Author Topic: Feker Alice 3-mode mechanical Keyboard kit  (Read 19280 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
« on: Sun, 28 August 2022, 02:52:19 »
Feker Alice 80 3-Mode Keyboard
SPEC
  • Dimension: 370 x 130 x 35 mm (flat) / 40 mm (with semi-stand) / 50 mm (with full stand)
  • Weight 867g
  • ABS plastic case
  • hot swap PCB
  • 1680M RGB
  • PC plate
  • Connection: Type-C / Bluetooth 5.0 / 2.4G wireless
  • 32K ROM storage
  • NKRO support
  • Battery 8000mAh
  • south-facing switch LED
  • Support macOS and Windows
BUY HERE
Offline KPrepublic
  • * Moderator
    • KPrepublic
Re: Feker Alice 3-mode mechanical Keyboard kit
« Reply #1 on: Sun, 28 August 2022, 02:53:08 »
