Author Topic: caps lock led support to a non led pcb QMK  (Read 7597 times)
Offline rjohn
« on: Sat, 17 December 2022, 09:11:18 »
Hello
i totaly new in pcb moding and i have a question ,if its possible to manual add a caps lock led (custom wiring)  and be able to make it work if you program it with QMK.
i am talking about the Plain60-C rev2 pcb.
https://anykeys.eu/product/plain60-c-rev2/
Re: caps lock led support to a non led pcb QMK
« Reply #1 on: Sat, 17 December 2022, 12:20:12 »
I've just had a look in the firmware and at the PCB and it's almost like they want you to add an LED because pin B0 is not used but looks to be connected to a hole just below the controller chip, alongside 5v and ground connections.
Go for it :)
Offline rjohn
« Reply #2 on: Sat, 17 December 2022, 12:31:16 »
thank you very much .i totally new to this kind of firmware mods,so wanted to be sure before i get the pcb in my hands.it will be my first firmware mod.
« Last Edit: Sat, 17 December 2022, 12:41:25 by rjohn »
« Reply #3 on: Sun, 18 December 2022, 05:12:05 »
It's a good first mod and you're not going to break anything - if the firmware doesn't work you just change it and try again.  I'm interested to see how/where you mount it so please post some pics when you're done :)
Offline rjohn
« Reply #4 on: Sun, 18 December 2022, 10:19:19 »
thanks i dont have yet the pcb on my hands ,but when i do the mod i will post some pics .
