Author Topic: [IC] curve0 (keyboard)  (Read 38874 times)
Offline kbd0
« on: Wed, 07 September 2022, 15:53:51 »
Edit: Group buy open until Nov 30 2024! Check it out
curve0:
First prototype (this is not what will be produced)
Why curve
It has long been known that a flat typing surface is not very ergonomic. This is why profiled keycaps exist.
You may have noticed that all keycap profiles share a common characteristic: the overall typing surface is in the general shape of a curve.
(original photo from https://geekhack.org/index.php?topic=68550; check out that thread to see lots of other profiles)
Changing the keytop angles (in order to achieve a curved typing surface) has flaws:
  • The angle of the force applied to the key is not in line with the translation axis of the switch. As a result:
    • Only the component of the force that is parallel to the switch action actually contributes to moving the switch. The operator therefore needs to press harder in order to move the switch the same amount (vs flat keytop):
    • The perpendicular force component becomes friction. This results in a less smooth key travel.
      • Additionally, the added friction resists the movement of the switch and makes the operator have to press even harder!
  • The angled keycaps also need to be taller. The perpendicular force component therefore has greater leverage, which increases its added friction (which decreases smoothness and requires you to press even harder):
To fix these flaws, curve0 has the switches themselves at an angle. This gives a curved typing surface with flat keycaps.
Another advantage of having the switches at an angle is that your finger actually moves in the direction of the press during the keytravel, which feels more comfortable (in my opinion at least).
About curve0
To give everyone a chance to try this new concept, I designed a simple construction to keep the price low. The case (into which the plate is integrated) is cut and bent from two pieces of 1.5mm stainless steel with a brushed finish.
curve0 is designed specifically for DSA keycaps but XDA should work too (they are taller so the curve will be a bit more pronounced and the keys will feel closer together (vertically)).
With DSA keycaps, the typing surface of curve0 is similar to that of MT3.
Height and angles
With DSA keycaps, curve0 will have a home row height of about 25.5mm and a spacebar height of about 27.5mm.
Measuring the angle is not as straightforward as other keyboards since each row has a different angle. With the default rubber feet, the home row has no angle (parallel to table). However, I find that the keyboard angle is better represented by the tangent of the curve between the home row and the row above it, as this is the center of the actual typing surface (without the spacebar row). This has an angle of 5°. Finally, the spacebar has an angle of 2°. The extra rubber feet add (or subtract, if you put them on the front) 3° (this might change).
Layout support
Layout options TBD. Please fill out the IC form for your preferences to be heard.
Kit will include
  • Stainless steel case
  • PCB, daughterboard, and their connecting cable
  • Screws, rubber feet
You will need your own: switches, keycaps, PCB-mount stabilizers
Price
Under $100; exact amount TBD
If you are interested please fill out the Interest check!
Discord server
https://discord.gg/2cN5WGYscM
« Last Edit: Wed, 13 November 2024, 14:52:52 by kbd0 »
Offline mmayhem17
    • Steam profile
Re: [IC] curve0 (keyboard)
« Reply #1 on: Wed, 07 September 2022, 16:00:33 »
just buy some SA bro, don't need to reinvent the wheel.
Offline wndy
« Reply #2 on: Wed, 07 September 2022, 16:05:12 »
This is very strange, but assuming the price would actually be sub-$100, I'd still buy it just to try it out. Creative project, I like seeing things like this even if it might not be exactly the most simple solution to the problem.
Good job!
Offline mvkb
  • Designer
    • MVKB
« Reply #3 on: Wed, 07 September 2022, 16:16:47 »
Love crazy ideas like this!
Offline IO Sam
    • IO Sam Hub
« Reply #4 on: Wed, 07 September 2022, 17:22:20 »
Yeap! I think I'd be interested in trying something like this... Reminds me of how Model F and M boards are similarly curved. Nice to see something that is actually trying to improve one's typing experience for a change (rather than just being "bouncy" and pretty)!
Offline andromache
« Reply #5 on: Wed, 07 September 2022, 17:36:26 »
This is neat. Would definitely try it at sub-$100.
Offline stewfayew
« Reply #6 on: Wed, 07 September 2022, 17:41:25 »
I could finally use my one abandoned DSA set!?
Offline Sax_______
« Reply #7 on: Wed, 07 September 2022, 18:00:17 »
That's cool and all but
DSS exists
Offline treeleaf64
    • treeleaf64
« Reply #8 on: Wed, 07 September 2022, 18:32:20 »
DSS exists
yea   This is a Cool Idea!  I am trying to figure out how to get this bent shape    , love the look   yes   I see DSS and  DSS is good
Everyone must pay the cat tax
Offline Zanhana
« Reply #9 on: Wed, 07 September 2022, 20:37:40 »
so is the PCB also curved, or is there a separate one for each row?
Offline HappyB0T
  • I'm a Piggie
« Reply #10 on: Wed, 07 September 2022, 21:11:39 »
I would imagine this would feel better than SA. If this keyboard was a split no one would say anything about the madness. Madness contained in 60% footprint may seem trivial but I like the intent here. SA num row feels odd since it is so far away from the actual actuation. Possible that you may feel a more consistent actuation and may not feel like you are typing on stilts.
__________________________________________
I'm cool with the idea.
Feedback:
The break on the space bar row looks a bit exaggerated. If it was possible to maintain that angle but cheat the keys closer to R2 may result in a less pronounced gap. An alternative is to raise the back a little and have a consistent arch toward the spacebar
Sub 100 is a nice sweetspot - thanks for providing pricing estimate.
Please consider adding a picture not at an angle or some sort of schematic showing a comparison of the SA image presented and the proposed layout with keycap profile. Or a close up side profile of your proto similar to the SA pic.
Consider a top-down view to show spacing between rows. It looks off from your pictures currently but is hard to judge.
**I am drunk - hope this makes sense :D
Offline SzGeri
« Reply #11 on: Wed, 07 September 2022, 22:17:59 »
Okay, at first I was like, this is stupid. But then I read your explanation and now I'm kind of intrigued. If you manage to keep the price down, I think many people would be willing to try this.
A suggestion to make it even cheaper and to potentially make it sound better would be to make it out of some kind of plastic. I love steel cases but not so much steel plates. And a plastic very open keyboard has the potential to sound like this keyboard everyone is obsessed with.
Offline wndy
« Reply #12 on: Wed, 07 September 2022, 22:37:34 »
Feedback:
Yeah, I do agree with the comment on the bottom row, it does look a bit extreme from the pictures included. I think maybe even just lessening the angle of the bottom row in general might be a decent idea as well, not just changing the look
Offline P103
« Reply #13 on: Wed, 07 September 2022, 23:28:44 »
This is cool  :thumb:
Offline hkhawk
« Reply #14 on: Wed, 07 September 2022, 23:30:30 »
Very cool idea
Offline hkhawk
« Reply #15 on: Wed, 07 September 2022, 23:47:35 »
I think reducing the gap and angle between the bottom row and alphas is probably a good idea. Also, I would prefer if the USB port was centered.
Also can you please post better pictures of the side profile?
« Last Edit: Wed, 07 September 2022, 23:56:41 by hkhawk »
Offline kbd0
« Reply #16 on: Thu, 08 September 2022, 00:09:53 »
Don't want to say too much as it may still change. But first proto has a curved PCB with reliefs for the stabs/smt components and seems to be a great solution so good chance that it will stay. Will update as it gets more final.
Offline kbd0
« Reply #17 on: Thu, 08 September 2022, 00:19:14 »
Feedback:
Will update with some more photos soon!
Regarding the bottom row I do agree it is a bit much and I will be lessening the angle and offset. But even with this version I found it was easy to get used to as the thumb is quite mobile and independent from the rest of the hand
Offline Farhandsome
    • Han Boards
« Reply #18 on: Thu, 08 September 2022, 00:21:19 »
Really interesting concept. Would love to see a Tsangan option and noted that in the IC.
I hope this project is successful so you can come back and make a full alu chassis compatible with the pcb for R2  ;)
Offline panka
« Reply #19 on: Thu, 08 September 2022, 00:31:18 »
that's what i've been saying man! thank you for putting this into practice
no why would anyone want this
also can someone perma ban this guy already
Offline Soums
« Reply #20 on: Thu, 08 September 2022, 00:41:57 »
Nice explanation this is an interesting concept. Heard people even talk about different weighted springs depending on how far/close from home row keys they are; this seems to try to solve the same problem in a more practical way.
Filco Zero Camo TKL | HHKB Professional 2 | KMAC 2 | KMAC Pad | LZ RE | LZ XE | LZ REs | Koala | Ottantaquattro | Dodici | Kohaku | Nue
Looking for:
LZ SE
LZ S
Offline kapowaz
    • kapowaz industries
« Reply #21 on: Thu, 08 September 2022, 03:29:28 »
I don’t know if it’s for me but I love that you’re pushing into new territory with this concept. Really interesting engineering problems to solve as well. Good luck with the IC!
Offline HappyB0T
  • I'm a Piggie
« Reply #22 on: Thu, 08 September 2022, 06:43:15 »
Offline plag
  • Formerly pepperonichicken
  • i also go by plag
« Reply #23 on: Thu, 08 September 2022, 07:07:40 »
Awesome project ;D
Offline jiminojimi
« Reply #24 on: Thu, 08 September 2022, 07:10:00 »
This is a good price point and the curve is distinguished enough for me to trial it for months
I’d like it to have a TKL option
Offline 0atneil
« Reply #25 on: Thu, 08 September 2022, 13:05:04 »
I like it, hoping for tsangan layout.
Offline fortissim2
« Reply #26 on: Thu, 08 September 2022, 13:29:09 »
Sounds awesome! Would prefer a 40% variant though. :)
Offline lewisflude
  • Hand Engineering
    • Hand Engineering
« Reply #27 on: Thu, 08 September 2022, 15:25:47 »
Great idea and clean execution, cool to see you take a problem and find your own way to solve it. Great work!  :thumb:
Offline catamscott
« Reply #28 on: Thu, 08 September 2022, 18:20:07 »
really cool project, and price is good enough that i'd be down to grab one if and when it hits gb  :thumb: hoping split right shift gets included
Offline crookey
« Reply #29 on: Fri, 09 September 2022, 01:04:16 »
Curved layout is interesting. Cool project.
Offline Nuap
« Reply #30 on: Fri, 09 September 2022, 01:44:00 »
This is quite neat, I'd be down to try.
I see that in your IC you have the incorrect layout for HHKB. The right shift should be split with a 1u Fn for a standard HHKB layout.
With that being said, please make a HHKB or Tsangan layout available with:
- Split backspace
- Split right shift
- Tsangan OR 7u HHKB bottom row
- Optional stepped caps
« Reply #31 on: Fri, 09 September 2022, 06:52:21 »
I have an old idea that perhaps angling the ZXCV row this way might be good but that the other rows should have sculpted keycaps.
Offline hkhawk
« Reply #32 on: Sat, 21 January 2023, 22:41:54 »
Any updates?
Offline EdgeOfInfinity
« Reply #33 on: Tue, 07 February 2023, 18:23:52 »
sweet diagrams
« Reply #34 on: Wed, 12 July 2023, 17:50:16 »
this dead??
Offline kbd0
« Reply #35 on: Mon, 03 June 2024, 20:43:30 »
Sorry I didn't update on geekhack
I stopped working on this project for a long time but I'm back and I'm ready to take it to completion!
I've been using my personal version of curve0 for the past year and I've been loving it, which makes me even more excited for you guys to try it.
I'm currently working on the second prototype which has a bunch of improvements both functionally and aesthetically.
Stay tuned!
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #36 on: Tue, 04 June 2024, 15:12:02 »
Excellent news. Can't wait to see what's new!
«How much wood could a woodchuck chuck if a woodchuck could chuck wood?»
Offline kbd0
« Reply #37 on: Sun, 21 July 2024, 16:25:18 »
I just finished assembling the second prototype and I am very pleased! It feels amazing to type on and there is not much that needs to be fixed. I need to make some decisions but I will have another update with the next steps soon!
more photos
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #38 on: Mon, 22 July 2024, 06:42:44 »
It looks like you've dramatically changed the height and inclination of the bottom row: how high is it exactly?
Can you please post a side profile photo?
Offline kbd0
« Reply #39 on: Tue, 23 July 2024, 12:50:48 »
That's right, the angles were too extreme in the first prototype. I have now made them as neutral as possible and will include extra rubber feet for adjusting the angle to personal preference. I'm out of town for a couple days so I will update with the exact measurements when I am back.
For anyone interested, I removed the photo of the first prototype but I realize that was a mistake and will put it back in the post when I update it
« Reply #40 on: Wed, 24 July 2024, 13:35:20 »
dope, i'm glad this project is back on!
Offline kbd0
« Reply #41 on: Fri, 26 July 2024, 17:59:00 »
Heights and angles added to original post under "Heights and angles"
Offline kbd0
« Reply #42 on: Fri, 26 July 2024, 22:54:39 »
What is generally expected firmware-wise? I currently have it running QMK (on RP2040)
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #43 on: Sat, 27 July 2024, 02:23:34 »
Thanks a lot for all the information you added about heights and angles.
It is definitely a tall board: based on your experience, do you not find the use of a wristrest necessary?
Offline kbd0
« Reply #44 on: Sat, 27 July 2024, 10:52:24 »
Unfortunately I can't answer that as I've personally never found a wrist rest to be comfortable, even on very tall boards.
This is subjective but I don't think the board feels tall since the home row is not that tall.
Offline Jimmy T
  • i could use a chiropractor
« Reply #45 on: Fri, 02 August 2024, 04:59:54 »
Crazy stuff, love it. Glad that it is back on track. Filled in the interest form, GLWIC.
Offline kbd0
« Reply #46 on: Mon, 12 August 2024, 21:56:29 »
Update: Turns out the upper steel part is quite hard to produce to the level of quality that I want. But after discussing extensively with the manufacturer and making some minor changes I think we are finally ready for production. I will be doing a full test run of 5 keyboards and if all goes well it will be time for the group buy!
Offline The_Boom_Boy
« Reply #47 on: Fri, 16 August 2024, 08:58:44 »
Love it! Keep up the good work!
Offline childofthehorn
« Reply #48 on: Fri, 16 August 2024, 09:40:51 »
Watching this as its refreshing and a take on an older style of boards. Glad to see more branching from the usual box.
Offline dskeeb
« Reply #49 on: Sat, 05 October 2024, 10:05:22 »
Finally registered so I can leave comments on this site and this is my second post.
The first prototype was so intriguing to me that I couldn't actually care if the bottom row was practical or not, first such thought for a keyboard for me. With the upcoming PBS MV Classic keycaps this keyboard would look even better.
I would had bought it for its aesthetic alone, at a reasonable price. Wish you nothing but success on your projects.
