Author Topic: [GB] S65V2 Keyboard with 3.5 inch IPS Screen R2 IS LIVE  (Read 5994 times)
Offline Lukenan
    • Sam Website
« on: Wed, 14 December 2022, 08:30:00 »
Hi everyone!
We are happy to share that our GB is live now, thanks so much to everyone who supports us at NotfromSAM! We appreciate each and every one of you!!
Groupbuy info:
GB Time: May 1st -May 20th
GB Collection
GB Price:
S65 V2 Solder Edition: $289
Hotswap Edition: $299
S80 V2 Solder Edition: $319
Hotswap Edition: $329
ETA SHIPPING: Q3
9 Final Colorways:
-Storm Blue (Sparkle)
-Black (Sparkle and Anodized)
-Avocado Green
-Burgundy
-Champagne Purple
-Cream
-Maraner Grey
-Silver
Renders for GB Colors: https://imgur.com/a/MMdVQVc
S65 V2 Prototype Gallery: https://imgur.com/a/P9AzKyi
S80 V2 Prototype Gallery: https://imgur.com/a/lwmxlLG
Information/Tech Specs:
-3.5" IPS Screen, programmable to an extent(jpeg/bmp) no GIF
-Non-flex cut Solder and Non-flex cut Hotswap PCB options will be available for purchase.
-Winkeyless or Winkey options
-ANSI and ISO Support available
-Split Right Shift Support
-Stepped Caps Support
-6.25u & 7u bottom row options
-Alu weight(Color: Brass)
-FR4 Plate default
The Default kit will include:
Alu top and bottom case * 1
Soldered or Hotswap PCB * 1
Daughterboard*1
3.5-inch IPS Screen
Aluminum weight (Color: Brass)
Fr4 plate * 1
Poron Foam Kit * 1
Screws and Keyboard Feet
Vendor List
US: Keebsforall
US: Dangkeebs
UK: MechMods UK
Philippines: Zionstudios.ph
Canada: Mech.land
EU: Deltakeyco
AU: Prestige Keys
TH: Gamingplanet
Worldwide: NotfromSam
Reviews/Live streams
Xanniard- Cream
Sviz- Silver Typing Test
Keyboard Features:
Material: Aluminum, anodized or coating for the surface treatment
S65/80 V2 Typing angle: 7 degrees
Top Mount
S65 V2 Weight: Built 2.5 kg
S80 V2 Kit Weight: Built 2.8 kg
S65 V2 Size: 390×125×20 mm
S80 V2 Size: 392x150*20mm
PCB: soldered or Hotswap, wired, Remap key with online web page
3.5-inch IPS Screen
3.5-inch screen with a resolution of 480×320. The screen can work with hwinfo64 using their data engine. There is a matching plug-in, which will automatically load when booting.
Functions:
Monitoring function: CPU, RAM, hard disk, GPU temp, network information such as usage rate, fan speed, etc.
Basic information display: computer model, location, date, time and other basic information
Other information display: weather forecast, host volume, custom display
Wallpaper mode: choose a 480×320 photo as the wallpaper, which can be displayed alone or superimposed for information display
Custom theme: preset theme, and theme editing function
This is not a second display, so it cannot support GIFs or an extended desktop, it is intended as an information or aesthetic addition
Wish everyone the best of luck and we thank you again for everything! For more details please join our Discord server. Thank you.
Hi Everyone,
S65 V2 GB is live. Please check the GB page below. Thank you.
S65 V2 product page
Group Buy Information:
GB Price: $289
GB Time: December 12th - December 25th
Quantity: 100 for all colors
Shipping Time: Q1 2023
3.5-inch IPS Screen
More Screen Using Examples
320x480 resolution
Modify the theme, UI, background picture, and more, or make a theme to match your keycaps and desk setup.
Colorways
  • Storm Grey (Sparkle)
  • Maraner Grey
  • Army Green
  • E-white
  • Black
  • Silver
You can still fill in the IC form and cast your vote! You can still fill in the IC form and cast your vote!
S65 V2 Color Chips: https://imgur.com/a/3G6UIUB
PCB & Layouts
-Soldered only
Specifications:
20mm front height
PVD Silver Alu external weight
Top mount
Aluminum case
PCB: soldered, wired, Remap key with online web page, no flex cut
POM plate
Kit Weight: Built 2.5 kg
-Alu top and bottom case * 1
-Soldered PCB *1
-Alu weight*1
-POM plate*1
-Poron Foam *1
-Carrying case*1
If you have any questions, feel free to join our Discord server. Thank you.
« Last Edit: Sun, 07 May 2023, 11:10:25 by Lukenan »
Re: [GB] S65 V2 Keyboard with 3.5 inch IPS Screen
« Reply #1 on: Wed, 14 December 2022, 15:32:20 »
Approved :thumb:
Offline Lukenan
    • Sam Website
« Reply #2 on: Thu, 15 December 2022, 10:14:20 »
Offline CaesarAZealad
  • Racc
« Reply #3 on: Thu, 15 December 2022, 16:58:00 »
Oh I am totally going to use this for degenerate purposes, hehehehehe
One, Two, Three, Four, Five, Six, Seven, Eight, Nine, Ten, Eleven, Twelve, Thirteen, Fourteen, Fifteen, Sixteen, Seventeen, Eighteen, Nineteen, Twenty... Yeah that seems about right.
"Ask your mother how good I can use more than two fingers." - Caesar, 2023
Offline hzh0525
What a cool keyboard design with a real big screen for customizing~~
Offline Lukenan
    • Sam Website
Thank you. R2 is coming now!  :thumb:
