Author Topic: [IC]DCD PBT Bird Jungle - Pre Order is LIVE!  (Read 71254 times)
Offline arq1999
Re: [IC]Bird Jungle - Update 08/30/23 - Full Sample Arrived
« Reply #50 on: Wed, 30 August 2023, 20:11:30 »
update!
Offline arq1999
Re: [IC]DCD PBT Bird Jungle - Pre Order starts 11/16/23 in DROP!
« Reply #51 on: Sat, 11 November 2023, 08:58:45 »
Hello everyone!
DCD Bird Jungle preorder starts this 16th!
I have updated the final kitting changes. Once I get the prices Ill be posting them as well. Thank you for the support!
Offline ggggggg
  • schmeiß die forties durch den club
Re: [IC]DCD PBT Bird Jungle - Pre Order Starts Nov 16th in DROP!
« Reply #52 on: Sat, 11 November 2023, 15:23:44 »
Hope it's not too late, but you're missing an r2 1.75u novelty backspace (backbird?) in your bird mod kit.
Good luck with the run!
Offline arq1999
« Reply #53 on: Sat, 11 November 2023, 16:15:59 »
oh man! You are correct and its the same for the accents. Ill ask, but its very unlikly to get added. My bad I totally missed.
