Author Topic: [IC] flash 60% WKL | GB Closed  (Read 18522 times)
Offline keypport
« on: Mon, 12 September 2022, 11:17:28 »
60% WKL, Top Mount, 3.1kg
Check GB Thread
Flash is small but strong
As a fan of anime, I tried to melt the character's mood into the housing.
I designed it to be simple, but to reveal individuality.
It contains structural characteristics that I like.
Top mount, 8 deg, brass bottom, 3.1kg.
Specifications
Mount : Top Mount
Plate : Standard
Weight : 3.1kg (built)
Materials
Top case: A6061, anodized
Bottom case: Brass, sandblasted & clear-coated
Plate: A5052, anodized
Front Height & Typing Angle
Exploded View
Plate
Color: Gold color fixed.
Design Interpretation
1. Removed the screw around the spacebar, which presses harder when typing compared to other keys.
2. To reduce distance deviation, 5 screw holes are placed in a 'W' shape.
Brass Bottom
Why Use Brass?
The keyboard doesn't necessarily have to be heavy. Especially for gasket mounting.
However, heavy brass has the advantage of damping vibrations when using a foamless top mount.
Section Analysis
Reduced the gap between the floor and the PCB by raising the floor height except for switches, stabilizers, and small component locations.
Layout
60% WKL Fixed
For more details, check out the
Flash Official Document
IC form
Wishing those who do IC full of happiness
00:00 27th Sep - 23:59 29th Sep
(KST)
Price
As more people buy together, the price decreases in stages
Base kit
Alu Top
Brass Bottom
Screws and bumpons
*ADD-ONs are NOT INCLUDED
QTYPrice ($)
50~99300
100~199280
200~300260
MOQ : 50 units
MAX : 300 units
ADD-ONs
Solderable PCB : $45 -> $39
Daughterboard & JST cable: $10 -> $9
(Custom PCB and Daughterboard by Hiney)
Alu plate: $20
*Non-Korean buyers will be charged a 4.4% PayPal fee
Gift for Early Bird
The first 100 people participating in the Discord channel will receive an Alu Plate
and the 101st~200th entrants will receive a Daughterboard & JST Cable
✨ Touching the logo will summon you to KEYPPORT World ✨
Thank you to everyone who supported my project,
and I will do my best to provide you with a satisfying typing experience.
« Last Edit: Thu, 07 August 2025, 13:17:30 by keypport »
Offline The0rigina1
  • fumoposting
Re: [IC] Flash | 60% WKL, Top Mount, 3.1kg
« Reply #1 on: Mon, 12 September 2022, 11:31:11 »
I think the ano quality could still be better
Offline ankit
  • Formerly ankit-sachdeva
« Reply #2 on: Mon, 12 September 2022, 11:58:05 »
this is not an IC, you have pricing and sales date
by a soft cap of 50 do you mean an moq of 50?
Offline keypport
« Reply #3 on: Mon, 12 September 2022, 12:09:04 »
Yes. Soft cap stands for moq.
I wanted to get more feedback, so I uploaded it to IC. It can be changed.
Offline keypport
« Reply #4 on: Mon, 12 September 2022, 12:16:09 »
I'll ask for more samples of the anodized texture.
I would also consider the raw aluminum option as an alternative.
Offline treeleaf64
    • treeleaf64
« Reply #5 on: Mon, 12 September 2022, 12:24:40 »
Really like the back design, it is awesome,   Thank you for producing
I like brass bottom!
Yes improve anodization.
Ayaya!
Everyone must pay the cat tax
Offline The0rigina1
  • fumoposting
« Reply #6 on: Mon, 12 September 2022, 12:25:40 »
Soft cap really doesn't stand for moq.
Offline KeyBros_
« Reply #7 on: Mon, 12 September 2022, 13:13:07 »
Holy ****, these days I don't know if it's more complicated to do a project or to get people's definition of IC right.
Offline fortissim2
« Reply #8 on: Mon, 12 September 2022, 13:18:12 »
Looks good! GLWIC :)
Offline keypport
« Reply #9 on: Mon, 12 September 2022, 13:31:40 »
I thought everything should be fixed at the GB level.
I would like to improve through feedback.
Do you think this should be moved directly to GB?
Offline hemlock
« Reply #10 on: Mon, 12 September 2022, 13:46:01 »
These days people so butt hurt on whats considered an IC, smh.
Offline KeyBros_
« Reply #11 on: Mon, 12 September 2022, 14:08:06 »
No, I meant it looks like people is more focused in trying to tell what is an IC and what is not than enjoying the product or giving just feedback
Offline Nonnegaard
« Reply #12 on: Mon, 12 September 2022, 14:17:22 »
You post an IC, and you'll get one of two responses:
-"This is not an IC at all, you need to put some more effort it."
-"This is not an IC at all, there's no room for change at all."
Aeon, TGR Jane V2, Dolphin 2021, Gherkin, Model M, 5°, NCR80, M0110-A
Offline KeyBros_
« Reply #13 on: Mon, 12 September 2022, 14:27:39 »
Legit
Offline ankit
« Reply #14 on: Mon, 12 September 2022, 14:43:09 »
the original post is a gb post not an ic post
1. nowhere in the original post does the OP mention anything that they are looking for feedback on, they only mentioned it afterwards
2. there is no form, how is OP going to gauge interest without an IC form
3. it is not more difficult to post in the GB section, it’s literally the exact same process
4. 10 days is not enough time to make any meaningful changes and get new protos so why even IC at that point
hopefully that clears up my comment
Offline keypport
« Reply #15 on: Mon, 12 September 2022, 15:57:45 »
I understand.
I wrote "No" for other layouts and hotswap PCB support in the FAQ and set the price and schedule.
It's not just an IC that starts from rendering, and it's a project where my tastes are firmly fused.
But I wanted to talk about your favorite color or what material you would like to use for the aluminum plate (5052 or 6061), etc.
I agree that reply is insufficient space to accommodate many comments, so let's add a Google IC form.
Offline lewisflude
  • Hand Engineering
    • Hand Engineering
« Reply #16 on: Mon, 12 September 2022, 16:07:40 »
Looks great! Good luck with the IC
Mount points look nice :)
Have a nice day my friend
Offline keypport
« Reply #17 on: Mon, 12 September 2022, 17:09:35 »
Thank you.
Dalco was one of my wannabes.
Offline Nuap
« Reply #18 on: Mon, 12 September 2022, 18:44:42 »
What's up with that layout? Are you sure that you're splitting right shift the correct way?
« Last Edit: Mon, 12 September 2022, 18:57:00 by Nuap »
Offline keypport
« Reply #19 on: Tue, 13 September 2022, 00:01:06 »
Thanks for pointing out
The splitting right shift needs to be changed.
Edited.
Offline keypport
« Reply #20 on: Tue, 13 September 2022, 02:24:02 »
IC form added.
« Reply #21 on: Tue, 13 September 2022, 12:44:55 »
Offline KeyBros_
« Reply #22 on: Tue, 13 September 2022, 14:36:41 »
what
Offline The0rigina1
  • fumoposting
« Reply #23 on: Wed, 14 September 2022, 04:13:30 »
discourse and group you can't be serious LMFAO
Offline syntxtypes
« Reply #24 on: Wed, 14 September 2022, 05:50:34 »
i love geekhack
Offline keypport
« Reply #25 on: Thu, 15 September 2022, 17:00:57 »
Regarding anodizing
I got feedback on the rough texture of the anodizing I produced as a prototype.
I contacted the factories to solve the problem.
This is a color sample.
Flash to be manufactured will be smoother than the sample.
Offline keypport
« Reply #26 on: Thu, 15 September 2022, 17:06:59 »
Finally, yellow was added.
Offline hemlock
« Reply #27 on: Thu, 15 September 2022, 22:25:30 »
That one fake friend whos nice in person but talk **** behind your back.
Offline keypport
« Reply #28 on: Fri, 16 September 2022, 00:19:44 »
He is a funny friend.
His brain seems to be fixed with two types of mounting.
Offline KeyBros_
« Reply #29 on: Fri, 16 September 2022, 00:46:49 »
LOL.
Offline Jefff
    • jlabs.co
« Reply #30 on: Fri, 16 September 2022, 19:28:10 »
This is literally just a GB post... You already have pricing and a sale date.
Offline keypport
« Reply #31 on: Sun, 18 September 2022, 02:51:30 »
Yes. Based on the feedback received from IC, the contents of the GB were confirmed.
Now waiting for moderator's GB thread approval.
Offline Nuap
« Reply #32 on: Sun, 18 September 2022, 06:57:21 »
How do the GB price brackets work? Will you refund orders when a lower price is reached?
Offline keypport
« Reply #33 on: Sun, 18 September 2022, 09:09:14 »
Updated.
The base kit sells for $300.
Additional discounts will be applied to shipping charges after global sales are aggregated.
For example, if more than 200 units are sold, you will be charged $0 shipping for East Asia and SEA, and $20 shipping for NA, EU and Oceania regions.
« Last Edit: Sun, 18 September 2022, 23:21:08 by keypport »
Offline keypport
« Reply #34 on: Tue, 20 September 2022, 13:15:21 »
GB thread opened.
Sale Time
00:00 27th Sep - 23:59 29th Sep (KST)
Offline keypport
Re: [IC] Flash 60% WKL | GB 27th Sep - 29th Sep
« Reply #35 on: Sat, 24 September 2022, 04:15:29 »
Updated PCB Price
Flash's PCB is yellow and has a small keypport character logo on it.
To keep the price down, I started H60 JST Group Buy for Koreans.
The changed prices are as follows:
Solderable PCB:  $45 -> $39
« Last Edit: Sat, 24 September 2022, 10:58:32 by keypport »
Offline keypport
« Reply #36 on: Mon, 26 September 2022, 11:40:47 »
Flash GB started.
27th Sep - 29th Sep
