dark. There are no renders depicting this as I want samples to speak for themselves and will be available shortly.
Interesting, will keep an eye on this one!
Offline Rilow
« Reply #6 on: Tue, 23 August 2022, 12:26:48 »
All-in if this is doubleshot. Don't want anymore reverse dyesub.
Offline TonyPia
« Reply #7 on: Tue, 23 August 2022, 12:38:16 »
Like this. 40s as add on please.
Offline Zeryph
« Reply #8 on: Tue, 23 August 2022, 13:15:21 »
I Love Jellyfish! I am extremely interested in the first two Deskmats, and should they reach group buy will certainly pick up both.
Offline BeesKeys
  • Formerly Beesley
    • BeesKeys
« Reply #9 on: Tue, 23 August 2022, 14:41:14 »
Thanks a lot!
You are correct!
We are excited to have these samples in hand very soon!
See above, you will be disappointed. But the reasoning behind this is the freedom of design in the novelties, and projected lead times in comparison to any double-shot manu right now.
Feedback for the full kit has been great, so there will be no add-on kit I'm afraid.
I glad you like them! I have the samples in front of me right now and could not be more happy!
Offline wndy
« Reply #10 on: Tue, 23 August 2022, 15:13:51 »
I won't comment on anything about originality, but if you want this colorway with doubleshots and aren't worried about novelties, I believe GMK Pulse is still in stock.
Offline Cylent
  • Formerly cylentshadows
« Reply #11 on: Wed, 24 August 2022, 11:10:59 »
Hi Beesley, I like what you've done with the concept, and as per usual your renders are excellent. I have a few points of feedback for improvement, mainly on the kitting, that is intended to be both positive and constructive.
For the base kit, the initial kitting is overall very solid. However, terminal iso is not really needed when uk iso is available. This means you can very easily cut R3 1u pipe and R4 1u pipe. Two things that are preference-based: (1) the Esc legends (GMK style) look to be a tad bit too small, and (2) I would also encourage you to make shift and caps lock vertically centered to increase alignment consistency across the legends.
For the 40s kit, the initial kitting is again overall very solid. The main thing of note is that you seem to have attempted to include "mod quote" and "mod pipe" which are generally great inclusions! However, these keys are only requested when the mods and alphas don't share the same colors. Here, just make those keys alpha-colored. Otherwise, the only other things that stand out in this kit are the preference-based comments I made above.
Finally, I really like the novelty designs. I hope that the samples indicate that this relatively-unproven manu can make the reverse dyesub illustrations. I'll be keeping an eye on this one - if the samples look good and it glows in the dark well, I'm in. GLWIC :thumb:
Offline The0rigina1
  • fumoposting
« Reply #12 on: Wed, 24 August 2022, 14:39:18 »
All reverse dyesub so based!!!
Offline mariajose1197
« Reply #13 on: Thu, 25 August 2022, 12:53:18 »
I love it, I want it.
It's reminds me of holbox beach in México.
I need that cute pattern deskmat.
;D
Offline CONIN
« Reply #14 on: Thu, 25 August 2022, 13:07:03 »
I would also love to have that deskpad even if I don't get the caps.
Offline BeesKeys
  • Formerly Beesley
    • BeesKeys
« Reply #15 on: Sun, 28 August 2022, 04:10:55 »
Update on pattern design, and minor 40s kit update
Offline Surefoot
« Reply #16 on: Sun, 28 August 2022, 04:56:02 »
Really nice novelties, love the theme. Colorway reminds of GMK Pulse but that's nice to have a PBT alternative.
Offline DirtyGingy
« Reply #17 on: Mon, 29 August 2022, 04:17:28 »
Pulse is... a little more green shifted from what I can tell. this set seems a tough more cyan on black as opposed to a slightly more teal on black with pulse. They definitely share similar DNA though. Hopefully this designer has been in touch with the person behind pulse to make sure there wouldn't be any bad blood
Offline Anthixious
« Reply #18 on: Mon, 29 August 2022, 12:01:58 »
Very simple <color> on Black set, love it. This is Cyan? on Black as well as being glow in the dark?  :thumb:
Offline Nonnegaard
« Reply #19 on: Wed, 31 August 2022, 05:47:27 »
MiTo is now a Drop employee. No use.
Aeon, TGR Jane V2, Dolphin 2021, Gherkin, Model M, 5°, NCR80, M0110-A
Offline gleneston
« Reply #20 on: Sat, 03 September 2022, 23:03:44 »
Hopefully the glow in the dark element works better than KAT Cyberspace. What a disaster.
Offline Pyurii
« Reply #21 on: Sat, 03 September 2022, 23:09:41 »
Really like the glow theme and the novelties, keeping an eye on this one
Offline BeesKeys
  • Formerly Beesley
    • BeesKeys
« Reply #22 on: Mon, 12 September 2022, 03:53:20 »
All Vendors Announced!
Offline kevvinn
« Reply #23 on: Mon, 12 September 2022, 08:19:22 »
This color scheme is really clean! :thumb: I'm loving the deep sea aesthetic of this set. I don't think I've seen a glow-in-the-dark set before; when you say that do you mean actual glow-in-the-dark plastic? If so, that's really neat! Looking forward to seeing pictures of the sample set.
Offline Avantel
« Reply #24 on: Mon, 12 September 2022, 08:56:05 »
Sweeet, vendors secured
Is there an estimate on the pricing of the different kits yet?
Offline BeesKeys
  • Formerly Beesley
    • BeesKeys
« Reply #25 on: Mon, 12 September 2022, 09:10:20 »
Pricing will follow soon! But we are aiming for sub $100 for basekit
Offline Avantel
« Reply #26 on: Mon, 12 September 2022, 10:15:14 »
Best news all week! :D
Offline AshF
Re: [IC] KBM Bioluminescent | Vendors Announced
« Reply #27 on: Mon, 12 September 2022, 10:31:05 »
Amazing kitting. Love the UK ISO which makes this an insta buy from me. GLWIC
Sent from my ASUS_I003D using Tapatalk
Offline William_S_Jones
  • Best Prime Ever!!!
« Reply #28 on: Tue, 13 September 2022, 23:40:22 »
Yes, I'm in for this set!
Sent from my SM-G998U using Tapatalk
Offline LASERman Projects
  • Soldering is my native language.
« Reply #29 on: Wed, 14 September 2022, 05:09:49 »
What is KBM, a profile? If so how it compares to Cherry? Any diegrams?
Offline BeesKeys
  • Formerly Beesley
    • BeesKeys
« Reply #30 on: Wed, 14 September 2022, 05:22:48 »
KBM is the manufacturer, the profile is Cherry
Offline BeesKeys
  • Formerly Beesley
    • BeesKeys
Re: [IC] KBM Bioluminescent | GB Update
« Reply #31 on: Wed, 28 September 2022, 02:55:51 »
GB Update:
In the interest of making sure everyone knows what they are buying and having samples ready before the GB to ensure there is no misleading with the quality of the GID we have made the decision to delay GB until 15th October while we iron out a few details in the manufacturing process
Offline Akele
« Reply #32 on: Wed, 28 September 2022, 11:57:37 »
GB Update:
Shame about the delay, but this seems like a very sensible decision. I look forward to seeing the samples.
Offline BeesKeys
  • Formerly Beesley
    • BeesKeys
« Reply #33 on: Wed, 28 September 2022, 12:52:10 »
GB Update:
The samples I have seen are looking fantastic! I am looking forward to showing the final ones when we have the process perfected.
Offline CONIN
« Reply #34 on: Thu, 29 September 2022, 09:28:04 »
...while we iron out a few details in the manufacturing process.
No problemo!, just like in videogames, we better have a finished, polished one, than a rushed, buggy one.
Offline BeesKeys
  • Formerly Beesley
    • BeesKeys
« Reply #35 on: Wed, 12 October 2022, 02:54:11 »
Update:
This is an indefinite delay. They have been more issues with manufacturing and are looking in to alternatives. Which may be a change to doubleshot and a complete novelty redesign. I will keep everyone updated but for now. GB date is TBD.
If there are any questions I'll be happy to answer them the best I can.
thank you for everyones support it means a lot!
Offline CONIN
« Reply #36 on: Wed, 12 October 2022, 09:21:04 »
Sorry to hear about the issues, but the "doubleshot and a complete novelty redesign" part sounds about great!
Offline digitalfrost
Re: [IC] KBM Bioluminescent | GB Update - Indefinitely delayed for now
« Reply #37 on: Wed, 12 October 2022, 10:07:52 »
I would definitely buy this if it came with an NORDE/international kit.
Offline Its Salty
  • I have no idea what I'm doing
« Reply #38 on: Thu, 13 October 2022, 21:59:01 »
Loved seeing all the WIPs of the project in KCC, cant wait to see it in person!
Offline bairghrem
« Reply #39 on: Tue, 22 November 2022, 10:48:19 »
Count me in
Offline arr1
  • Ñ supporter
« Reply #40 on: Mon, 05 December 2022, 12:09:08 »
Looking awesome. Looking forward to it
Offline WarlordGorguts
« Reply #41 on: Wed, 31 May 2023, 11:41:53 »
Any updates on this set?
Offline ppatches24
« Reply #42 on: Tue, 06 June 2023, 15:41:53 »
The glow in the dark dye sub is going to be maximum underwhelming.
I would highly reconsider making these dual shot with the bio blue glow in the dark plastic.
The lights come from under the keys not above lol.
Close to being amazing and unique but will probably be very underwhelming with just dye sub.
This would be an INSTA purchase if they were dual shot.
Offline Dmitri
« Reply #43 on: Sun, 09 July 2023, 09:04:41 »
I'm interested in the color scheme
I have no knowledge of glow in the dark application on keycaps, is it safe to use?
Let me know if i'm wrong.
« Last Edit: Sun, 09 July 2023, 09:11:01 by Dmitri »
