Author Topic: Request for comments on a modified MTGAP layout  (Read 46561 times)
Offline zunbid
« on: Sun, 09 October 2022, 04:55:23 »
== Motivation ==
After trying DVORAK and COLEMAK-dh I ended up enjoying the finger rolling of the MTGAP layout. BUT while learning the MTGAP I got annoyed by the position of the 'M' and 'W' keys.
== The Layout ==
Link to Oryx configurator with layout https://configure.zsa.io/ergodox-ez/layouts/NpdQX/latest/1
Config file for genkey analyser:
Code: [Select]
MTGAPmw
j p o u x k d l c q
i n e a , v h t s r
y b z . ; / f m g w
0 1 2 3 3 4 4 5 6 7
0 1 2 3 3 4 4 5 6 7
0 1 2 3 3 4 4 5 6 7
== Setup ==
I developed this layout on my ergodox. The layout might work better on ortholinear/matrix keyboards.
I used https://semilin.github.io/genkey/ analyser to help me tweak the layout.
This layout also scored on TOP for some input on these analysers:
http://patorjk.com/keyboard-layout-analyzer/#/main
https://stevep99.github.io/keyboard-layout-analyzer/#/main
== Request ==
If you use MTGAP or another layout focused on rolling fingers give this layout a try.
Also if you know of better/more popular layout analysers, check and share the results of this layout. Or just share the analysers so I can run them myself.
« Last Edit: Sun, 09 October 2022, 07:24:28 by zunbid »
Offline macroxue
    • Darknight: DIY 60% Split Keyboard
Re: Request for comments on a modified MTGAP layout
« Reply #1 on: Sat, 29 October 2022, 10:18:21 »
The layout looks quite good for two key reasons.
  • Alternating hands by having all the vowels and some low-frequency consonants on one side.
  • Reduced lateral movements by de-emphasizing the two middle columns.
With that said, the only weakness seems to be N, a high-frequency consonant, being on the same side as the vowels. You can try "opinion anyone" and see my point.
[Darknight: DIY 60% Split Keyboard](https://github.com/macroxue/keyboard-diy)
