Author Topic: [IC] Aaru65 by Helix Lab | GB start on 4th July  (Read 29621 times)
Offline ClickClack.io
  • Find us on clickclack.io
    • clickclack.io
« on: Fri, 28 October 2022, 23:51:10 »
Aaru65 (Aten)
Designed by Helix Lab
Index
- Intro
- Design
- Structure
- PCB and Layouts
- Slider Module
- Colorways
- Specification
- Q&A
- IC Forms & Discord
Intro
Welcome back to another ClickClack-run project! This time we’re delighted to introduce a collaboration with Helix Lab – the Aaru65, codenamed Aten! It’s a project inspired by ancient Egyptian mythology.
Design
▲ The embossment on the Aaru65 continues after the Aaru TKL and Ankh Numpad projects as well, this time embossing the 6th and 7th row of the Rosetta Stone onto the keyboard.
▲ The weight and slider cap for this board are designed around the Egyptian Scarab, the dung beetle, a famous figure that has featured a lot within Egyptian culture and mythology. Its popularity comes from the dung beetle’s rolling of dungballs that had a symbolic likeness to the sun god Ra, who rolled the sun across the sky. Hence the board is named “Aten”, the name of the disk of the Sun in ancient Egyptian.
▼ The weight is surface treated with different processes – the beetle itself is PVD coated and mirror polished, while the background is sandblasted. Two different weight designs will be offered to choose from in the GB.
▼ The weight is surface treated with PVD coated and mirror polished. Two different weight designs will be offered to choose from in the GB. (Due to the low weight production yield for dual process weight, the entire weight piece will be PVD Mirror.)
▲ The back side, where the type-C port is located, consists of two frames, decorated uniquely. The upper one is engraved with the same hieroglyphs as on the Aaru TKL – a nod to our old project. The lower bar is PVD coated, with an engraved "Aaru" logo.
Structure
▲ Aaru65 uses a gasket mount, using custom-made silicon foam and pre-cut holes to align the plate as well as mitigate sideways movement.
PCB and Layouts
▼ PCB has two option, both use QMK firmware and are VIA compatible:
└ Hotswap: ANSI layout, 6.25u spacebar, per-key RGB, supports SignalRGB (https://signalrgb.com/)
└ Soldered: ANSI and ISO layouts, split backspace and left shift support, stepped caps support, 7u spacebar support
Slider Module
The slider module, in the top right of the keyboard, transmits MIDI input, so by default it controls volume. With additional software, it transmits data through channel 1 and cc0 by default and can be programmed through the software – more on how to use and customize the sliders will be included in the product manual. (N.B. slider volume control is not natively supported on Mac; however other functions may be possible to program for Mac.)
Colorways
There will be two editions:
└ Standard Edition: with embossed hieroglyphs on the top case
└ Divine Edition: with double-anodized hieroglyphs on the top case in gold color
▼ Standard Edition - Black (Anodized)
▼ Standard Edition - Safari (Anodized)
▼ Standard Edition - Ivory (Electrophoresis)
▼ Standard Edition - Wildcard (Random Mystery Colors)
▼ Divine Edition - Black (Anodized)
▼ Divine Edition - Silver (Anodized)
▼ Divine Edition - Wildcard (Random Mystery Colors)
Specification
► Materials: Aluminum Case and Brass Weight with multi surface processes
► Layout: 65% ANSI and ISO
► Plate material: PC
► Mount: Gasket Mount
► PCB: QMK-based, VIA-compatible
- Hotswap with per-key RGB underglow
- Soldered with ISO, Split Backspace, 7U Space and Split Shift Support
► Typing angle: 6°
► Front Height: 20.5mm
► Package Size: 385x155x75mm
Q&A
What will be the estimated pricing?
Estimated pricing for different versions as follow:
- Standard Edition: ~$430
- Wildcard Standard Edition: ~$485
- Divine Edition: ~$580
- Wildcard Divine Edition: ~$640
Estimated pricing subject to change and finalized pricing will be available before GB.
When will be groupbuy start?
We are looking to start GB by the end of December 2022.
Will this be unlimited groupbuy?
Most likely yes.
Interested?
This group buy will be handled by ClickClack.io and please contact the platform for more information.
Join ClickClack’s Discord for latest update, discussion, questions:
Fill in Interest Check Form:
Follow ClickClack's IG for other new projects:
Follow Helix's Discord:
« Last Edit: Mon, 03 July 2023, 07:19:59 by ClickClack.io »
Offline HaX
Re: [IC] Aaru65 by Helix Lab
« Reply #1 on: Sat, 29 October 2022, 00:21:21 »
I'm in. Let's go!
Offline Luna
« Reply #2 on: Sat, 29 October 2022, 02:08:12 »
A Divine this time to compliment my brass TKL!   :thumb:
Offline Mecxs
« Reply #3 on: Sat, 29 October 2022, 02:58:18 »
Give me sand or give me death.
Offline elguey
« Reply #4 on: Sun, 30 October 2022, 21:02:00 »
def gonna pick up the divine black edition but wish there was a dark gold option like with Aaru
Offline whitewolf154
« Reply #5 on: Mon, 31 October 2022, 00:27:58 »
What is the front height on this?
Offline Xury46
« Reply #6 on: Mon, 31 October 2022, 09:04:52 »
This is fantastic news since I missed the TKL!
Offline Luna
« Reply #7 on: Mon, 31 October 2022, 09:09:52 »
There are still TKL left, Brass Editio, Divines, some standard ones.
Check via their Discord. They will also soon be posted on Helix website and may or may not be available via Clickclack.
Offline Springpocket
« Reply #8 on: Mon, 31 October 2022, 12:09:36 »
Wow this looks amazing, always love seeing new features on keyboards, that slider is dope! Will cop
    • clickclack.io
« Reply #9 on: Mon, 31 October 2022, 22:22:48 »
Thank you for your question!
Offline lemanh97
« Reply #10 on: Tue, 01 November 2022, 14:51:23 »
Unlimited GB? My kidney is ready!
Offline lemanh97
« Reply #11 on: Tue, 01 November 2022, 19:02:54 »
Will there be other plate option other than PC?
Offline Oogtug84
« Reply #12 on: Fri, 17 February 2023, 21:16:19 »
wheeeeen
Offline hzh0525
« Reply #13 on: Sat, 18 March 2023, 18:14:26 »
What a brilliant dual anoding process!
Offline Ustinj
« Reply #14 on: Sat, 18 March 2023, 23:19:19 »
That weight goes crazy
    • clickclack.io
« Reply #15 on: Sun, 21 May 2023, 01:31:09 »
Stream & Reviews
Blacksimon
https://www.twitch.tv/videos/1820593551
FranktheTank
05/22/2023 20:00 EST
https://www.twitch.tv/frankthetank_16
Offline pgcantos
« Reply #16 on: Mon, 22 May 2023, 04:49:18 »
Can’t wait for this board. Looking forward to buy this soon!
Offline ppatches24
« Reply #17 on: Thu, 15 June 2023, 23:13:24 »
Has the group buy happened for this yet? Imma be sad if I missed out on it
    • clickclack.io
« Reply #18 on: Fri, 16 June 2023, 08:12:39 »
No, you don't miss it.
The creators are reviewing Aaru65 and according to their suggestions, Helix Lab has re-designed the scarab and added a POM to provide better stability and prevent it from falling off or rattling.
Offline sketch3v
  • Sketch (astro-keys)
    • Astro
« Reply #19 on: Fri, 16 June 2023, 09:51:33 »
wow that's some crazy looking board.
GMK pharaoh is the way to go.
    • clickclack.io
Re: [IC] Aaru65 by Helix Lab | GB start on 4th July
« Reply #20 on: Mon, 03 July 2023, 08:53:39 »
GB Details
GB start time: 4th July 2023 20:00 EST
GB end time: 23rd July 2023 23:59 EST
This groupbuy will be unlimited.
Shipping date is estimated to be Q4 2023
Pricing for different versions is as follows (pricing may vary between vendors):
- Standard Edition: $430
- Wildcard Standard Edition: $485
- Divine Edition: $580
- Wildcard Divine Edition: $640
- Extra Weight: $105
- Extra PC Plate + Poron Plate foam: $15
- Extra Alu Plate + Silicon Plate foam: $25
- Foam Kit: $9(Including Case foam, Plate foam and Under Switch IXPE foam)
- Extra Hotswap PCB: $41
- Ti Badge: $50
- Aluminum Badge: $25
Note: if this badge is added in your order, please make sure you choose the default PCB with unsoldered slider module or purchase an extra PCB with unsoldered slider module.
Vendors
Worldwide: ClickClack
OCE: Allcaps
SG: Ktechs
TH: Aiglatson
Unboxing, Building & Typing Tests
Alexotos
Twitch VOD
BlackSimon
Twitch VOD
Frankthetank_16
Tofu Types
Lewis Toh
Offline Luna
« Reply #21 on: Tue, 04 July 2023, 04:30:12 »
What's the status on the solder PCBs?
There's a poll on your discord showing more than enough interest.
Offline aa212121
« Reply #22 on: Tue, 04 July 2023, 05:29:01 »
Huh, is there a possibility i buy a wildcard divine edition and receive a regular divine edition? id rather pay extra 60$ to not gamble please.
« Last Edit: Tue, 04 July 2023, 05:47:39 by aa212121 »
    • clickclack.io
« Reply #23 on: Tue, 04 July 2023, 07:36:22 »
No, of course you won't get a regular divine edition if you buy the wildcard.
We will provide the Solder PCBs as a choice.
Offline yz
« Reply #24 on: Tue, 11 July 2023, 20:50:55 »
I respect the boundaries helix lab has been pushing with their releases. glwgb!
white & gold is :chefskiss:
