Author Topic: [IC] Kairo 65 by Laneware | Prototypes in Maufacturing |  (Read 20981 times)
Offline Laneware
    • Laneware Peripherals
« on: Fri, 25 November 2022, 16:05:41 »
Introducing the
Kairo 65
By Laneware Peripherals
Instagram
Discord Server
Feedback Form
Render Book
Dark Grey
Green
Silver
4th Color - Community Choice
Coming Soon.
Complete the feedback form at the top of this page to have your say!
Gasket Mount
USB-C Daughterboard
Unified C3 Standard
Layouts
PCB
Hotswap PCB displayed. The hotswap PCB will only offer the default layout. For the layout options shown above, a Solder Type PCB will be required.
Front
Back
Palette
Details
Method of Sale: 100 In-Stock and then GB
Form Factor: 65%
Angle: 7 Degrees
PCB: Type C, QMK/VIA, Rotary Encoder, Hotswap Option
Encoder: Press to Change Function
Plate: Aluminium 1.5mm
Cost: ~$299 USD Base Price
Vendor: https://lanewareperipherals.com/ (Based in Australia)
Contact
My Personal Discord: LANEWARE#0468
Email: support@lanewareperipherals.zendesk.com
Previous Projects
LW-75
LW-67
Macro-1
Raindrop 60%
« Last Edit: Sat, 07 January 2023, 22:25:54 by Laneware »
Offline Laneware
Re: [IC] Kairo 65 by Laneware | First Look |
« Reply #1 on: Fri, 25 November 2022, 19:04:24 »
Reserved
Offline ManoliVisuals
« Reply #2 on: Fri, 25 November 2022, 21:15:33 »
We <3 Laneware
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #3 on: Sat, 26 November 2022, 01:43:23 »
finally spermo 2
Offline saab
« Reply #4 on: Sat, 26 November 2022, 07:32:00 »
love the layout
Offline Laneware
« Reply #5 on: Wed, 30 November 2022, 02:42:33 »
Purple is looking very promising in the feedback poll :D
Offline Inversecrowd
« Reply #6 on: Sun, 04 December 2022, 00:00:19 »
Keen as always for a new Laneware keeb 👌 loving the left knob and macro cluster!
Offline pixelpusher
« Reply #7 on: Sun, 04 December 2022, 00:34:51 »
Filled out the detailed feedback form.  I really think this would be a grand slam if you removed the right shift and give those arrows even more room to breathe.  100% would give up the right shift for a more bold design :)
I'm a right shift user, and I would never be able to hit it where it is.  Might as well get rid of it.
« Last Edit: Sun, 04 December 2022, 01:10:18 by pixelpusher »
Offline Xury46
« Reply #8 on: Mon, 05 December 2022, 05:51:44 »
I really like the right shift as-is. Personally I don't like boards with empty space in their layouts, so filling in that gap on the right side of the arrows is a huge win and makes the layout look symmetrical and beautiful.
Offline Xury46
« Reply #9 on: Mon, 05 December 2022, 05:53:50 »
I would love to see a split spacebar option. Not enough 65% boards do it and it makes layers so easy to access which really opens up the possibilities for keymaps.
Offline Laneware
« Reply #10 on: Wed, 07 December 2022, 22:44:03 »
We are looking at adding this to the solder PCB :) Unfortunatly this isn't possible to offer on the HS PCB due to interaction between the HS sockets and the stabelizer cutouts.
Offline Laneware
« Reply #11 on: Sun, 11 December 2022, 03:03:30 »
Thanks to all that are dropping their feedback! Because of it, we have decided to drop the silver due to its similarity to the grey and bring back the LW-75 blue :D Keep the feedback coming!
Offline Laneware
« Reply #12 on: Sun, 18 December 2022, 01:13:01 »
Update: First prototypes are currently in fabrication :D
Offline Ikeygai Designs
« Reply #13 on: Tue, 20 December 2022, 20:56:48 »
I really like that weight design and the big knob
Offline Laneware
« Reply #14 on: Sat, 07 January 2023, 22:25:30 »
Update: Prototype cases are due to arrive shortly after the CNY holiday. PCB prototype R2 are currently in manufacturing.
Offline Laneware
Re: [IC] Kairo 65 by Laneware | Prototypes in Maufacturing |
« Reply #15 on: Wed, 15 February 2023, 18:16:53 »
Prototype Update: Currently finishing anodizing, we expect to have these in hand in 2-3 weeks, ready to send out to content creators :D
Offline nylewd
« Reply #16 on: Sun, 21 May 2023, 11:54:08 »
Any update on this?
Offline illusion2086
« Reply #17 on: Sun, 21 May 2023, 12:17:41 »
i just dont get it
how are you supposed to use right shift
Offline pixelpusher
« Reply #18 on: Sun, 21 May 2023, 14:27:44 »
i just dont get it
I'd say that you don't.  Probably use that key as a function key :)
Offline niakulah
« Reply #19 on: Sun, 21 May 2023, 20:15:47 »
Only 1 bottom row mod on the right is a bit limiting to me, so a split spacebar option would be nice.
Offline NumPadEnjoyer
« Reply #20 on: Tue, 09 January 2024, 11:30:06 »
giant fan of this layout with the left side macros and rotary encoder gonna keep my eye on this
Offline pixelpusher
« Reply #21 on: Tue, 09 January 2024, 12:21:26 »
For anyone following that isn't on their Discord:
305490-0
