Author Topic: [IC] AM AFA | Adjustable Flex Alice keyboard  (Read 13014 times)
Offline Crazy Designers
    • Angry Miao Official Website
« on: Wed, 26 October 2022, 05:26:41 »
AM AFA by Angry Miao
Crazy Designers here. It took a lot of effort to get to this point but here it is: AM AFA, the world's first keyboard with three-stage Adjustable Leaf-Spring Mount. Earlier on, we talked a bit about this keyboard before (it was called AM AGA back then), but here it is in its final form.
IC Form: https://forms.gle/JTbYzdY9qioN8rce7
292606-0
292608-1
292610-2 292612-3
Details
Keyboard Inclination Angle: 6.5°
Tenting Angle: 5.0°
Material: aluminum body with stainless steel front panel, anodized / electrophoretic / baked paint
Mounting method: Adjustable Leaf-Spring Mount (three-stage adjustable flex, 18 typing combos)
Plate: POM plate (FR4 optional)
LEDs: PCB lighting, in-switch RGB LEDs
PCB: 1.2mm 4-layer hotswap PCB with cutouts, with left and right side separated, PCB lighting, in-switch LEDs and key layout configurable via Angry Miao DIY site
Connectivity: Bluetooth 5.0, wired (USB Type-C, supports C to C), wireless charging
Dimensions: 445.7*156.5*56.5mm (front height: 22.5-36mm)
Weight: Base Kit 2.00kg, Bundle 2.25kg
Layout:
292614-4
Vendors
Pre-order: November 1, 2022 at 9:00 AM PDT on angrymiao.com (estimated shipping date mid to late December)
Price: Base Kit 680 USD, Bundle 795 USD
Also available through the following vendors, sale date and shipping date is subject to vendor's separate notification.
Inspired by Macross Plus VF-19
292616-5
Macross is one of our favorite animes, and we're especially fans of the VF-series variable fighters designed by Masaharu Kawamori. The VF-19, a fighter with a forward-swept wing design, is where AM AFA takes its inspiration from. With 4 unique colorways and a hollow aluminum frame crafted using 5-axis CNC, AM AFA takes design, construction and craftsmanship to the next level.
292618-6
VF-19 Advance - inspired by the VF-19 Advance variable fighter from Macross.
292620-7
The Dark Night - inspired by Batman.
292622-8
Ranger - inspired by Ranger, the futuristic sci-fi spaceship from the movie Interstellar.
292624-9
Velocity - inspired by the Bertone Stratos B A X concept car design from Hollywood-based concept designer Shane Baxley.
292626-10
AM AFA uses a hollow metal frame crafted using 5-axis CNC high-precision machinery. Hollowing out its metal frame takes more than 7 hours. Its smooth edges are carefully cut and polished. Combined with 2-hour manual grinding and sandblasting of each single piece, AM AFA's sophisticated craftsmanship adds a soft touch to its sharp appearance.
292628-11 292630-12
Gradually taking shape from a whole block of aluminum alloy - forming the metal frame takes over 9 hours.
First keyboard with three-stage adjustable flex
292632-13
Everyone's preference is different when it comes to keyboard flex. Some prefer soft, some prefer hard. And for some users, their preference will change over time. While often this would be an excuse to go out and buy a new keyboard, this is no longer the case with AM AFA's three-stage Adjustable Leaf-Spring Mount.
292634-14 292636-15
While developing our three-stage Adjustable Leaf-Spring Mount, we looked at the automotive industry, who has already figured it out. Öhlins Height Adjustable Coilovers, such as those found on the BMW M6 GT3, feature rebound adjustment in two directions, which we also aimed for with AM AFA.
292638-16 292640-17
AM AFA comes with 2 kinds of leaf-springs, 3 adjustable "Gears" each, and 3 ways to use pads, allowing for a total of 18 typing combos. The extend of the rebound can be modified by adjusting the position of the rubber stopper under the leaf-spring, providing three distinct types of feel through the use of "Gears". Their respective adjustment levels are 3.5mm, 2mm and 0.5mm.
292642-18 292644-19
We also provide the possibility to adjust rebound strength, through the use of two different leaf-spring materials, namely phosphorus copper and stainless steel, which are included in the box. This increases the total amount of typing combos to 18.
Two separate keyboards combined into one
292646-20 292648-21
One big advantage of Alice is that we take advantage of its layout to separate the PCB and plate. The smaller the area, the easier it is to achieve a consistent and stable feel. Therefore, we fully separated the PCBs from the mainboard. They're exactly the same size on both sides, so that we can achieve a unified feel.
292650-22 292652-23
We take this one step further by creating two separate "key boxes". This basically means that AM AFA consists of two individual keyboards. Each key box contains a PCB, plate, adjustable leaf-springs and pads.
292654-24
Everything that's unrelated to feel and typing sound has been removed from the key boxes, such as the mainboard, battery and wireless charging coil.
292656-25
Custom RGB lighting and keymaps
292658-26
AM AFA lights up much like how an aircraft lights up the runway. Of course, in-switch LEDs are also present. With full customization support on our DIY site.
292660-27
Key remapping is also supported with AM AFA. Create your own custom keymaps through Angry Miao's DIY site. All keys can be edited except the FN key!
292697-28
Of course, we're aware you would like to see QMK/VIA compatibility. We would like to see it too! But the reality is, QMK doesn't support high-performance Bluetooth connectivity. That's why we developed our own Bluetooth control system based on Nordic Semiconductor's Bluetooth module. Unfortunately, VIA is closed source and therefore there's no way to modify it to be able to take advantage of our improved Bluetooth system.
But we do hear your voice. In the near future we are planning to develop a native desktop application similar to VIA to replace the current DIY remapping web tool.
Hover
292662-29
AM AFA is relatively high on the front, which means it's best used in combination with a wrist rest. That's why we came up with Hover, an ergonomic maglev wrist rest, which perfectly matches the front height of AM AFA. And at the same time, they add a new dimension of flexibility to your wrist.
We're looking forward to hear what you think in the comments and IC form. See you on November 1, 2022 at 9:00 AM PDT!
« Last Edit: Mon, 31 October 2022, 06:39:14 by Crazy Designers »
Angry Miao Team. Future Art Community.
Offline whirlwind
Re: [IC] AM AFA | Adjustable Flex Alice keyboard
« Reply #1 on: Wed, 26 October 2022, 06:25:47 »
How many more ICs are you going to make about this lol
Offline nostr
« Reply #2 on: Wed, 26 October 2022, 06:27:23 »
Split backspace compatibility with solder pcb possible?
Offline Rafa_n
  • stuffforrectangles.etsy.com
« Reply #3 on: Wed, 26 October 2022, 07:28:26 »
I still prefer you 65% "hhkb" with ful backspace
Offline nu_types
  • Formerly Iredeus
« Reply #4 on: Wed, 26 October 2022, 08:13:12 »
You guys already posted an IC for this board. This should have just been a GB post since the pre-order is next week.
Offline niicao
« Reply #5 on: Wed, 26 October 2022, 08:55:37 »
why are you making an adjustable flex alice when your pcb has individual flex cuts for each switch, no matter how stiff the configuration is, it will still have a **** ton of flex. all the designs you do basically look like concept designs, they are pricey, exagerated in all possible ways and have features that aren't really useful. don't get me wrong, the innovation is key, but it needs to be useful and not just do it for the sake of doing it.
Offline Keeblet_257
« Reply #6 on: Wed, 26 October 2022, 12:54:34 »
oh fck yeah another project
lemme just list all the good things about this project:
-no solder/hs only
-no layout options
-cant remap keys
-POM plate forced so if you want the only other plate option you get cucked into buying FR4 from add ons
- "anodized / electrophoretic / baked paint" wow, didnt knew that you can anodie color and then paint stuff with it
-900€ or more depending on Mykeyboard
- "With 4 unique colorways" and proceeds to offer a full black unit, very unique colorway man
« Reply #7 on: Thu, 27 October 2022, 05:37:34 »
Yes, this is possible. However, since time is limited and we want to make sure that first and foremost hot-swap and in-switch LEDs are supported. So, split backspace and solder PCB are currently not supported.
The current designs are not just concepts, but the result of co-creation with our community.
Our beta testers worked with us to test out our cutout PCB with leaf-spring mount combination. They helped us to fine-tune the setup and make sure rebound and elasticity are top-notch. Even when using a cutout PCB, there are some users who require a stiffer feel and some users who require more flex. Both designs work hand-in-hand and are the result of repeated testing, not just some random ideas.
When configuring the hardest setup of our adjustable flex system, AM AFA's adjustable leaf-spring mount can achieve a feel similar to a top mount.
-cant remap keys
Keys can be remapped and in-switch LED customization is also possible.
After thoroughly testing AM AFA together with our community, we believe the sound and feel of a POM plate is the best fit. Still, we offer FR4 for those who prefer it.
It's 680 USD for the Base Kit and 795 USD for the Bundle on angrymiao.com.
Offline Mecxs
« Reply #8 on: Thu, 27 October 2022, 06:17:32 »
Hi, yes. What exactly the **** do you mean by this?
Are you trying to say that the wrist-rest will allow me to bend my wrist in a direction that I was previously not able to bend it in? Because that is not healthy.
Offline mr_foggy
  • neue = nope
« Reply #9 on: Thu, 27 October 2022, 08:45:05 »
you have a point: either get screwed by custom or get screwed by mykeyboard's pricing policies lmfao
board looks ungodly anyway
Offline hottrout
  • I'd Hit Dat Key
« Reply #10 on: Fri, 28 October 2022, 11:15:16 »
The spacing between each is interesting.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
