Author Topic: [IC] Q66 Hot-Swap Mechanical Keyboard DIY Kit  (Read 5006 times)
Offline Kelley Kenny
« on: Fri, 30 September 2022, 08:10:02 »
https://iqunix.store/products/q66-mechanical-keyboard-hot-swap-diy-kit
Specifications
Layout: 65%, 66 keys
PCB: Hot Swappable, QMK, VIA support
Case Material: Aluminum
Structure: Gasket Mount
Larger Keys Style: PCB Mounted Screw-In Stabilizers
What's in the box
Keyboard Case x1, PCBA x1, Aluminum Plate x1, PCB Foam x1, Case Foam x1, Gaskets Set x1, Cherry Stabs Kit x1, Screws Set x1, Screwdriver x1, Screw Heads x3, USB-C Cable x1
[/size]
« Last Edit: Wed, 23 November 2022, 02:00:52 by Kelley Kenny »
Offline Rafa_n
  • stuffforrectangles.etsy.com
Re: Q66 Hot-Swap Mechanical Keyboard DIY Kit
« Reply #1 on: Fri, 30 September 2022, 08:11:39 »
Reserved
Re: [IC] Q66 Hot-Swap Mechanical Keyboard DIY Kit
« Reply #2 on: Wed, 23 November 2022, 01:59:20 »
 Group buy will end soon.
« Last Edit: Wed, 23 November 2022, 02:01:58 by Kelley Kenny »
