Author Topic: [IC] Poisson | TKL | First Prototype is in!  (Read 40960 times)
Offline elvenmonster
Re: [IC] Poisson | TKL | First Prototype is in!
« Reply #50 on: Sat, 03 December 2022, 15:30:17 »
looks great elven  :thumb:
Thanks!!
Next up: need to finish up with PCB design.
Offline whirlwind
« Reply #51 on: Sat, 03 December 2022, 15:49:58 »
The proto looks great, the hype is real! :eek:
Offline Jubileus
« Reply #52 on: Sun, 04 December 2022, 00:26:22 »
Looks good! Would be interested in an F13 version. Also do we have side profile pics of the proto?
Offline 1setups
  • Reviewing Mechanical Keyboards
« Reply #53 on: Sun, 04 December 2022, 03:30:11 »
Love the color and vibes.
Commercial Photographer
Offline GMK83
« Reply #54 on: Sun, 04 December 2022, 05:29:53 »
One of the most interesting TKL to come along in awhile.
Offline Plurrkeebs
« Reply #55 on: Mon, 05 December 2022, 19:22:35 »
What is that melody it sings to me!!! That's how I feel when I see this board. Good job cant wait for the future of this board.  :thumb: :thumb: :thumb: :thumb: :thumb:
Offline fantasyrunner
« Reply #56 on: Mon, 05 December 2022, 20:51:49 »
Wow.... Very interested in this. Love the bezel and color, everything about this! I would definitely like to see more render angles etc. and of the Morse code.
Offline lkmyth
    • Latamkeys
« Reply #57 on: Fri, 09 December 2022, 17:48:39 »
GLWIC, looks amazing.
Even if you are not ready for the day, it cannot always be night.
Offline The0rigina1
  • fumoposting
« Reply #58 on: Fri, 09 December 2022, 18:44:28 »
IDK what do I feel about the weight on the accent cube, other than that looks fire
Offline whirlwind
« Reply #59 on: Sat, 10 December 2022, 00:12:48 »
Gib Martingale, Poisson :prayge:
Offline Mena
« Reply #60 on: Tue, 27 December 2022, 15:53:29 »
interested in seeing a better angle of the side profile
Offline aicyborg
« Reply #61 on: Tue, 27 December 2022, 17:04:22 »
Asking again just in case: please consider adding ISO accommodations to the plate, and maybe some flexibility for stuff like split right shift since that's pretty common in this form factor. At the moment this layout is very fixed and I feel like that's maybe the only thing I wish were differnet.
It looks like your plate does have a wide enough space for stepped or regular caps, which is good at least. Basically, I'm pushing for customisation here. Thank you!
« Reply #62 on: Tue, 27 December 2022, 17:46:51 »
Hi! The plate shown isnt meant to showcase the layout compatibility. It is mainly to showcase the mounting points. Of course, ISO will be avail, but I might enforce full right shift and backspace. Will also enforce 7U layout for the bottom row.
« Reply #63 on: Tue, 27 December 2022, 17:51:25 »
Here you go!
294913-0294915-1
Offline aicyborg
« Reply #64 on: Tue, 27 December 2022, 18:55:14 »
Thank you for answering, sorry I assumed about the plate. This board does look lovely, though. Personally, I'm okay with you forcing 7u bottom row and full length backspace. I would ask you to not force full RShift given this is WKL because I use the split for Windows key.
Offline Mena
« Reply #65 on: Tue, 27 December 2022, 21:10:54 »
Here you go!
Thanks! I'm very interested in this board, GLWIC
« Reply #66 on: Wed, 28 December 2022, 10:23:18 »
That makes sense. Will consider! These things are super easy to change anyways. Currently I am mostly interested in working on the feet, since they seem to affect the sound of boards a lot. Need to make sure that they dont sink into the deskmat while also looking good!
Offline Zyrophr
  • https://zyrophr.com
    • zyrophr.com
« Reply #67 on: Wed, 04 January 2023, 16:37:47 »
Interesting!
French keyboard streamer
Offline FearsomeCubedWarrior
  •  Post Reporting Timeout
« Reply #68 on: Thu, 05 January 2023, 11:21:39 »
« Last Edit: Mon, 15 April 2024, 21:15:46 by FearsomeCubedWarrior »
Offline sirieous
  • help
« Reply #69 on: Thu, 05 January 2023, 11:52:56 »
I'd be keen to get my hands on one of these, looks dope man.
« Reply #70 on: Mon, 09 January 2023, 15:10:51 »
What about alps support, is it dropped?
Alps can easily be supported by just working on the plate design. PCB will have support for the alps pins. I don't plan to offer alps plates for any potential GB, but can make the plate file available so that interested parties can get it cut.
« Reply #71 on: Mon, 09 January 2023, 15:29:15 »
« Last Edit: Mon, 15 April 2024, 21:15:12 by FearsomeCubedWarrior »
Offline Chippy
  • sus chef
« Reply #72 on: Mon, 09 January 2023, 16:48:19 »
Been keeping an eye on this for a while. The blocker light is growing on me. Maybe it's time for a second fish themed board in my collection.
1.2og | Buddy 6xx | Le Fishe V1 Proto | xyz60 Rev2 | Quartermaster | Chimera65 | Satisfaction75 | Realforce 84u | Zenith Z-150 | Realforce 86u | 378
This and the swiss cheese keyboard is the next generation of keyboards
Offline techzenario
« Reply #73 on: Sun, 22 January 2023, 08:23:32 »
Great design, clean lines. I like it very much :D
Typing angle is good
USB to the right is great (not centered)
Think I'd prefer h88c (south), but 87 works as well. I'm an ISO user and would need to find some support for that through another pcb possibly.
As I understand it is gasket mount? not top mount?
Anyhow, very interested and will keep an eye on this.
-tech
« Reply #74 on: Mon, 23 January 2023, 18:46:03 »
Thanks for the kind words Chippy!
-tech
ISO will be avail, don't worry. F13 will not be avail - so no H88c compat. Also the board is not gasket mount!! Its a top mount with a bit of adjustability via options for both regular and 'leaf spring' mounting points. Check out the plate shown! (It has been updated since, but the mounting mechanism is still the same).
Offline MSA_Vision
« Reply #75 on: Sat, 25 March 2023, 13:34:15 »
Any progress on the second proto? I assume you’re busy with your other project in martingale amongst other things but I would be interested in this project. Thanks in advance  :-*
Sic Parvis Magna
Offline finalarcadia
« Reply #76 on: Sat, 25 March 2023, 13:41:22 »
Soon tm
Offline WoobEC
    • Eloquent Clicks
« Reply #77 on: Sun, 26 March 2023, 07:55:18 »
That is great!
Offline NightFox99
« Reply #78 on: Sun, 26 March 2023, 08:49:24 »
Man took the best from 1.2og and 2.0add and added to it some bottom waves like in Bias. Elvenmonster, take my money, I'm in  ;D
Offline Flybeck
« Reply #79 on: Sun, 14 April 2024, 22:36:12 »
What happened to this?
