Author Topic: ZERO-G x JWK Balance Linear Switch  (Read 22776 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
« on: Thu, 15 September 2022, 01:56:24 »
ZERO-G Balance Linear Switch
Balance Linear switch features ZERO-G GIFT theme colour scheme.
Blue and pink stem with ZERO-G's cream covers looks like mouth-watering candy.
SPEC
- Linear switch
- P3 stem
- upper and lower cover PA66
- 18mm gold plated spring
- advanced length stem
- Operating force 48.5g
- Total force 63.5g
- pre-travel 2mm
- Actuator travel 3.8mm
- approx. 50 million clicks
JOIN NOW
« Last Edit: Mon, 24 October 2022, 03:04:35 by KPrepublic »
Offline KPrepublic
  • * Moderator
    • KPrepublic
Re: [GB] ZERO-G Balance Linear Switch
« Reply #1 on: Thu, 15 September 2022, 01:56:43 »
Offline fortissim2
« Reply #2 on: Thu, 15 September 2022, 13:25:50 »
Looks promising. But another 63.5g linear and I'm going to crap my pants.
Offline KPrepublic
  • * Moderator
    • KPrepublic
« Reply #3 on: Sun, 18 September 2022, 00:05:13 »
If you like it, don't hesitate take it. : )
Offline Nuap
« Reply #4 on: Sun, 18 September 2022, 00:37:25 »
Am I reading the chart right? The forces are plus or minus 20 gf? Does this mean that in a single batch some could be 45 grams and others could be 80 grams? Even cheap Gateron's are +/- 15gf.
Offline KPrepublic
  • * Moderator
    • KPrepublic
« Reply #5 on: Sun, 18 September 2022, 22:16:36 »
The info is from the author.
We follow the info what they provide to us :  )
