Author Topic: [IC] Alas 60% Gummy o ring mounting  (Read 24854 times)
Offline RMEStudio
« on: Thu, 01 December 2022, 20:58:35 »
Alas
Gummy o ring friction fit mounting style
Hi, this is an interest check for my new project, Alas is a 60% keyboard with a gummy o ring friction fit mount. I design the board to look simple but I add some subtle curve in the bottom to help user to pick up and move the board easily.
The top side bezel of the keyboard both left and right will have a curve as well to make the side profile looks simple but sleek.
This board will have internal and external weight made of brass to give heft to it, the weight will sandwich the thin layer of aluminum in the middle to absorb the vibration and reverberation and eliminate unwanted hollowness.
since we make the tolerance tighter than normal friction fit board, we design the plate with cutout on the top and bottom to make the typing feel still bouncy and soft without any compromise from the tighter tolerance.
293816-0
IC FORM
Details
Aluminium 6063 for main body
sandblasted brass for internal and external weight
7 Degree typing angle
Friction fit mounting style
20mm front height
3.28 KG fully build
PCB by Yiancar
Also compatible with Hiney H60 jst
100 Units
Exploded View
293818-1
Layout
293820-2
Plate
293822-3
Prototype Photos
by Wigol
293824-4
293826-5
293828-6
by Snayee
293830-7
293832-8
Pricing
$390
GB May 5th, 2023
Vendor
Mekibo (FCFS) 12:00pm PST, May 5th, 2023
Acid&co (raffle) 8:00am WIB May 6th, 2023
Streamers
Lightning Keyboards
Lulzthax April 25, 2023
Alexotos April 19, 2023 7pm ET
Social
« Last Edit: Fri, 05 May 2023, 01:52:28 by RMEStudio »
Offline wigol2506
    • Instagram
Re: [IC] Alas 60% Gummy o ring mounting
« Reply #1 on: Thu, 01 December 2022, 21:04:42 »
All the best for your interest check!
Let’s go!!
https://www.flickr.com/photos/wigol2506/
Singa Ocelot R1 Prototype | Singa x TGR Unikorn R1 Prototype | Singa x TGR Unikorn R2.1 PC & FG | Singa Kyohaku | TGR Jane V2 CE | TGR Police | TGR 910 OG (01/23) |TGR 910RE PC | LZ Phase | LZ XE | LZ erGhost | LZ erGhost CL | LZ REs | LZ Trik X_T | LZ SQ | LZ GHv1 | LZ GHv2 |LZ Prism | Palmetto60 | HBCP | Ibis | No2Rev2 TKL Black Unfinished | 1/60 Rev. 1 | Keynergy Serratus Chrome | DNworks SBL (DN)
Offline ankit
  • Formerly ankit-sachdeva
« Reply #2 on: Thu, 01 December 2022, 21:14:50 »
3.28 KG fully build
 :cool:
Any photos of the internals?
Offline B_D
    • bdskeyboards
« Reply #3 on: Thu, 01 December 2022, 21:37:16 »
looks really good!
height=120]https://imgur.com/rPWNMJz.png[/img][/url]
Offline alas
« Reply #4 on: Thu, 01 December 2022, 21:49:18 »
owo what's this
Offline RMEStudio
« Reply #5 on: Thu, 01 December 2022, 22:21:24 »
3.28 KG fully build
 :cool:
I will add them when I have the photo
Offline RMEStudio
« Reply #6 on: Thu, 01 December 2022, 22:25:39 »
Offline RMEStudio
« Reply #7 on: Thu, 01 December 2022, 22:28:11 »
Let’s go!!
Thank you for letting me borrow the photos for the IC
Offline RMEStudio
« Reply #8 on: Fri, 02 December 2022, 22:46:48 »
IC form Added
Offline Toptiginn
    • toptiginn.com
« Reply #9 on: Tue, 17 January 2023, 06:06:29 »
wow!! Looks awesome :eek:
Offline Toptiginn
    • toptiginn.com
« Reply #10 on: Wed, 18 January 2023, 03:45:25 »
filled out the IC
Offline terryzhouke
« Reply #11 on: Wed, 15 February 2023, 21:42:55 »
HHKB please
通过我的 SM-N9600 上的 Tapatalk发言
Offline catamscott
« Reply #12 on: Thu, 16 February 2023, 16:33:19 »
looks really nice, internal pics would be appreciated as well. only thing that gives me pause is that the plate cuts would make me a little nervous to use a plastic plate (assuming plate file was released, but even then it wouldn't be hard to measure and recreate), particularly a brittle material like acrylic. but otherwise this looks very solid :thumb:
Offline RMEStudio
« Reply #13 on: Fri, 17 February 2023, 04:28:46 »
I will make the plate file without the cut for more flexible plate material
for the internal picture I will take the proper photo then I will update it here
Offline RMEStudio
« Reply #14 on: Fri, 17 February 2023, 04:44:22 »
HHKB please
Sorry no hhkb for now, it will require different pcb and plate for hhkb layout
Offline catamscott
« Reply #15 on: Fri, 17 February 2023, 13:36:02 »
ahh i thought those cuts were necessary for the tighter tolerances, but if it works without them then that's awesome  :thumb:
Offline RMEStudio
« Reply #16 on: Tue, 11 April 2023, 10:00:48 »
Pricing and stream schedule updated
Offline involuntarysoul
« Reply #17 on: Tue, 11 April 2023, 23:05:25 »
front height is alittle tall, the USB port could be even lower, price is little close to Unikorn which is a much better buy atm
Offline tactilesbad
« Reply #18 on: Wed, 12 April 2023, 04:30:15 »
unikorn is raffle based with an immense influx of entries each drop, hard to just "buy" it, especially considering R2.2 ended a few weeks ago and there won't be more for a while...
price is more than ok for a keyboard of this type and heft, imo. any plans for the sales format? hope it's not raffle
Offline RMEStudio
« Reply #19 on: Wed, 12 April 2023, 05:56:14 »
We are still discussing the sales format, I will update the info when we reached the final decision
Offline RMEStudio
« Reply #20 on: Mon, 17 April 2023, 01:15:51 »
Stream Schedule Updated
Offline anjing
« Reply #21 on: Wed, 19 April 2023, 19:50:12 »
Hello, I am a little bit concerned about the Javanese script. I think instead of for the sound a, it should be . Because the word alas has thew vowel a as the initial letter, and on its own syllable.
With my limited knowledge of the script (I only learned it in school), I'm not sure if what I just said is correct or not, you could probably check from multiple sources.
I know it's a nitpick, but I imagine when using the board, it's like having a tattoo with foreign script on your wrist, but not sure on the meaning.
Thanks
Offline RMEStudio
« Reply #22 on: Wed, 19 April 2023, 21:47:34 »
Thanks
Hi, I understand your concern of the chosen character cos someone also ask me about this, but I consult with the Javanese Language expert and actually this character is the one offered by him.
Offline RMEStudio
« Reply #23 on: Fri, 05 May 2023, 01:55:28 »
Sales date and time updated
May 5th,2023 12:00pm PST on Mekibo
May 6th, 2023 08:00am WIB (gmt +7) on Acid&Co
« Last Edit: Fri, 05 May 2023, 02:00:20 by RMEStudio »
