Author Topic: [IC] RE65 Aluminium R2 | Foamless, Gasket Mount  (Read 22401 times)
Offline nuxroskb
    • Keyboard from Vietnamese Maker
« on: Wed, 07 September 2022, 05:01:12 »
RE65 Prototype Ver 1
RE65 Designed by Nuxroskb
Ever since I got into this hobby, I've always wanted to design keyboards in the most classical way possible,
which could give the best sound profile and typing experience without having to utilize foam but are also budget-friendly for many enthusiasts.
After many failures and a long process of prototype testing, I am excited to introduce my next project - RE65.
IC FORM https://forms.gle/Ln7Ss3NVPnntR42P8
Base kit includes:
Aluminium case
External Brass Weight
FR4 Plate
PCB Hotswap, gasket poron, bottom feet
RGB front bar
Link album: https://imgur.com/a/vmChYCs
Structure
Front Height: 20,1 mm
Length: 336,6 mm
Width: 116,7 mm
Weight:
Full built(Keycap, switch) + Internal Brass Weight  + External Brass Weight:  2,300 g
Only kit (without Internal Brass Weight, keycap, switch): 1600 g
Case Material: 6061 Aluminum
Colours: Black, Grey, Red, Silver
Degree: 7
Gasket Mount
Leaf Spring Plate
Group Buy Format: Unlimited
Case compatible with KBD67 PCB, KBD67lite PCB..
BLE PCB: VIA Compatible
Hotswap PCB: QMK/VIA Compatible
PCB compatible with: KBDFans case, KBD67, KBD67 lite, Blade65,...
Extras
+ Case
+ Plate Alu/FR4/POM/Poly
+ Aluminium front bar
+ Acrylic Wrist rest
+ Hotswap standard PCB
+ BLE PCB
Typing test:
Tailer keebs Stream & Soundtest
Scuffed Boards Stream & Soundtest
Linn types
Nuxroskb
LAB reviewer
Str4yC4t
BLE TEST
Expected GB Round 1: Oct 2022
Expected Lead Time: Depends on how many units are sold (We will update this when the GB is closed)
Expected Price: <$250
Vendors: For Round 1
Global - Mechkey.store
Mechkey.store discord: https://discord.gg/dyZUDb2ZsC
My Discord: https://discord.gg/y5FFTgs9g9
My Instagram: https://www.instagram.com/nuxroskb/
My youtube: https://www.youtube.com/channel/UC-57W_53wkqKUT4ga7c5CUA
Prototype
Black
Blood
Silver
PCB
During my travel to Malaysia to attend the MYMK 2022 event, I've had the chance to talk to other makers and designers, from whom I was given advices and learned a lot to improve my designs further.
Typing feel and sound profile are the two aspects I focus most, which don't require any kinds of foam to be good.
Finally, I've made the decision to change the design of RE65 significantly and fix any issues that were visible in the last Interest Check.
This post will be an entire rework and final Interest Check of RE65
Difference between version 1 and final version
Base kit includes:
Aluminium case
FR4 Plate
Hotswap PCB, Poron gasket, Bottom feet
RGB front bar
Link album: https://imgur.com/a/yAA7b36
Link IC: https://forms.gle/CYD22gf2kqHvi9GQ9
Structure
Length: 336,6 mm
Width: 116,7 mm
Weight:
Degree: 7
Gasket Mount
Leaf Spring Plate
Extras
+ Only case
+ Internal brass weight
+ Acrylic wrist rest
+ PCB hotswap
+ RE Deskmat
Expected GB Round 1: Nov 2022 (Because I have changed my designs, GB time will be pushed back from the previously announced date)
          - Iconlabs
Typing test:
Linn types
Nuxroskb
Str4yC4t
Hi, I'm Nuxroskb  IC FORM  DISCORD  INSTAGRAM
I designed this board based on a spaceship, with the RGB front bar will be the rocket booster.
I really like using heavy keyboards, the heavier the better, so the RE65 is an extremely heavy keyboard with a weight of 2.3kg after being built.
I just finished the RE65 R1, with R1 I run in my VNMK community last December and some internationally. After R1 I received very positive reviews about the feel of the typing and the sound is very good.
Now I introduce to everyone RE65 R2 with the aim of making it more widely available to people all over the world.
Still keeping the spirit of saying no to foam to be able to produce the most standard sound of the switch that clearly shows each switch's sound quality without distorting it.
Here is some information about R2:
RE65 R1
Specifications
  • Case: Aluminium 6061
  • Plate: Aluminium
  • Internal Copper Weight  + External Copper Weight
  • Weight: Base kit 2.3kg
  • Degree: 7
  • Front Height: 20,1 mm /Length: 336,6 mm /Width: 116,7 mm
  • Gasket mount
  • Hotswap PCB 1.6mm, USB type-C
  • QMK/VIA compatibility
  • Colors: Black/ Grey/ Red/ Silver/ Navy/ PC
                                       All PCBs will include the following options:
                                         R2                                                 R1
                              Stepped capslock                                     None
                             6.25u/ 7u spacebar                       6.25u/ Split spacebar
Base kit includes:
  • Case
  • Alu plate
  • Poron gasket
  • PCB Hotswap 1.6mm
Estimate price: 270$
GB time estimate: 25/5/2023
Extras
Plate (aluminum, brass, PC, POM)
PCB Hotswap/ Ble PCB
Aluminum front bar
Special thanks Alexotos, NearLucid, The Dredgen Project for streaming and reviewing my RE65 Keyboard.
Vendors
US: Vala
Canada: Ashkeebs
China: TBD
UK: Proto[Typist]
EU: Keygem
OCE: Allcaps
Thailand: PJ Aiglatson Studio
Malaysia: Tips
Rest of World: Mechkey.store
Soundtest: (All sound test videos don't use foam)
« Last Edit: Thu, 08 June 2023, 00:48:18 by nuxroskb »
Offline The0rigina1
  • fumoposting
Re: [IC] RE65 Aluminium | Foamless, Gasket Mount
« Reply #1 on: Wed, 07 September 2022, 06:47:59 »
Vietnam dolinger
Offline densus designs
  • * St. Jude Supporter
« Reply #2 on: Wed, 07 September 2022, 06:52:35 »
Offline Arokomi
« Reply #4 on: Wed, 07 September 2022, 07:25:43 »
really pretty
Offline Fraaaan
« Reply #5 on: Wed, 07 September 2022, 08:14:02 »
Why does my foamless keyboard come with foam?
Offline nuxroskb
« Reply #6 on: Wed, 07 September 2022, 08:37:26 »
Some people like to use it and some people don't, so I still want to let it in.
If you need it you will have it, otherwise, you can use it for your other 65 keyboards.
Sorry if I said something wrong because my English is not good
Offline nuxroskb
« Reply #7 on: Wed, 07 September 2022, 08:40:03 »
Offline treeleaf64
    • treeleaf64
« Reply #8 on: Wed, 07 September 2022, 15:07:30 »
Hey, that's a nice case design, !  Not bad from your Flower Lover
Everyone must pay the cat tax
Offline Uki
« Reply #9 on: Thu, 08 September 2022, 18:09:16 »
Unique layout I haven't seen that before that split spacebar might be very funtional. Really cool. Maybe I'm not a fan of the case but I'm a fan of split spacebars
Offline nuxroskb
« Reply #10 on: Thu, 08 September 2022, 22:57:48 »
Thank you very much. I will have an update explaining why I chose this layout as soon as possible ;D ;D
Offline crookey
« Reply #11 on: Thu, 08 September 2022, 23:50:13 »
Unique light layout. It's cool.
Offline nuxroskb
« Reply #12 on: Fri, 09 September 2022, 23:44:49 »
Thank you  ;D
Offline Nonnegaard
« Reply #13 on: Fri, 16 September 2022, 06:09:01 »
it looks like a dolinger, only worse in every metric. the dolinger is the best board ever, tho, so that's not bad.
Aeon, TGR Jane V2, Dolphin 2021, Gherkin, Model M, 5°, NCR80, M0110-A
Offline fortissim2
« Reply #14 on: Fri, 16 September 2022, 14:20:03 »
I love the design and the RGB! GLWIC :)
Offline nuxroskb
Re: [IC] RE65 Aluminium REWORK | Foamless, Gasket Mount
« Reply #15 on: Sun, 16 October 2022, 01:09:43 »
We just rework the RE65 product, and have some new updates !! ;D
Offline datnoof
« Reply #16 on: Sun, 16 October 2022, 02:01:32 »
nice rework, GLWIC
Offline IconlabsOfficial
  • Where makers make art!
    • Iconlabs
« Reply #17 on: Wed, 23 November 2022, 06:39:40 »
RE65 IS FINALLY LIVE!
https://iconlabsofficial.com/group-buy-re65-aluminum/
We are an official distributor of Nuxroskb and allowed to bring this keyboard to everyone ^^
Offline nuxroskb
Re: [IC] RE65 Aluminium R2 | Foamless, Gasket Mount
« Reply #18 on: Wed, 03 May 2023, 09:47:25 »
R1 is done, R2 will come to everyone as soon as possible.
R2 will be streamed by Alexotos and Nearlucid in the near future, stay tuned !!!
Offline nuxroskb
« Reply #19 on: Sat, 10 June 2023, 02:42:55 »
GB is live !!!!
This is the Unlimited GB, after running this R2 will not have R3, this is the last time I produce RE65!
If you have any questions please DM me on Discord. Thank you guys !!!
Offline tactilesbad
« Reply #20 on: Wed, 14 June 2023, 10:00:38 »
I absolutely despise the OG dolinger design and this follows suit but at least the price on this one is actually reasonable
GLWGB
