Author Topic: [IC]S65/80 V2 Keyboard with 3.5-inch IPS Screen R2 GB IS LIVE  (Read 14843 times)
Offline Lukenan
    • Sam Website
« on: Wed, 30 November 2022, 09:24:25 »
GB Collection
Updated: April 28th
Hi everyone!
We are happy to let everyone know the IC form was a success, thanks so much to everyone who supports us at NotfromSAM! We appreciate each and every one of you!!
A lot of you awesome people had missed the original drop for the S65V2/S80V2, so we took some of your advice and recommendations and are now reintroducing them with some new colorways and a hotswap option.
Group buy is incoming!
Updates and information below:
What’s the update:
9 Final Colorways
-Storm Blue (Sparkle)
-Black (Sparkle and Anodized)
-Avocado Green
-Burgundy
-Champagne Purple
-Cream
-Maraner Grey
-Silver
Renders for GB Colors: https://imgur.com/a/MMdVQVc
S65 V2 Prototype Gallery: https://imgur.com/a/P9AzKyi
S80 V2 Prototype Gallery: https://imgur.com/a/lwmxlLG
Information/Tech Specs:
-3.5" IPS Screen, programmable to an extent(jpeg/bmp) no GIF. -Non-flex cut Solder and Non-flex cut Hotswap PCB options will be available for purchase.
-Winkeyless or Winkey options
-ANSI and ISO Support available
-Split Right Shift Support
-Stepped Caps Support
-6.25u & 7u bottom row options
-Copper weight(improved logo emboss into copper)
-FR4 Plate default(more options if requested in future drop, this was based on a poll)
Vendor List
US: Keebsforall
US: Dangkeebs
UK: MechMods UK
Ireland: Row5.store
Philippines: Zionstudios.ph
Canada: Mech.land
EU: Deltakeyco
AU: Prestige Keys
TH: Gamingplanet
Groupbuy info:
GB Time: May 1st -May 20th
GB Price:
S65 V2 Solder Edition: $289
Hotswap Edition: $299
S80 V2 Solder Edition: $319
Hotswap Edition: $329
ETA SHIPPING:Q3
Reviews/Live streams
Xanniard- Cream(Schedule: TBD)
Sviz- Silver Typing test
Hi everyone!
Following the success of the previous rounds, we have decided to run another round of the S65 and S80 V2!
What’s new:
1. New colorways to vote
2. Add a hotswap PCB option
3. Remove the text on the Weight and keep Sam logo
4. Vendors Invitation
Colorways
Coating options: 8 colors
Anodized options: 7 colors
Please fill in the IC form and cast your vote!
Keyboard Features:
Material: Aluminum, anodized or coating for the surface treatment
S65/80 V2 Typing angle: 7 degrees
Top Mount
S65 V2 Weight: Built 2.5 kg
S80 V2 Kit Weight: Built 2.8 kg
S65 V2 Size: 390×125×20 mm
S80 V2 Size: 392x150*20mm
PCB: soldered or Hotswap, wired, Remap key with online web page
3.5-inch IPS Screen
3.5-inch screen with a resolution of 480×320. The screen can work with hwinfo64 using their data engine. There is a matching plug-in, which will automatically load when booting.
Functions:
Monitoring function: CPU, RAM, hard disk, GPU temp, network information such as usage rate, fan speed, etc.
Basic information display: computer model, location, date, time and other basic information
Other information display: weather forecast, host volume, custom display
Wallpaper mode: choose a 480×320 photo as the wallpaper, which can be displayed alone or superimposed for information display
Custom theme: preset theme, and theme editing function
This is not a second display, so it cannot support GIFs or an extended desktop, it is intended as an information or aesthetic addition
PCB & Layouts
Solder PCB flex cut, or without
Hotswap flex cut, or without
Split TBD
Groupbuy info:
The groupbuy will be run through our website and Vendors to be updated, if you would like to be a vendor, please PM me via Discord.
This round no limited MOQ, and this is the last round in 2023. Don’t miss the chance.
S65 V2 Price: About 300 USD
S80 V2 Price: About 320 USD
GB Date: April Middle
For more details please join our Discord server.
Thanks for your support! I hope you love this board as much as we do!
S65 V2 GB page
Hi Everyone,
Thank you for everyone’s support. We have sorted all information from the IC form. Please check the final updates below.
Update
3.5-inch IPS Screen
More Screen Using Examples
320x480 resolution
Modify the theme, UI, background picture, and more, or make a theme to match your keycaps and desk setup.
Colorways
The votes of Storm Grey and Maraner Grey colors are very close with the most votes.
We have also added army green. You can still fill in the IC form and cast your vote for the next round!
Final Colors:
Storm Grey (Sparkle)
Maraner Grey
Army Green
E-white
Black
Silver
Group Buy Information:
GB Price: $289
GB Time: December 12th, Beijing time 10PM - December 25th
Quantity Limit: 100 Units
S65 V2 product page
Shipping Time: Q1 2023
Hi Everyone,
Since we launched the S80 V2 a few months ago, many customers have asked us to prepare R2. But considering the shipping weight for the S80, we decided to do a 60% version! Now S65 V2 is coming. The first batch is only 100 units, CNC manufacturing is already underway.
3.5-inch IPS Screen
  • 320x480 resolution
  • You can modify the theme, UI, and background picture, or make a theme to match your keycaps and desk setup.
Colorways
At the moment we have confirmed E-white, Black and Silver, but we also want to choose two coated colors for the case.
PCB & Layouts
  • Soldered only
  • Winkeyless or Winkey
  • ANSI and ISO Support
  • Split Right Shift Support
  • Stepped Caps Support
  • 6.25u & 7u bottom row options
Specifications:
- Typing angle: 7 degrees
- 20mm front height
- PVD Silver Alu external weight
- Top mount
- Aluminum case
- PCB: soldered, wired, Remap key with online web page
- POM plate
- Size: 390×125×20 mm
- Kit Weight: Built 2.5 kg
GB Price: Under $300
GB Time: Middle of December for the first batch
If you have any questions, feel free to join our Discord server. Thank you.
« Last Edit: Sun, 07 May 2023, 10:57:34 by Lukenan »
Offline TyPo.mk
Re: [IC]S65 V2 Keyboard with 3.5-inch IPS Screen
« Reply #1 on: Sat, 03 December 2022, 10:01:52 »
 Neat
Offline Necrolegion
« Reply #2 on: Sat, 03 December 2022, 21:49:23 »
Please add a southpaw version.
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #3 on: Sun, 04 December 2022, 00:09:01 »
Echoing this, southpaw would seem to be the better setup for this to me.
Offline Lukenan
    • Sam Website
« Reply #4 on: Sun, 04 December 2022, 08:19:58 »
let me check if we have a chance for the next round. Thank you.
Offline tulaine
« Reply #5 on: Mon, 05 December 2022, 13:43:50 »
Pretty neat, not a fan of the engraving though.
Offline murasaki
  • Formerly 'jota'
    • Mollecue Design
« Reply #6 on: Wed, 07 December 2022, 22:35:26 »
This is pretty cool especially for under $300!
Not a big fan of the engraving though...
Offline Lukenan
    • Sam Website
« Reply #7 on: Fri, 09 December 2022, 09:03:33 »
Thank you. I will forward it to SAM.
Offline epicdesk.shop
Re: [IC]S65 V2 Keyboard with 3.5-inch IPS Screen +Color, and GB Time Updated
« Reply #8 on: Sat, 10 December 2022, 21:12:25 »
Southpaw would rock here!
Offline treeleaf64
    • treeleaf64
« Reply #9 on: Sun, 11 December 2022, 12:57:34 »
What does the plate and Pcb look like, I like this layout but i'm not sure about flex cuts if there are any
Everyone must pay the cat tax
Offline Lukenan
    • Sam Website
« Reply #10 on: Wed, 14 December 2022, 08:00:03 »
PCB no flex cut, but POM plate come with some flex cut
« Last Edit: Wed, 14 December 2022, 08:03:09 by Lukenan »
Offline Lukenan
    • Sam Website
Re: [IC]S65/80 V2 Keyboard with 3.5-inch IPS Screen R2 Coming Now
« Reply #11 on: Mon, 03 April 2023, 10:15:38 »
S65/80 V2 Keyboard with 3.5-inch IPS Screen R2 Coming Now, let me know if you still have any ideas. Thank you.
Offline LosTaquitos
  • Professional Procrastinator
    • Keebs.gg Profile
« Reply #12 on: Mon, 03 April 2023, 13:50:51 »
Definitely interested in this, I'd love to ditch the mini display I'm currently using for PC telemetry. GLWIC!
Ryzen 5800X3D | RTX 3070 Noctua OC | LANCOOL II Mesh
Mode Sonnet | Jwick Semi-Silent | GMK Civilizations
Pulsar Xlite V2 Wireless | Gamebitions Orbit
Offline Lukenan
    • Sam Website
« Reply #13 on: Mon, 03 April 2023, 19:59:08 »
Thank you. Please feel free to fill in our IC form
Offline Lukenan
    • Sam Website
GB Time and Vendor list updated.  ;)
