Author Topic: TypeHall - Keyboard GB calendar app for Android  (Read 14595 times)
Offline rfbabeheer
« on: Fri, 23 December 2022, 13:17:45 »
Hi guys!
I recently published an app on Google Play called TypeHall which can be used to track current keyboard group buy and interest check.
You can get the app https://play.google.com/store/apps/details?id=com.rivafarabi.typehall
Current available features:
  • Product listing by types (Keycap, Keyboard, Deskmat, Others)
  • Product listing by status (Group Buy, Incoming, Interest Check, Closed)
  • Display item's group buy schedule, vendors, variants or kits (for keycap kits)
  • Save item to Watchlist (login required)
Considered future features:
  • iOS port
  • Google Sign-In integration
  • Push Notification to notify user the new live item and almost over GB item
  • Probably REST API for everyone to use
If you want to list keyboard related item on the app, just put a post at https://discord.gg/HWknw2VE
Any feedback is welcome!
Thank you!
Offline rfbabeheer
Re: TypeHall - Keyboard GB calendar app for Android
« Reply #1 on: Fri, 23 December 2022, 13:20:48 »
The preview of the app
