Author Topic: [IC] 65% Z67-YUN, gasket Update#1 - Dec1  (Read 8461 times)
Offline tommyamoszhao
« on: Sat, 19 November 2022, 23:37:11 »
Hello, Geekhack! We are introducing our 3rd board Z67-YUN to the market, 65%, 67 keys gasket mount keyboard. Inherited by 2 previous projects Z40-Pastry and Z60-Evolve, simplicity aesthetics is in Z67's blood stream. Hidden screw design for the weight and flushed surface between weight and bottom makes the weight rooted in the bottom aesthetically. Vibration insulation foams between every contacting surface absorbs unwanted noises.
Rendered Image
Powder-White
Anodized-Dark Grey
Powder-Yellow
Features:
  • Gasket mount: Poron/Silicon (Update#1)
  • Base kit with PE Foam included
  • Three piece enclosure
  • Centered USB-C port
  • 18.05mm Low front-height
  • Brass weight mirror polished
Dimension:
  • Length: 322.75mm, width: 122.7mm, front-height: 18.05mm
  • Typing angle: 6.5 deg
  • Bezel: 8.46mm
  • Weight: 1.1kg, 2.43lb (Aluminum Top+PC Bottom+Brass Weight+PCB+CF Plate)
PCB Layout:
  • Layout-Overall
  • Layout Standard
  • Layout 7U Spacebar
  • Layout Bauer
  • Layout Compact
Base Kit Include:
  • Case x1
    • Top enclosure x1
    • Bottom enclosure x1
    • Weight x1
  • Switch Plate x1
  • PCB x1
  • Accessories:
    • Vibration insulating foam (Force break mod) x1
    • PE Foam x1
    • Plate Foam x1
    • Poron Gasket x1set
    • C-3 daughter board x1
    • USB-C cable x1
    • Cap/switch puller x1
    • Screws x1 set
    • Silicone foot pads x1set
    • Silicone Shoes x1set (Update#1)
Specs:
  • Case: Gasket mount Poron/Silicon (Update#1)
    • Centered USB-C socket
    • 18.05mm Front-height
    • Top enclosure: CNC machined 6063 aluminum
    • Bottom enclosure: CNC machined Polycarbonate(Default), 6063 aluminum(Optional)
    • Brass Weight: CNC machined H62 Brass, PVD Titanium coating, mirror polished, nano coating
  • Plate material options:
    • FR4
    • Carbon fiber
    • PC
    • Aluminum(Sand blasted & Anodized Silver)
    • FR4 as default, Carbon Fiber, PC and Aluminum optional
  • PCB:
    • C3 Daughter board with ESD protection
    • Solder version with layouts compatible, 'split-backspace', 'ISO enter', 'Stepped capslock' and 'split-left shift'
    • Bottom row option:
      • 1.25+1.25+1.25+6.25+1.25+1.25
      • 1.5+1+1.5+7+1.5
      • 1.25+1.25+1.25+6.25+1+1+1
    • Hotswap version, ANSI layout only
    • Solder version PCB will have through holes for per-key LED(Not included)
    • Hotswap version PCB with per-key RGB
  • Firmware: QMK driven and VIA compatible
    • Downloadable from official website, when GB ends
  • Color options:
    • Powder White
    • Anodized Dark Grey
    • Powder Yellow(TBD)
    • Other color options are within the IC form
Extra Parts:
  • FR4 Half-plate
  • Carbon fiber Half-plate
Pricing:
  • Base Kit: $250-300 TBD
MOQ=100pcs
Lead time: 90-120days depends on order quantity
GB start time, Dec 2022
[/list]
Update#1, 1st Dec
  • Dark grey
  • Yellow
  • Structural change update
  • Silicon shoes mounting mechanism's been added, grooves will include parts for Silicon shoes
Update#1, 12th Dec
  • Molded silicon shoes
« Last Edit: Sun, 11 December 2022, 11:03:34 by tommyamoszhao »
Offline Akele
Re: [IC] 65% Z67-YUN, Gasket mount board, Quarkeys
« Reply #1 on: Sun, 20 November 2022, 05:10:22 »
Nice clean design. I hope you keep the weight blank, as it's so nice to see a board without italic script on the weight.
Perhaps consider adding a 'any other comments' to the interest check form to capture any other comments people may have on the design.
Looking forward to seeing some pics of the prototype. GLWTIC.
« Reply #2 on: Sun, 20 November 2022, 08:19:38 »
Thank you so much for the appreciation, and yes, logo is only on the inside of the weight, outside stays mirror finish. And thanks for the heads up, "Any other comments" is added in IC form. Sincerely
Offline saab
« Reply #3 on: Sun, 20 November 2022, 14:33:35 »
not a big fan 65%s but i like how you did the bottom, acrylic with brass weight. GLW IC :)
Offline desgeek
    • Desgeek
« Reply #4 on: Mon, 21 November 2022, 20:28:51 »
clean design, I like it
« Reply #5 on: Mon, 21 November 2022, 23:05:50 »
« Reply #6 on: Mon, 21 November 2022, 23:06:34 »
Re: [IC] 65% Z67-YUN, gasket Update#1 - Dec1
« Reply #7 on: Thu, 01 December 2022, 07:31:02 »
#1 Update's been modified includes:
     1. Dark grey color prototype
     2. Yellow color prototype
     3. Structural change, silicon shoe mounting mechanism is added, case groove was for Poron gasket only, but will include grooves for silicon shoes as well
Offline Its Salty
  • I have no idea what I'm doing
« Reply #8 on: Thu, 01 December 2022, 18:44:39 »
I do like the rounded design, but that thick acrylic bottom reminds me of the ID87 which sounded terrible
concerned how all that plastic will affect the sound; but hope it's does some good
« Reply #9 on: Fri, 02 December 2022, 01:03:33 »
Hi, thx for the good concern. First of all at the moment, poly-carbonate and aluminum6063 would be our choice for bottom materials. Sound wise, it's affected by so many factors including mounting mechanisms, plate materials, structural cuts, cushioning system and resonating relationship. Z67 is gasket mount mechanism, resonance calculation is done and planned on it, so I should say the sound signature should be quite different, pls stay tuned for the sound test and review
« Reply #10 on: Sun, 11 December 2022, 11:05:07 »
Update#2- Dec12. Molded silicon shoes is done, waiting for the new prototypes with the silicon grooves to arrive.
Offline Toptiginn
    • toptiginn.com
« Reply #11 on: Mon, 16 January 2023, 14:23:14 »
I like it! Especially bottom side  :thumb:
