Author Topic: [GB]Class80 by MM Studio-We're coming!- Finished  (Read 6378 times)
Offline Totoro
« on: Wed, 21 September 2022, 03:28:02 »
Hello, everyone! This is MM studio.
Sorry we're late, But good stuff takes time!
GB Information
  • Sales Date:
     September 25th 2022, 08:00 GMT+0 to October 25th 2022, 12:00 GMT+0
  • Quantity: unlimited group buy
  • Colors: Retro E-White, Retro E-Red, Ano-Black
  • Fulfilment: 90-120 days after GB concludes
  • Prices:
    Wired standard kit: $345 USD
    Bluetooth standard kit: $375 USD
  • Vendors:
United States: https://epomaker.com
Korea:
                 Wired version: https://www.monstargears.com/46
              BLE version:  https://mmstudio.store/
              (due to Bluetooth module import restriction in Korea)
Australia: https://www.switchkeys.com.au/
Europe: https://mykeyboard.eu/
United Kingdom: https://keebcats.co.uk/
Canada: https://www.ashkeebs.com/
Japan:https://basekeys.jp
Vietnam: https://mokbstore.com/
Thailand: https://ntchkeys.com/
Philippines: https://zionstudios.ph/
Indonesia: https://instagram.com/curatedbykwok
Singapore: https://hexkeyboards.com/】
Malaysia:https://www.rebultkeyboards.com/
Taiwan: https://www.inpad.com.tw/
Others: https://mmstudio.store/
Reviews & Builds:
MORE REVIEWS INCOMING!
(Alexotos, Badseed Tech, Hipyo, 3ildcat, DBOKEY, Shoobs.. Just to name a few  ;))
About Class80:
The Class80 builds on the big bezel design of the Class65 and intensify the chonk.
It measures 39.34cm*18.9cm and the big boy weighs about 3.5kg unbuilt.
In addition, we made a 1.6cm slope on the front edge to make the typing angle of the board to 7°.
Colors:
we retained the much loved retro E-white and Ano-black of the Class65
and added a FAMICOM inspired E-Red to the selection.
Layout:
Select between WK or WKL
  • Hot-swap PCB only supports ANSI and 7U spacebar Tsangan, stepped caps is possible;
  • Soldered PCB supports 6.25U spacebar, 1.25 mods or Tsangan, stepped caps, ANSI or ISO both supported.
Plate support details can be checked here
PCB:
The new double “S” on the PCB leaf-spring-mount retains the ultra-soft typing experience of the original class65
but also allows the PCB to be top mounted.
We will offer both Wired and Bluetooth Version of the PCB, wired PCB supports QMK and VIA,
Bluetooth software support is provided by Dana through the program LDN .
For wired PCB, there are Hot-swap and soldered version, the Bluetooth PCB only comes with Hot-swap.
(Class80 firmware:download here )
The Bluetooth version comes with a 5000mAh battery included in the kit.
Mounting styles:
the Class80 supports 3 different mounting styles
  • Top mount with plate
  • PCB gasket mount with plate
  • PCB gasket mount plateless
We highly recommend you trying out the plateless build, it’s amazing if you like some flex.
Plate:
Standard kit comes with PC plate and only supports PCB mounted stabs.
Extra Plates comes in 10 variations which can be purchased separately here
Buzzer & Solenoid:
The standard wired kit includes the Buzzer and Solenoid.
Unfortunately, the Bluetooth PCB can’t be used with the buzzer and solenoid,
so we excluded the parts from the Bluetooth kit to reduce the cost.
On the backside of the bottom case, there is a switch with 3 stages: Left-Off, Middle-Buzzer, Right-Solenoid.
The Buzzer and Solenoid can’t be used at the same time, stop trying to get fired.
Sticker Badge:
For even more retro feel, we added a "Class80" sticker badge made out of stainless steel to the standard kit,
which you can freely choose where to stick it on your class80.
Carrying Case:
Last but not least, we included a keyboard carrying case to the standard kit,
since we know it’s not easy to find a case for a such chonky boy. You are welcome.
Standard Kits List:
  • Alu keyboard case
  • E-white&red FC controller weight(Alu)
  • Plate:1.5mm PCB-Mount stabilizer Plate-PC(One PCB-Mount stabilizer Plate-PC is included in the kit. If you need other plate, you can buy extra)
  • Plate foam: 5mm+3.5mm poron plate foam
  • Switch foam: 0.5mm ixpe
  • PCB:Solder/Hot-swap/ LDN BLE (Hot-swap)
  • Type-c Ai03 daughter board
  • Case foam and battery room foam:poron
  • Gasket poron
  • Bumpons
  • Screws and tools
  • Solenoid and Buzzer(Wired version only)
  • 5000 mAh Battery (BLE version only)
  • Class80 Sticker Badge
  • Carrying Case
Extras
Keycaps: $45
A set of retro inspired keycaps set as optional extras can be purchased with the Class80
(Not included in the standard kit).The color is close to GMK L9 and U9.
Extra PCB (Presented Gasket )
  • Wired Soldering PCB: $45
  • Wired Hot-swap PCB: $45
  • BLE Hot-swap PCB: $75
PC Plate
  • Plate-Mount stabilizer Plate-PC(ansi only): $25
  • PCB-Mount stabilizer Plate-PC(iso/ansi) : $25
Black core FR4 Plate
  • Plate-Mount stabilizer Plate-FR4(ansi only): $25
  • PCB-Mount stabilizer Plate-FR4(iso/ansi): $25
  • (Half plate)Plate-Mount stabilizer Plate-FR4(ansi only) : $25
  • (Half plate)PCB-Mount Stabilizer Plate-FR4(iso/ansi): $25
Brass Plate
  • Plate-Mount stabilizer Plate-Brass(ansi only): $42
  • PCB-Mount stabilizer Plate-Brass(iso/ansi): $42
  • (Half plate)Plate-Mount stabilizer Plate-Brass(ansi only) : $42
  • (Half plate)PCB-Mount Stabilizer Plate-Brass(iso/ansi): $42
Extra FC controller weight(Alu): $25
Indicator Light Module(Optional): $20
Extra Foam Kit(Optional): $15
  • 5mm plate foam*1
  • 3.5mm plate foam*1
  • 0.5mm PE sheet*1
  • 2mm hot-swap case foam*1
  • 1mm case foam*2
  • Battrey room foam*1
Extra Tools and others(Optional): $5
  • Gasket poron
  • Screws and Drivers
  • Bumpons
  • Type-C daughter board
Shipping:
Shipping from MM Studio Store: According to the actual transportation cost
Shipping from regional vendors: please check your vendor’s conditions
For Class65V2 buyers:
 The controller weight are compatible with the Class80.
If you don’t want a new controller weight, you can contact us to deduct the price by the cost of the controller weight
(just to make sure: of course, you won’t get a new controller weight with the Class80 in this case)
Please join our DISCORD to get more update, you are very welcome to join our small community!
« Last Edit: Sun, 19 November 2023, 19:15:18 by Totoro »
Offline made in China
Re: [GB]Class80 by MM Studio-We're coming!
« Reply #1 on: Sat, 08 October 2022, 21:26:16 »
like E-Red
