Author Topic: [IC] Spilled Dragon Round 2 - Waterproof, 5mm; Vendors Assembling  (Read 22745 times)
Offline Skeil
  • I drink art and draw coffee
Spilled Dragon R2
Introduction
The return of Spilled Dragon.
"Inspired by the tragical experience of spilling a drink onto your desk, Spilled Dragon is a deskmat series that combines organical liquid shapes and draconical motifs."
Check out the IC forms below:
IC FORM
Hello! This is skeil, welcome to the interest check for the Round 2 of Spilled Dragon.
As with other runs, I will discern the popularity of each design through votes for a week or two and then proceed to order samples to discern the quality of the deskmat and the design.
The R2 of Spilled Dragon will feature two bestsellers from the previous round.
On top of that, you can choose 3 new unique colorways which will be available for purchase for this round.
You can also choose between 4mm or 5mm thickness options.
As a bonus, you can choose if the combination of the previous colorways will make it into the group buy stage!
This round will be manufactured by Wuque Studios, and will offer spill-proof technology.
A match made in heaven.
Colorways
Full album
White Ink
Blueberry Smoothie || Orchid
Nebula || Underwater
BONUS: COMBINED R1 COLORWAY
Info
Group Buy: TBA
Production, shipping to vendors: 2-3 months
Shipping to you: TBA
Specs
- 900 x 400 mm in size, 4mm OR 5mm in thickness
- Stitched edges
- Smooth cloth surface
- Rubber Bottom
- Machine/Hand Washable
- Waterproof Surface
Vendors / Pricing
USA: TBA
Canada: Mech.land
Philippines: Zion Studios
Singapore: iLumkb
Taiwan: Inpad
EU: Keygem
AU: Keebn Z Cables
UK: Proto[Typist]
Worldwide: Wuque Studios
Crossposts
https://www.reddit.com/r/mechmarket/comments/yerhih/ic_spilled_dragon_round_2_waterproof_5mm_new/
https://www.reddit.com/r/MechanicalKeyboards/comments/yere9u/ic_spilled_dragon_round_2_waterproof_5mm_new/
Contact
Discord:
Change Log
10/27/2021 - IC Launch
Huge thanks to
KeebAad, Laminar, Noxious, Cere, Tom, Ty, acitrin, and many, many others for being supportive beans
Support Banner
Code: [Select]
[url=https://geekhack.org/index.php?topic=118694.0] [img width=265 height=116]https://i.imgur.com/ovOD2Kh.png[/img][/url]
« Last Edit: Mon, 03 June 2024, 05:41:37 by Skeil »
Offline TyPo.mk
Re: [IC] Spilled Dragon Round 2 - Waterproof, 5mm, New Colorways
« Reply #1 on: Thu, 27 October 2022, 07:17:08 »
Good luck with round 2! 5mm is pretty thiccc
Offline Antivity
  • Keycap Designer
« Reply #2 on: Thu, 27 October 2022, 08:20:46 »
Looking forward to being able to add this to my setup! GLWIC
Offline Hawkenfreude
« Reply #3 on: Thu, 27 October 2022, 14:56:29 »
Love that you're even considering using the combined colorway design. Good luck!
Offline Skeil
« Reply #4 on: Fri, 28 October 2022, 05:08:05 »
Appreciate the kind words :D
Offline Skeil
« Reply #5 on: Mon, 03 June 2024, 05:41:18 »
UPDATE: 06.03.24
Colorways chosen, thickness chosen and vendors are assembling
Hi friends! It has been a while!
After a bit of a hiatus I'm continuing through with this group buy. As for now I plan to offer 6 colorways to purchase with 5 mm thickness (as per poll results).
IC FORM
I would love if you could take your time and fill a second interest form to discern which of the 6 colorways is the most desirable. As of this moment I'm finalizing the vendor list and making final preparations for the GB. Stay tuned for updates  :D
