Author Topic: [IC] *UPDATE 9/12* Magnetic Artisan Tray - Fragment R (Ikeygai Desings)  (Read 3280 times)
Offline Ikeygai Designs
291244-0
Announcement: We are super happy and excited to share that we have some exciting collaborations coming soon! Join our discord to keep up to date.
Hi Everyone! Welcome to our Artisan Tray IC! We are very excited to introduce our Artisan Tray Series - FRAGMENT
UPDATED RENDER
291250-1
The Fragment will be a series of trays starting with, Fragment R. What makes the Fragment series unique is the integration of magnets within the walls of the tray to connect two or more trays to form various shapes. The idea here is that we will offer different shapes and sizes in the future so that various trays can be used in conjunction with your existing trays to make any shape that you would like to. The magnets are placed in calculated positions so that each individual tray can be connected even in offset positions and not just in a linear placement. The logos around the edges of the tray are designed to complete when combined with another tray (Like in the render below).
        UPDATED RENDER
291252-2 291248-3
Fragment R will be a 5 X 3 artisan tray with a mirror finish badge in the center slot. There will be 3 magnets along the longer side faces and 2 magnets along the shorter side faces (This can be seen in the render below). The magnets will be held in place with rubber stoppers that will also act as the feet for the tray.
291254-4
This render is PC to show the magnets inside the tray, we have not planned a PC version. Unless of course there is interest :)
The badge in the center slot can be dislodged through the hole on the bottom of the tray (See render below) and used as an additional slot for a keycap. By default the logo in the badge will be the Ikeygai logo. We are planning to make this customizable by you (depending on the logistics and costs) or we can leave it blank on request so that you can customize it yourself. The logoing on the badge is still TBD so would love your feedback.
UPDATED RENDER
291242-5291246-6
291256-7
Details:
Tech Specs:
  • Aluminum 6063 Grade
  • Anodized Finish (Sand Blasting TBD) & Powder Coating/E-coating
  • Neodymium magnets x 10
  • Badge - Aluminum/Stainless Steel/Brass (depending in interest, might offer multiple choices)
  • 15 x 1u Artisan Slots
Dimensions:
  • Weight - Will update once we have the prototype in hand
  • Tray Dimensions are 123mm x 75mm x 12.75mm
  • Keycap Slots are 21mm x 21mm, with a depth of 8mm (Center slot depth 4mm)
  • Badge Dimensions are 20.8mm x 20.8mm x 4.25mm
Pricing:
  • TBD (but somewhere between $80-$100)
Colors:
  • Black, Red, Yellow and Green - Anodized Aluminum
  • White - Powder coat or E-coat (depending on volume/interest)
Quantity:
  • Depending on IC and GB (will update as we get more info from all of you)
Status:
  • Currently we are in the prototyping phase and are waiting for the prototypes to be completed.
    Will keep this post updated, but quickest way would be to check out our Discord channel
Contact (Come say hello!):
Discord - Ikeygai Designs
Instagram - @ikeygai_designs(https://www.instagram.com/ikeygai_designs)
About Us - Check out our introduction post!
Big shoutout to KingK22 for the amazing renders. You should definitely check out their page as well!
Lastly, thank you all for taking the time check out this post!
« Last Edit: Tue, 20 December 2022, 21:08:07 by Ikeygai Designs »
