Author Topic: [IC] Nice60 - A seamless wedge, oring / top mount 60%  (Read 13943 times)
Offline Chuuu
« on: Tue, 08 November 2022, 19:28:34 »
Project is shelved for the time being. Thanks everyone for the support. This will return next year
Nice60
Original IC https://www.reddit.com/r/mechmarket/comments/vumcy9/ic_nice60_the_low_angle_low_front_height_seamless/
Because 6.9° boards are overdone and I really wanted a travel friendly, wrist friendly board
Interest Check Form!  Discord!
Nice60 aims to deliver the typing sound and feel only found in limited, high end keyboards in a nice, competitive package.
Nice60 draws inspiration from the mounting system in the OTD 356 mini and the low front height, seamless look of Noxary products.
Mounting system / exploded view
The sandwich o-ring mounting system lends itself to being a firm, yet pleasant typing experience.
Relief top mount was added on a whim with this proto revision, however I ended up liking it!
Proto pictures!
Side note, these protos are from the final manufacturer and I am stoked for the finish quality. Normally I'm a huge Karen when it comes to qc but I truly could not find anything wrong with the anodized unit.
Another note, on the raw unit, they accidentally started processing it, so it isnt *as* shiny as it should be. It's a proto and I didn't want to make them re-machine an entire new case so it is what is.
Specs:
- Target Price: $250-300 Alu bottom, $300-350 Brass bottom
   * Price is a bit high for full alu, but I'm very pleased with the quality of the board compared to my proto from a cheaper manu. There's def room for negotiation with higher quantities.
- Above price is based on MOQ: 100
- Lead time for manufacturing: 60-90 days
- Material: Aluminum Top, Aluminum/Brass Bottom
   * Brass bottom will be sandblasted and matte coated
- Typing Angle: 4.20°
- Front Height: 16.9mm
- EKH: 20.5 mm
- Rear Height?: 25.1 mm
- Weight:
   Aluminum Bottom: Approx 900g / 2lb built
   Brass Bottom: Approx 1700g / 3.75lb built
- Mount: Gasket O-Ring with compression ("sandwich oring"), Relief top mount
- Colors: TBD
- Layouts: WK/WKL 60%, Tsangan bottom row, Split/Full Backspace, Split/full right shift, will look into ISO support.
   * Only tsangan bottom row is "officially" supported by this case (there's cutouts on the lower case walls where the oring would protrude from the stab housings, as well as cuts on the bottom case to prevent bottom out)
   * subject to change based on ic responses
KLE screenshot will be available when my PCB designer wakes up (s/o merro60 pcb)
If you want an idea about how low profile this board is
Side note, Pandora is a gorgeous board, even for today's standards. koobs is the goat
Proto albums: https://imgur.com/a/m0QQYM9 https://imgur.com/a/MkgpRfE
Vendors
NA: TBA  ;D
Sound Tests: (there's a lot and more will be added)
Rev 1 proto sound tests: Recorded on a Shure MV7 + Scarlett 2i2
Alu bottom:
Meteor whites on PP oring mount: https://voca.ro/13ylkGX7h7Re
Gateron Inks on Alu Full top mount: https://voca.ro/139eW3tjvVb5
Gateron Inks on Alu Full oring mount: https://voca.ro/1hypThfsJjWJ
Brass bottom:
Cherry Blacks on Alu Half top mount: https://vocaroo.com/1m7owIvBuBxu
Cherry Blacks on Alu Half oring mount: https://voca.ro/13koyC7hvteV
Gateron Inks on Alu Full top mount: https://voca.ro/1ipwsp7Uw5cM
Gateron Inks on Alu Full oring mount: https://voca.ro/1j9FZW7WZ6t7
Special thanks to Enigo (formerly PhilJB) for the degen hour design talks, dks for steering me away from throwing random curves on a keyboard, New England Keyboard Discord for the feedback during meetups, everyone that has supported me along the way, and lastly a special shoutout to kabocha, because he'd probably complain if I didn't
TODO:
Finalize colors
Finalize pricing, pricing was quoted for a 100 unit run, but there's definitely room for negotiation if there's enough interest.
A fun engraving
International vendors?
Rev 0 sound tests, renders, gallery:
Changelog:
v0 > v1:
- Raise sidewall height on bottom case for ease of alignment
- Add cutouts on the bottom case sidewalls for ease of assembly
- Add relief cut along plate tabs with top mount points to test
- Use 1mm fillets + dogbone instead of 1.6mm fillet
If you made it this far, thanks for reading! I truly hope you'll enjoy nice (if you join the gb) as much as I have. It's quite literally the board I bring everywhere! 【=◈◡◈=】
« Last Edit: Mon, 12 December 2022, 17:28:31 by Chuuu »
Offline kobb
Re: [IC] Nice60 - A seamless wedge, oring / top mount 60%
« Reply #1 on: Tue, 08 November 2022, 19:30:25 »
reserved  :thumb:
Offline Chuuu
« Reply #2 on: Tue, 08 November 2022, 19:32:00 »
Reserved  :blank:
Offline Brian1321
« Reply #3 on: Tue, 08 November 2022, 19:33:32 »
Nice
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
« Reply #4 on: Tue, 08 November 2022, 19:33:50 »
yeah that's a keyboard
Offline scantron
    • Route 66 Cable Co.
« Reply #5 on: Tue, 08 November 2022, 19:34:48 »
Nice.
Consider http://www.route66cables.co for all your wire and cable needs.
Offline catamscott
« Reply #6 on: Tue, 08 November 2022, 19:35:36 »
nice, simple design, nice angle, nice mounting, nice price. good stuff  :thumb:
Offline sub0001
« Reply #7 on: Tue, 08 November 2022, 19:36:24 »
love premium-leaning boards at budget prices, will be following this one! GLWIC!
Offline dks
« Reply #8 on: Tue, 08 November 2022, 19:37:19 »
Nice!
Offline Jona_1153
« Reply #9 on: Tue, 08 November 2022, 19:39:58 »
Very nice keyboard at a nice price! :thumb:
Offline ankit
  • Formerly ankit-sachdeva
« Reply #10 on: Tue, 08 November 2022, 19:43:08 »
looks really nice, glwic  :thumb:
Offline chchchchalex
« Reply #11 on: Tue, 08 November 2022, 19:43:27 »
Nice
Offline lbassett21
  • Plastic and Metal Enthusiast
« Reply #12 on: Tue, 08 November 2022, 19:45:25 »
Very good board. Highly recommend it after trying proto.
Discord: Bassett#0001 | Reddit: /u/lbassett_21 | Instagram: BassettKeebs
Current Collection:
Keyboards:
OTD 360 Corsa | Kira80 | FMJ 80 | Matrix 8xv2.0 | Matrix 8xv1.2og | IBM SSK 1395217 (Stock Trading) | Hiney TKL One PC | Hiney TKL One FNF | G81-3077SAU | G81-3007SAU | G80-9039HAAUS | HHKB Pro 2 Type S | Realforce 84ub |  Lunar 2 |  Sord KB-101 | Percent Canoe | G80-3190HSU | Alps64 | Xerox 6085 Keyboard | IBM 5576-001 | IBM Model M 1390131 | IBM Industrial Model M 1394946 | IBM Model M SSK 1393691 (SABRE) | IBM Model M 1393464 | HHKB Pro Hybrid Type S | Dell AT101 | Leading Edge DC3014 | IBM Model F AT | IBM Model F122 | G80-0693 | G80-0528 | G81-3100SDU | G80-1838HPU | DAS 2 (G80-3485LWNUS-2 | Texas Instruments Keyboard (SKCM Brown) | G80-9002LBBXX
Keycaps:
ESA-3000-HASR0 | G81-3077SAU | G81-3100SAU | BMOL 5206 UP (Desko Color) | BMOL 4000 U (Desko) | GMK Solarized Penumbra | Desko Black (1/10) | GMK Beta JS | IBM APL2 w/Box 1395624
Offline B_D
    • bdskeyboards
« Reply #13 on: Tue, 08 November 2022, 19:45:59 »
what is the weight of the board with the brass bottom?
height=120]https://imgur.com/rPWNMJz.png[/img][/url]
Offline Chuuu
« Reply #14 on: Tue, 08 November 2022, 19:56:17 »
Its roughly 1.7 kg / 3.75lb fully built  :thumb:
Offline B_D
    • bdskeyboards
« Reply #15 on: Tue, 08 November 2022, 19:59:15 »
damn thats heavy. If you do a brass/copper bottom version I will definitely be in for one  :thumb:
Offline CaesarAZealad
  • Racc
« Reply #16 on: Tue, 08 November 2022, 20:02:07 »
Baby blue with my badseed tactiles and a brass plate :Drool:
One, Two, Three, Four, Five, Six, Seven, Eight, Nine, Ten, Eleven, Twelve, Thirteen, Fourteen, Fifteen, Sixteen, Seventeen, Eighteen, Nineteen, Twenty... Yeah that seems about right.
"Ask your mother how good I can use more than two fingers." - Caesar, 2023
Offline Rafa_n
  • stuffforrectangles.etsy.com
« Reply #17 on: Tue, 08 November 2022, 20:23:04 »
Nice. I would love to get one with brass bottom.
 Also please consider having a EU vendor
Offline C_L | Soup
« Reply #18 on: Tue, 08 November 2022, 20:51:20 »
Added relief top mount? Now im intrigued Mr. Chu
Do you with E-coats are on the table or would you want to stick with ano only?
« Reply #19 on: Tue, 08 November 2022, 20:54:51 »
Great board and great designer, GLWIC  ;D
Offline evillguy
« Reply #20 on: Tue, 08 November 2022, 21:06:04 »
NICE
Offline irithyll
« Reply #21 on: Tue, 08 November 2022, 22:00:26 »
nice
Offline nonuser
« Reply #22 on: Tue, 08 November 2022, 22:02:56 »
 :eek: :eek: :eek: $300 all alu at 100 moq!  :-X :-X :-X :-X That's not so nice LOLOL  :)) :)) :)) :)) (you get it because its called NICE60 ROFLMAO :)) :)) :)) )
Offline Peter6109
  • Working on my own set.
« Reply #23 on: Tue, 08 November 2022, 23:09:07 »
chUwU
Offline Nonnegaard
« Reply #24 on: Wed, 09 November 2022, 00:48:57 »
most sane geekhack user
Aeon, TGR Jane V2, Dolphin 2021, Gherkin, Model M, 5°, NCR80, M0110-A
Offline Nonnegaard
« Reply #25 on: Wed, 09 November 2022, 00:49:42 »
I could use a new doorstop. Nice work.
Offline Psyquack
« Reply #26 on: Wed, 09 November 2022, 06:37:26 »
Looks good!
Offline conternecticus
« Reply #27 on: Wed, 09 November 2022, 09:19:17 »
I really like the purple in the render in the IC. Is that Veri Peri?
Offline ABlazinBlueToe
« Reply #28 on: Wed, 09 November 2022, 10:22:30 »
TIL that Pantone has a "color of the year".
Offline pixelpusher
« Reply #29 on: Wed, 09 November 2022, 10:51:14 »
Yep, you can check their website to see the color of the year back to 2000.  Interesting to look back and see that many of the colors chosen have been very close to previous colors.  For instance, this year's color looks extremely similar to the one from 2008.
Offline arr1
  • Ñ supporter
« Reply #30 on: Wed, 09 November 2022, 12:41:34 »
Please, consider including EU vendors  :(
Offline Chuuu
« Reply #31 on: Wed, 09 November 2022, 21:04:33 »
So it turns out I'm a massive clown and linked the wrong IC form lol...
https://forms.gle/a8YiFD23oX5cXDqL7
Offline Chuuu
« Reply #32 on: Wed, 09 November 2022, 21:18:05 »
Brass bottom is an option!
I haven't asked about ecoating with my manu yet. I can check, but I personally think this design looks best with an anodized finish
The IC form actually features outdated colors, see my comment above about posting the wrong form  :(
If you're referring to the picture at the top of this IC, that's actually the lilac from my manufacturer!
I was planning on reaching out to international vendors once I had more data from the interest check forms :D
Offline Chuuu
« Reply #33 on: Fri, 11 November 2022, 12:00:39 »
Replying to some ic comments ~
ISO support please, and an EU vendor
I'll for sure offer it as a plate file, although I'm still on the fence about adding it to the plates available in gb. Depends on ic numbers!
(the) framing circle around the usb c cutout.. to me it looks a little cheap and worried it might not fit my Lindy cable very nice
I actually really love my lindy cables too! Any designs coming from me will always be compatible
also prefer the thinner side on the right proto in the picture.
the side bezel could stay as thin as it is on the 1.6mm example
I'll consider it! In hand, I'm currently liking the slightly thicker side bezels as it makes the board look a bit heftier than it really is
Offline lakeboredom
« Reply #34 on: Fri, 11 November 2022, 17:38:15 »
Someone pls educate me, how does the mounting in this and the otd differ from a bakaneko or uninorn? I know there's tabs on the plate preventing it from being pulled out, but do they sit on the oring the same way?
Sent from my moto g power (2022) using Tapatalk
Offline Chuuu
« Reply #35 on: Fri, 11 November 2022, 21:53:19 »
With bakeneko/unikorn type oring mounts, the whole plate/pcb assembly is just dropped into the case, with compression coming only from the walls of the case
With mounts like the otd356 mini and nice, the top case actually presses against the tabs of the plate, applying compression on top of the oring. From my experience, this leads to slightly firmer typing experience, and unique sound signature, with more top/case sound
Offline disarmyouwitha
« Reply #36 on: Sat, 12 November 2022, 13:30:52 »
The whole bottom (where the cutout of the JST is) is made of brass?
o.O
Offline arr1
  • Ñ supporter
« Reply #37 on: Sat, 12 November 2022, 15:31:48 »
looks insane
Offline lakeboredom
« Reply #38 on: Sat, 12 November 2022, 17:30:00 »
Thank you, and with this style case are they compatible with the other style assembly also? Or do you kind of need the plate?
Offline bruin
« Reply #39 on: Mon, 14 November 2022, 09:36:06 »
for those that still want an ogre.
« Reply #40 on: Mon, 14 November 2022, 10:15:38 »
Ah, I really like that color :( Somewhat unique, don't see that color as an option very often.
Offline selsik
« Reply #41 on: Mon, 14 November 2022, 11:49:47 »
I'm positively tired of every single IC/GB board being 6 deg or higher. This is such a breath of fresh air.
Very much interested in this, and looking forward to it :thumb:
Topre >>> MX
Offline mr_foggy
  • neue = nope
« Reply #42 on: Tue, 15 November 2022, 10:00:09 »
nice 60
if vendors help you get past the 100 moq so that prices can be lowered a little bit, you'll be having a banger board with multiple rounds ahead
Offline lampmk
  • box art peddler
« Reply #43 on: Tue, 15 November 2022, 10:53:16 »
Really interested in this. GL!
My collection -
Ovinnik - Spyder TKL - FMJ TKL - Keycult 1/60 Raw - Lin Whale - Duck Lightsaver V1
Offline NassimO
« Reply #44 on: Tue, 15 November 2022, 12:21:54 »
Very simple yet pleasant board!
Offline kennedystewart
« Reply #45 on: Wed, 16 November 2022, 21:56:44 »
genuinely curious about this.
Offline thocciness
« Reply #46 on: Thu, 17 November 2022, 10:23:42 »
Hope you can hit that price point! That's great price for such a nice board!
Offline FrothBoss
« Reply #47 on: Tue, 22 November 2022, 23:45:54 »
Very interested after trying it at a meetup. GL chuu!
