Author Topic: [GB] Ahgase TKL  (Read 5000 times)
Offline thocciness
[GB] Ahgase TKL
« on: Thu, 17 November 2022, 22:27:31 »
Ahgase TKL
by plywrks
This is a passion project born from the fandom of a certain Kpop group. After two years I'm excited to share this group buy with everyone!
plywrks Store
PHOTOS
SPECIFICATIONS
Layout: F13 Blocker TKL
Mounting: Double O-ring Gasket/Top Mount
Material:  6063 Aluminum, Sandblasted Stainless Steel
Weight: 4.4lbs unbuilt, 5.3lbs built
Colors: Sliver, Green, Lilac
Typing Angle: 6.9 Degrees
Front Height: 17.5mm
Plates: Aluminum Full, Polypropylene Full, Polycarbonate Full
Units: FCFS 100 Units
Layout
WKL and WK
Price
Case $495
PCB $45
Aluminum Plate $50
Polycarbonate Plate $45
Polypropylene Plate $45
PCB SUPPORTED LAYOUTS
Regular or Split Backspace
Regular or Stepped Caps Lock
ANSI Left Shift
ANSI Enter
ISO Enter
Split Right Shift
Tsangan Bottom Row
PACKAGING
plywrks Carrying Case
GROUP BUY INFORMATION
November 18th, 2022 1PM - November 25th, 2022 11:59PM EST
or until 100 units are sold out.
CONTENTS
(1x) Top (Aluminum)
(1x) Bottom (Aluminum)
(1x) Weight (Stainless Steel)
(1x) Accent Weight (Stainless Steel)
(1x) Plate (Aluminum)
(1x) Ahgase Solder PCB
(1x) Daughterboard
(1x) JST Cable
(8x) Case Screws
(7x) Top Mount Screws
(1x) 70A Large Oring
(7x) 70A Small Orings
(4x) Bump Ons
(1x) plywrks Carrying Case
COLORS
Silver, Green, Lilac
Estimated Delivery
March 2023 - Late Q1/Early Q2
LINKS
Join our community:
Discord: https://discord.gg/rwBM7tpchE
Instagram: https://www.instagram.com/poly.works/
BUILD GUIDE/INTERNALS/b]
Full Alu Plate + Cherry Black Switches
TYPING TESTS
Full Polypropylene Plate + CreamKon Switches
Full Alu Plate + Meteor Whites Switches
Full Alu Plate + Singularity Switches
Full PP Plate + Cherry Brown Switches
Full PC Plate + Zaku Switches
Full Alu Plate + Zaku Switches
« Last Edit: Tue, 22 November 2022, 23:27:50 by thocciness »
Re: [GB] Ahgase TKL
« Reply #1 on: Tue, 22 November 2022, 15:35:14 »
Approved :thumb:
