Author Topic: Looking for full sized keyboard with no gap above arrows  (Read 9498 times)
Offline muidlos
« on: Sun, 02 October 2022, 20:33:01 »
Hello!
I am looking for a mechanical keyboard with a specific layout, where there is no gap between the arrows and the keys above (PGUP, PGDN, DEL etc...). I know this is a very weird and specfic question, but I thought maybe someone knows a mechanical keyboard like that.
Here is a picture of what I mean:
One important thing to note is that it needs to have the numeric pad as well, so a full sized mechanical keyboard.
In case you're wondering why I need this, I've been playing FPS games for almost 2 decades with those keybinds and I'm just so used to it. But I would like to play on a mechanical keyboard. I just can't switch to WASD. I found several membrane keyboards with this layout, but couldn't find a mechanical one.
Thank you!
Offline Morbii
Re: Looking for full sized keyboard with no gap above arrows
« Reply #1 on: Mon, 03 October 2022, 05:11:25 »
You may want to consider getting an ortholinear for a gaming pad.
Offline OctaneMike
« Reply #2 on: Tue, 13 February 2024, 12:22:02 »
Where you able to find keyboards like this?? I have the same problem as you.
Offline TomahawkLabs
« Reply #3 on: Tue, 13 February 2024, 12:37:52 »
This would be the perfect way to learn how to handwire your own board. Go to KLE, paste the blow into the "raw" field and find a company to cut you a sandwich case. Find yourself a Microcontroller with 27+ GPIO and handwire it following any of the guides online. What you are describing would be so incredibly niche that you would only find that in a small run group buy or if someone like yourself designed a PCB and had extras. The plate/case would be 100% custom because it's non-standard which is why you wouldn't find any off the shelf PCBs/Cases.
["Esc",{x:1},"F1","F2","F3","F4",{x:0.5},"F5","F6","F7","F8",{x:0.5},"F9","F10","F11","F12",{x:0.25},"PrtSc","Scroll Lock","Pause\nBreak"],
[{y:0.5},"~\n`","!\n1","@\n2","#\n3","$\n4","%\n5","^\n6","&\n7","*\n8","(\n9",")\n0","_\n-","+\n=",{w:2},"Backspace",{x:0.25},"Insert","Home","PgUp",{x:0.25},"Num Lock","/","*","-"],
[{w:1.5},"Tab","Q","W","E","R","T","Y","U","I","O","P","{\n[","}\n]",{w:1.5},"|\n\\",{x:0.25},"Delete","End","PgDn",{x:0.25},"7\nHome","8\n↑","9\nPgUp",{h:2},"+"],
[{w:1.75},"Caps Lock","A","S","D","F","G","H","J","K","L",":\n;","\"\n'",{w:2.25},"Enter",{x:0.25,a:7},"","","",{x:0.25,a:4},"4\n←","5","6\n→"],
[{w:2.25},"Shift","Z","X","C","V","B","N","M","<\n,",">\n.","?\n/",{w:2.75},"Shift",{x:0.25,a:7},"",{a:4},"↑",{a:7},"",{x:0.25,a:4},"1\nEnd","2\n↓","3\nPgDn",{h:2},"Enter"],
[{w:1.25},"Ctrl",{w:1.25},"Win",{w:1.25},"Alt",{a:7,w:6.25},"",{a:4,w:1.25},"Alt",{w:1.25},"Win",{w:1.25},"Menu",{w:1.25},"Ctrl",{x:0.25},"←","↓","→",{x:0.25,w:2},"0\nIns",".\nDel"]
Always looking for Alps SKCM/SKCL switches. Feel free to DM.
AMD 5600x | RTX3080 | 2x 1TB NVME + 4x 4TB HDD | B550M Pro-P | 32GB RAM | RM850x | Node 804 | Schiit Modius/Magnius + Audeze LCD-2 | 2x Dell S3422DWG
GMMK 1 Full Size Barebones | Zealio 67g ; Apple M3501 handwired | Alps SKCM Damped Cream
SA: Camping
Offline TWX
« Reply #4 on: Fri, 16 February 2024, 11:28:55 »
Just thinking about what I've worked with over a lifetime in IT, if you don't want to go full custom or rubberdome then you may end up having to source a point-of-sale keyboard:
306196-0
Image gratuitously stolen from Reddit
and then work on remapping keystrokes in software.
Also for what it's worth, there are a lot of complaints about the layout that you're looking into, apparently the power key is so close to commonly used keys like bksp that a lot of people end up prompting to shutdown or else shutting down their computers when using it.
There were some terminal keyboards whose arrow keys are closer to the six-block, but this was achieved by moving-up the arrows, not moving-down the six-block, and the functions of the six-block are not the same.  They also lack most of the modifier keys, and sometimes even lack keys like Esc.  For what it's worth I've been tempted to make a WYSE-85 work as a PC keyboard but in reality the only real advantage in doing that would be the nifty-factor for having something never meant to be a PC keyboard drive a PC.  It would mostly just be a hassle.
TWX
C:\>echo y|format C: /q
Offline wjrii
« Reply #5 on: Sat, 17 February 2024, 14:35:40 »
It seems like your preferred 107-key layout is not readily available as a mechanical keyboard, though if the layout is truly the important thing, Amazon does still have a couple of 107 key membrane keyboards for cheap that will match what you need.  It's also not super hard to have a couple of plates cut, and then get some brass standoffs, some soldering supplies, some switches and keycaps, and a Raspberry Pi Pico or Pro Micro to make a simple sandwich custom.  It is a project though, no two ways about that.
To go a bit farther off the beaten path, the legendary IBM F series came in a rare 107 key variant that could be modified to work for you, though that's a whole other rabbit hole of time, effort, and expense.  Finally, if you are willing to roll with an external numpad and be flexible with keycap legends or get a flat profile (i.e. no variation in shape between different rows), the Keychron K13 is a nice low-profile option that could be remapped (be careful on keycap sets here), . Its downmarket regular-height gamerboard cousins the Redragon K636 and E-Yooso Z19 can as well, though only with redragon software. They all have enough keys in an ortholinear block on the right side to recreate your layout, sans numpad, and with a couple of extras.
« Last Edit: Sat, 17 February 2024, 16:46:32 by wjrii »
