Author Topic: [GB] Sperno59 GB CANCELLED  (Read 13340 times)
Offline Biscuit
« on: Thu, 03 November 2022, 09:37:14 »
Sperno59
Made by Alex and Biscuit
Join the discord to get updates and discuss this keyboard
GB date: November 4th - December 9th (different end dates for vendors)
US pricing: Alu: $ 345
                 Brass: $ 425
”sperno 59 | 31/10/2022:"
sorry about delaying it by a week!
There was some last second logistical stuff that was overlooked for launching the GB pages, and we wanted to take a few days to iron it out.
Introduction
I don’t use right shift, I do use arrows. So why don’t replace the right shift with arrows?
This way we can keep the "60%" format, with less compromise. (unless you use right shift of course)
Sperno means to despise/remove/reject etc. in this case, the right shift is the object... Also, it sounds funny.
We have made 2 versions, one with an aluminum bottom and another with a brass bottom.
The brass bottom is heavier and sounds better than the aluminum without foam.
With the alu bottom, you depend more on the provided foam to prevent sound from bouncing inside the case.
The upside is that the aluminum version is cheaper, and maybe you prefer the full alu look.
(There is a sound test and the full alu without foam sounds really good, but decide for yourself)
Specifications
Typing angle: 6o
Dimensions: Length: 306.75 mm, Width: 118.01 mm, Front Height: 19.25 mm, back height: 28.4 mm
Case material: Aluminum (and brass)
Weight: Brass built without switches and caps:  2.25kg
            Alu built without switches and caps: 1.2kg
Colors: Anodized Black, Anodized Alu (silver), Anodized Slate Blue, Anodized Vibrant Red
Mounting: Gasket boots (similar to suit)
               The boots slide over the plate.
Plate: Polycarbonate, alu or FR4 (with a lot of flex cuts)
PCB: VIA compatible
Solder layout options:
Hotswap layout option:
Sound and Feel
brass bottom
full alu (no foam)
The board is bouncy and types soft, this is due to the big amount of flex cuts in the plate and also in the pcb.
You can adjust the amount of gaskets to influence the feel, using all the gaskets will make it stiffer and using less will increase the flex.
Parts Included in Base Price
1x Top case
1x Bottom case
1x Alu Plate
1x PCB (hotswap or solder) + daughterboard + JST cable
16x gasket boots
4x feet
11x Screws
1x carrying case
Available as extra
Foams: (all inluded)
Case foam
Plate foam
Pcb foam
Gasket boots
pcb's (hotswap and solder)
Daughterboard
Polycarbonate plate
Aluminium plate
FR4 plate
Colors
Slate Blue
Vibrant Red
Basic Black
Shining Silver
Parts Pics
Alu plate
Polycarb plate
Fr4 Plate
PCB (solder version shown)
Pricing
Buying info
US: Mechs&Co till dec 5th
EU: MyKeyboard till dec 9th
UK: KeebCats till dec 9th
CA: AshKeebs till dec 8th
AU: SwitchKeys till dec 5th
Asia: QwertyQop
till dec 9th
MOQ: 300
Sales date: November 4th - December 1st-9th
Estimated delivery date: Q2-Q3 2023
Prototype and Colors
R1 proto: We are very pleased with the outcome, technically almost everything works except a tolerance issue with some switches.
For the final and R2 this issue will be solved.
We have ordered a proto of each color with pics in the comments.
The red and blue are a bit lighter than what we intended and will be darker for R2 and final.
R2 proto: Have arrived! the blue color looks way better, the red is now a better shade, but still quite a bit lighter.
We will be keeping this red though, we found it looks better than what we intended. (happy little accidents)
Everything looks good and no changes are needed, we are on the final product.
Content
Past:
KiwiKang stream
StrayChroma stream
LightningKeyboards stream
Not scheduled yet:
TimKeyless
If you want to support and share this keyboard with others, consider adding this banner to your profile
Code: [Select]
[url=https://geekhack.org/index.php?topic=116529.0][img]https://i.imgur.com/RAE6OYM.png[/img][/url]
« Last Edit: Thu, 01 December 2022, 08:32:21 by Biscuit »
Offline Biscuit
Re: [GB] Sperno59 (60% W/ arrows) NOV 4th - DEC 9th
« Reply #1 on: Thu, 03 November 2022, 10:14:17 »
Reserved
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
« Reply #2 on: Thu, 03 November 2022, 13:12:19 »
Approved
Offline Takaoster
« Reply #3 on: Fri, 04 November 2022, 00:13:48 »
Keyboard sounds very nice and am a big fan of flex cuts in the plate
Offline Biscuit
Re: [GB] Sperno59 (60% W/ arrows) GB Live
« Reply #4 on: Sun, 06 November 2022, 08:53:56 »
all vendors live besides mykeyboard
Offline SDKCAMPING
« Reply #5 on: Sun, 06 November 2022, 12:33:01 »
Good luck , MOQ is optimistic and extreme difficult to meet even for very popular makers
Blue Gray Ciel 60 with BCPs | E-white 7V (plateless) with Aqua Kings
Offline radar
« Reply #6 on: Mon, 07 November 2022, 15:36:51 »
I couldn't find any information about the PCB firmware.  Is the PCB VIA compatible?
Offline Biscuit
« Reply #7 on: Wed, 09 November 2022, 17:06:15 »
yes it is via compatible, ill add that in there
Offline Biscuit
« Reply #8 on: Wed, 09 November 2022, 17:11:09 »
we will see what the numbers look like, most likely extras will be made which could fill up the remaining keyboards needed to reach moq.
The prices are based on having 300 boards, which was based on the amount of ic responses (600).
Offline Biscuit
« Reply #9 on: Thu, 10 November 2022, 15:09:14 »
Updated breakdown render:  PCB foam placed correctly
Straychroma streaming again.
Offline BeesKeys
  • Formerly Beesley
    • BeesKeys
« Reply #10 on: Tue, 15 November 2022, 14:05:12 »
I use right shift and still need this board in my life
Offline Biscuit
« Reply #11 on: Fri, 18 November 2022, 06:40:03 »
YES! you just need a left one
Offline Biscuit
Re: [GB] Sperno59 GB CANCELLED
« Reply #12 on: Thu, 01 December 2022, 08:35:45 »
Hey everyone,
Unfortunately we weren't looking to meet moq.
This is not what we expected due to the high amount of ic responses, engagement and positive feedback.
We think this is due to the financial state people are in all around the world, which is currently not the best.
We are thinking of revisiting this GB in the future, hopefully with more succes and an improved price point.
Very sorry for the people who were counting on this board and may have bought and joined other GB's for this board.
Happy typing,
Biscuit and Alex
Offline mixie
« Reply #13 on: Sat, 17 December 2022, 16:51:06 »
Hey everyone,
Happy typing,
Biscuit and Alex
Sorry to hear that the timing for this GB didn't work out. I just stubled upon this board today, unfortunately. Just letting you know that I would surely be interested if/when you decide to run in the future, as a fellow left shift enjoyer.
Offline Eatthereet
« Reply #14 on: Sun, 25 December 2022, 07:12:56 »
Hey everyone,
Happy typing,
Biscuit and Alex
Really unfortunate I think the market is quite dead atm  :'( :'( Are you able to provide some detailed sales figures?
Offline Lovekb
    • YouTube channel
« Reply #15 on: Sun, 25 December 2022, 08:11:15 »
Yeah, people have become smarter and stopped buying any trash, only keyboards with the best value for money remain and they drive the market.
HHKB layout cultist
