Author Topic: Swap [Esc] and [~] on XD68 PCB  (Read 37625 times)
Offline BlackBeard637
« on: Fri, 14 October 2022, 13:21:15 »
Hi all! I assembled my first custom keyboard on pcb from KPrepublik XD68.
Faced a problem. By default [~] (top left key) works like [ESC].
For type a [`] = [Fn] + [ESC]
For type a [~] = [Fn] + [Shift] + [ESC] - and that's horrible
I want to make it work like a [~] by default, and:
For type a [`] = [Shift] + [ESC]
For run [ESC] = [Fn] + [ESC]
I have tried adjusting the values in keyboard-layout-editor.com and flash keyboard through xd.tkg.io like this:
"Esc\n\n\n\n~\n`" - default setting
"~\n\n\n\nEsc\n`" - the combination i tried
But xd.tkg.io does not accept such a combination with error "no maching key"
What am I doing wrong? Or is there any way to customize the key the way I want?
« Last Edit: Fri, 14 October 2022, 13:50:25 by BlackBeard637 »
Re: Swap [Esc] and [~] on XD68 PCB
« Reply #1 on: Fri, 14 October 2022, 18:21:28 »
Solved  :D
"~\n`\n\n\nEsc"
