Author Topic: [IC]Keyno Y·8 ends in 10 hours-uniquely designed 80%,Heat coloring,brass weight  (Read 15644 times)
Offline Ckeeb
  • Meet ZOOM64 Keyboard!
    • MELETRIX
    Hi Everyone!
    The GB is reaching to the end, and we will start preparing the production as soon as GB orders confirmed. If you are interested in the set, please do not miss the chance :)
    Keyno Y·8 Gallery
    Heat coloring version
    CNC raw version
    Standard version
    Keyno Y·8 New Photos and Showcase Video
    * Keyno Y·8 Detail Photos
    * Showcase video
    Keyno Y·8 GB Price
    * Heat coloring version: 399 USD
    * CNC raw version: 349 USD
    * Standard version: 349 USD
    Keyno Y·8 Streamers Schedule
    * Alexotos, Heat coloring version-Silver color
    * Apiary,Standard version-Green color
    * Xinxinwong, Standard version-Purple color
    * Clackbait, Standard version- cream color
    * CG, Standard version- black color & CNC raw version
    * :3ildcat
    The Design Language
    This time, the pursuit of balance is the theme of Y·8 -- Keyno
    • Balance of appearance design
    • Balance of structural design
    Appearance design
    The design of Y·8 is restrained and minimal. There is no pattern, no text, no lights, only the use of geometric elements, such as bars, squares, triangles, and trapezoids.
    In order to achieve the unity of the overall design language, we added "no printing" bar-shaped design elements in all dimensions of the keyboard, so that the Y·8 will not appear excessively redundant while maintaining a refreshing design sense. By adjusting the proportion of the frame to achieve a visual balance, adding a badge accent under the function keys, so that the entire front design will not be so monotonous.
    The position of the top and bottom case is equally divided in the middle, and the linear exposed design of the middle case improves the layering of the side and back of the keyboard. The back uses triangles and trapezoids as the main elements, making the Y·8 shape consistency to a higher level.
    Structural Design
    The new hassle-free Screwless Design
    Screwless design is definitely the one makes the overall design clean. But it’s more easier to have screw and plate/switches interference problem. Y·8 has made the screw sinking lower to avoid such situations, and adjusted the ratio so that the screw hardly falls directly into the case.
    Hassle-free Sinking Screw Design
    Internal "Waffle" Brass Weight
    Due to natural structure of 80% layout, the hollow cavity sound in the area between the arrow keys and the function keys has always been a headache.
    In response to this pain point, the first version of the Y·8 sample adopts a large-area flat brass weight to solve this problem. But it has not reached the point that our team is satisfied with. Finally, we are inspired by the design of concert hall’s echo walls (absorbing sound waves and reducing noisy echoes), we modified the flat brass weight to the current "Waffler" design, through the influence of its structure on the sound, the cavity sound of Y·8 can be hardly noticed.
    Waffle Brass Weight Photo
    1mm PCB, thick black core (no flex cut)
    Improve the keyboard's rebound by applying a 1mm PCB, combined with the PCB's non-flex cut design for a more consistent overall feel.
    1mm Hot-swap PCB
    Layout
    Wired Soldered PCB
    Wired Hotswap PCB
    Standard Colored, Heat Coloring and Raw Aluminium Edition
    Specifications Edition
    * Typing angle: 8 degrees
    * Dimension: 361.70x137.66X18 mm
    * Front Height: 18 mm
    * Weight (unbuilt):
      Y·8 Standard version - 2.3 kg,
     Y·8 Heat coloring version -2.7 kg
    * Case material: 6063 Aluminum
    * Mounting Method: Gasket Mount
    * Support WK/WKL layout
    PCB Specifications
    * Hot-swap PCB: 1 mm, thick black core (no flex cut)
    * QMK/VIA support
    * WK/WKL layout
    * ESD Protection
    Thank you again! and  join the Y·8 discord channel in Wuque Studio’s Discord server for more discussions and updates. Thank you.[/list]
    « Last Edit: Mon, 06 February 2023, 19:44:29 by Ckeeb »
    Offline Nonnegaard
    definitely interesting. the heat colored version is definitely something
    Aeon, TGR Jane V2, Dolphin 2021, Gherkin, Model M, 5°, NCR80, M0110-A
    Offline AnonyMoose_
    how is the 1mm pcb's compatibility with 1.2mm? will shims be needed or is it close enough?
    Offline Helicopter7
    I imagine washers will be enough for 1.2 on 1mm
    Offline twitchytheinsideman
    • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
      • Twitchy Homepage
    Which front height?
    Nice colors. And F13 supremacy  :thumb:
    I wanna see pictures of the PCB.
    Offline EdgeOfInfinity
    interested to see how that 1mm pcb will fair, i'll check out Alex's stream later tonight. although screwless is not my fave i'm glad to see the interference will be addressed.
    waffle weight is pretty dope if it doesn't add a bunch of cost. i like the simple-ish design elements & how it looks kina chonky ;D
    Offline CONIN
    Xinxinwong is building the Purple one, right now: https://www.twitch.tv/xinxinwong
    Offline fzlo
    Hey - any chance to get the accent pieces as addons?
    CNC Raw convinced me to buy the keyno
    Offline Its Salty
    • I have no idea what I'm doing
    so a 1mm PCB, do you plan on including shims as well?
    « Last Edit: Thu, 26 January 2023, 23:57:17 by Its Salty »
    Offline fzlo
    The builds that were seen on YT have shims included in the box
