Author Topic: Han60v2 | A Plateless Gasket 60% | New Proto, Vendors, Info  (Read 39872 times)
Offline Farhandsome
    • Han Boards
« on: Tue, 06 September 2022, 13:01:46 »
Han60v2
A 60% by Han Boards
The link above is a living document for the Han60v2. Please check this out because I spent a lot of time on it as it is the best resource for everything to know about this keyboard.
Externals
The design language of the Han60v2 involves the utilization of chamfers and bevels as opposed to fillets and sweeps.
Everything is designed around keeping things as angular as possible while still having an interesting profile.
Material (case):        Sandblasted 6063 Aluminum
Material (weight):        PVD Brass
Variants:        WK & WKL
Weight:        5 lbs / 2.2kg unbuilt
Typing Angle:        7 deg
EKH:        27mm
Plate Options:        Plateless, Aluminum, PC, Carbon Fiber
Colors:        Silver, Purple, Red, Rose Gold
Internals
The Han60v2 utilizes a plateless mounting style with deep bottom gaskets for improved compression.
Multiple layouts, several optional foams, and other optional modifications allow the user to tune the board as they see fit.
Mounting Style:        Plateless Gasket Mount
PCB Specs:                                                            RP-2040 Powered (Designed by Sleepdealer)
Software:        QMK & VIAL
PCB Design:        1.6mm FR4
Daughterboard Info:                                                           Modified XYZ DB (Designed by Lysol)
PCB Variants:        Solder and Hotswap
Switch Type:        MX
Layout Support:        see pic below
Solder
Hotswap
Kit Details
Aluminum Top & Bottom Case
PVD Brass Weight
PCB (solder or hotswap)
Daughterboard w/ JST Cable
Plate (aluminum, PC, or carbon fiber)
Acoustic Foams (case, thin plate, thick plate, and switch)
Structural Material (silicone bumpers, thin gasket tabs, thick gasket tabs, case feet)
Hardware
Microfiber Cloth
Hard-shell Carrying Case
Typing Test #1
Type Test - Nainaigogo
MX Blacks | Gateron Ink Stabs | Case Foam Only
Typing Test #2
Type Test - Jan
Zakus | TX Stabs | No Foams
Sale Information
Price:        $300-335
Format:                                                          Group buy w/ a hard cap (TBD)
GB date:        TBD
Content Lineup
Clackbait        Review
nearLucid        Review
LightningKeyboards        Build Stream
XinXinWong        Build Stream
Alexotos        Build Stream
DutchMasterw        Build Stream
Vendors
Han Boards        NA
Keyspresso        CA
Keygem        EU
Han Boards        Rest of World
Special Thanks
Nainaigogo
Jan
Sneakbox
Deepspace
Sehonky
SpikedSynapse
Sleepdealer
Lysol
Clackbait
nearLucid
LightningKeyboards
XinXinWong
Alexotos
DutchMasterw
The keyboard community  :)
Han60 Signature:
Code: [Select]
[url=https://geekhack.org/index.php?topic=118286.0][img width=276 height=120]https://i.imgur.com/6izLkRq.png[/img][/url]
« Last Edit: Wed, 05 October 2022, 17:19:15 by Farhandsome »
Offline Farhandsome
    • Han Boards
Re: Han60v2 | A Plateless Gasket 60% by Han Boards
« Reply #1 on: Tue, 06 September 2022, 13:07:32 »
IC FAQs
Design
  • Logo will stay on the backplate
  • Dimensions will be slightly changed to look more "slim"
Colors
  • All colors will run (and maybe will add one more :eek:)
Kit
  • All foams/plates will be available as options since it doesn't change the price too much
Vendor Support
  • Self-fulfilling for CONUS, will be working with international vendors
Updates (as of 10/5)
  • Red prototype in!
  • Keyspresso and Keygem will serve as CA/EU vendors
  • Content creator boards in progress
Next Steps (as of 10/5)
  • Get boards to content creators
  • Establish GB dates
« Last Edit: Wed, 05 October 2022, 17:20:52 by Farhandsome »
Offline Bub
    • big bub's beepers
« Reply #2 on: Tue, 06 September 2022, 13:17:59 »
Love the spellbook photo!!
price looks OK to me. i'd say go no foam and drop the price a few bucks if the option is there. i don't think a lot of folks will build with foam, but i could be wrong
GLWIC
Offline nainaigogo
« Reply #3 on: Tue, 06 September 2022, 13:44:40 »
Thanks for sending this board for me to test. Really enjoyed the looks, sound, and feel. GLWIC!
Offline .jan
    • keebsta
« Reply #4 on: Tue, 06 September 2022, 13:46:04 »
LETS GO
love the purple
Offline ankit
  • Formerly ankit-sachdeva
« Reply #5 on: Tue, 06 September 2022, 15:34:14 »
sick pricing
where is the front height being measured from?
« Reply #6 on: Tue, 06 September 2022, 16:41:54 »
I like the angular design choice. Seems like a lot of boards focus on curves now so this stands out to me. Good pricing too. Best of luck with this IC!
Offline Farhandsome
    • Han Boards
« Reply #7 on: Tue, 06 September 2022, 17:39:09 »
GLWIC
Thank you !! Spellbook is an awesome set  ;)
I added foam config as an option on the IC so I'll see how people would prefer it. I personally don't use any foams in my build, but wanted to leave it open for as much customization as possible.
sick pricing
Thanks !! Daal is a sick board  :)
And good eye - that's the front height, but I'll update it to the EKH measurement when I get home tonight!
Offline Rafa_n
  • stuffforrectangles.etsy.com
« Reply #8 on: Tue, 06 September 2022, 17:40:26 »
the design is not for me, but the mounting looks good and the price is really nice, GLWIC :)
Offline MelonBred
« Reply #9 on: Tue, 06 September 2022, 19:51:28 »
Interesting mounting options. Can you explain the Integrated Force Break Mod in a little more detail?
Offline synthetics
  • very cool
« Reply #10 on: Tue, 06 September 2022, 21:19:00 »
Why not ne hhkb avail?  :( :(
Offline dvllpxe
« Reply #11 on: Tue, 06 September 2022, 21:33:52 »
the sound!!
this is a yes
Offline Farhandsome
    • Han Boards
« Reply #12 on: Tue, 06 September 2022, 22:50:08 »
Sure!
The bottom case has some slots that allow some silicone bumpers (included) to rest in. This sits slightly above the lip of the bottom case and makes direct contact with the top case when assembled together having the same effect as a "force break" mod (minimizing the reverberation in the case)
It's entirely optional but does a good job of eliminating any ping or hollowness!
Offline Farhandsome
    • Han Boards
« Reply #13 on: Tue, 06 September 2022, 22:51:31 »
It will really come down to the amount of interest! If there is a high enough MOQ, we may be able to offer HHKB but will need to gauge based on this first IC!
Offline linell
« Reply #14 on: Wed, 07 September 2022, 03:02:39 »
I love the new bezel design compared to the first han60
love seeing more plateless boards
bro this a **** set, just be thankful you even getting 1 base running fr
Offline The0rigina1
  • fumoposting
« Reply #15 on: Wed, 07 September 2022, 03:13:25 »
In the title you said this will be a plateless kit, yet you include a plate for every kit sold?
Offline Botty212
« Reply #16 on: Wed, 07 September 2022, 03:20:57 »
are the blockers here going to stay like this?
« Last Edit: Wed, 07 September 2022, 03:30:01 by Botty212 »
Offline Botty212
« Reply #17 on: Wed, 07 September 2022, 03:21:27 »
« Last Edit: Wed, 07 September 2022, 03:29:45 by Botty212 »
Offline Farhandsome
    • Han Boards
« Reply #18 on: Wed, 07 September 2022, 09:23:09 »
Another case similar to the foams - the aluminum and FR4 plates don't really add too much to the cost, so I thought giving people more options to build would be a good idea whereas if people wanted to try something like CF, it'll add slightly. Maybe "PCB-mount" is more aptly named than plateless.
So the blockers were changed from the silver (rev1 prototype) to the purple (rev2 prototype) to have a chamfer all the way around and also fixed the width between keys. Or are you referring to something else?
Offline Luna
« Reply #19 on: Wed, 07 September 2022, 10:01:41 »
Interested in a silver or maybe red one.
Is it going to be bright red or can it be more burgundy as well?
Offline Farhandsome
    • Han Boards
« Reply #20 on: Wed, 07 September 2022, 13:40:42 »
I'll have a red prototype soon, I don't imagine it'll be burgundy, but it should be closer to a matte finish than the render! I will update with pictures when I receive.
Offline Luna
« Reply #21 on: Wed, 07 September 2022, 13:59:59 »
Thanks, I’ll be following the updates but I’m pretty sure I’ll get me a red one this time.
Offline treeleaf64
    • treeleaf64
« Reply #22 on: Wed, 07 September 2022, 17:53:29 »
Good pricing  and the Tree Leaf Supports This One
It is the proper level of Cursed and Rursed
Yayaya Yayaya!
Everyone must pay the cat tax
Offline Botty212
« Reply #23 on: Thu, 08 September 2022, 01:35:10 »
Might just be the lens or something but on that picture it looks like the blockers are shifted to one direction.
Example the right blocker. On that pic it looks as if its shifted to the right. The gap on the left is bigger than the one on the right.
Offline Farhandsome
    • Han Boards
« Reply #24 on: Thu, 08 September 2022, 09:38:32 »
Ah gotcha! I think it may just be the angle:
Here's a different view of it!
Offline Luna
« Reply #25 on: Thu, 08 September 2022, 21:44:37 »
I think GMK Umka on red would look nice. Or maybe better on silver after all?
Offline v4lly
« Reply #26 on: Fri, 09 September 2022, 10:25:21 »
Looks so nice....Interested about the ETA?!
Offline Luna
« Reply #27 on: Fri, 09 September 2022, 10:27:56 »
Yeah, I like the edges, classy!
Offline Backspace2
  • Third most used key on the keyboard is Backspace!
« Reply #28 on: Fri, 09 September 2022, 10:40:43 »
I also really like the design, as someone who primarily uses 60%. Interested in the plateless config, great price.
Yes
Offline Farhandsome
    • Han Boards
« Reply #29 on: Sat, 10 September 2022, 10:16:21 »
Currently, I'm analyzing the responses on the IC! If there's not too much that needs to be changed, I'll send out to content creators after the IC period and then go into GB shortly after that. I'll keep the timeline up-to-date on the Notion page as well as my Discord!
Offline Farhandsome
    • Han Boards
« Reply #30 on: Wed, 14 September 2022, 18:00:47 »
Updated with first week's progress! The responses on the GH as well as the IC have been amazing! Looking forward to what's next  :)
Offline Botty212
Re: Han60v2 | A Plateless Gasket 60% | 9/14 Update
« Reply #31 on: Thu, 15 September 2022, 07:57:31 »
just realised after reading through it once again.
You are offering hotswap with plateless?!? I dont think that this is a good idea
Offline Farhandsome
    • Han Boards
« Reply #32 on: Thu, 15 September 2022, 20:44:50 »
The mounting style is plateless - each kit will come with a plate if users want to use a hotswap PCB!
Offline Bigtailcat
« Reply #33 on: Thu, 15 September 2022, 22:30:33 »
Looks so good! :thumb:
Offline Jkush463
« Reply #34 on: Fri, 16 September 2022, 17:26:07 »
this is nice, hope to get in on the GB
Offline judthedud
Re: Han60v2 | A Plateless Gasket 60% | 9/21 Update
« Reply #35 on: Thu, 29 September 2022, 06:13:34 »
silver and brass for the backpiece looks stunning. hopefully I can hop on the group buy!
Offline Farhandsome
    • Han Boards
Re: Han60v2 | A Plateless Gasket 60% | New Proto, Vendors, Info
« Reply #36 on: Wed, 05 October 2022, 17:30:31 »
Hi all,
Red prototype is in! I added the pictures to the GH post. Also, Keyspresso and Keygem will be serving as vendors for the CA/EU regions.
Excited for this project moving forward! Stay tuned...  :cool:
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #37 on: Sun, 04 December 2022, 12:27:02 »
Purple, silver, red good colors  :thumb:
Offline tucuxi
« Reply #38 on: Mon, 23 October 2023, 11:51:58 »
Still relevant?
Offline avalicious
« Reply #39 on: Sun, 10 December 2023, 15:35:50 »
any chance for this to still be made?
Offline Farhandsome
    • Han Boards
« Reply #40 on: Sun, 10 December 2023, 21:07:17 »
Hey all - sorry for not checking this one.
This project is on a hiatus until after the Reflection GB goes into production - then I'll probably make some updates to this one!
