Author Topic: [IC] KKB Moon Rabbit (GB Feb. 1st - Feb. 29th) | aumipon artisan leak!  (Read 68757 times)
Offline trung11.kb
  • Formerly tomkatsuuu
Re: [IC] KKB Moon Rabbit (GB Feb. 1st - Feb. 29th)
« Reply #50 on: Tue, 23 January 2024, 19:44:49 »
Any possibility of a Mac kit? ^ (alt for Control), Opt/Option, Cloverleaf/Command, F13 (alt for Print), Help (alt for Ins)?
Unfortunately not, sorry :(
The caps look right but the sizing labels on your 40s support is wrong. It should be 1u r2 esc, 1.75u r2 backspace, 1.25u r3 tab and 1.5u r3 enter.
A 1.75u r4 shift is also needed for pretty much all 40s, this is essential. Again you seem to have one in base but its labelled as 2u.
If you wanted to add more comprehensive 40s support then a 1.75u r3 enter and two 3u space bars would be nice.
Thanks for catching that! Updated renders.
Also, we're about a week away from the groupbuy! Wanted to drop that we have the follow collab artisans:
aumipon
GEEKKEEY
Namong Art
okeydokey
Sandun Art
Shirouu
« Last Edit: Wed, 24 January 2024, 15:05:02 by trung11.kb »
Offline trung11.kb
« Reply #51 on: Wed, 31 January 2024, 08:45:31 »
Offline trung11.kb
