Author Topic: Overclocking  (Read 32595 times)
Offline Brodie337
Overclocking
« Reply #50 on: Fri, 08 October 2010, 06:23:03 »
Pah! Air cooling!
H50 for the win!
Offline zefrer
Overclocking
« Reply #51 on: Fri, 08 October 2010, 07:07:31 »
Pah! Off the shelf liquid coolers. Custom loop! :D
Offline timw4mail
    • https://timshomepage.net
Overclocking
« Reply #52 on: Fri, 08 October 2010, 09:29:27 »
If your heatsink doesn't have heatpipes, it's not acceptable for overclocking.
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
Offline itlnstln
Overclocking
« Reply #53 on: Fri, 08 October 2010, 09:44:34 »
Quote from: ripster;231331
Plus you can't smoke it.
Damn, I nearly hosed my HHKB with Diet Dr. Pepper.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
Overclocking
« Reply #54 on: Sat, 09 October 2010, 17:38:40 »
Those losers on OCN weren't helpful at all when I asked them how to overclock my Gateway2000.
Offline Konrad
Overclocking
« Reply #55 on: Sat, 09 October 2010, 21:51:44 »
Well, if you don't like overclock.net there are a lot of alternative forums,
(overclockers.com, overclockersclub.com, extremeoverclocking.com, extremesystems.org, [h]ardforum.com, anandtech.com, blazingpc.com, devhardware.com, many others) ... I just have no clue which is the "best" or is "best" in any given area, lol
Offline chimera15
Overclocking
« Reply #56 on: Sun, 10 October 2010, 07:28:54 »
Quote from: ripster;231927
Hah, even I know that one.  You feed the hamsters steroids and the wheel goes faster.
What's the deal with that wheel? They have an rpm meter on it? lol  Is it motorized or something?
Alps boards:
white real complicated: 1x modified siiig minitouch kb1903,  hhkb light2 english steampunk hack, wireless siig minitouch hack
white with rubber damper(cream)+clicky springs: 2x modified siig minitouch kb1903 1x modified siig minitouch kb1948
white fake simplified:   1x white smk-85, 1x Steampunk compact board hack
white real simplified: 1x unitek k-258
low profile: 1x mint m1242 in box
black: ultra mini wrist keyboard hack
blue: Japanese hhk2 lite hack, 1x siig minitouch pcb/doubleshot dc-2014 caps. kb1903, 1x modified kb1948 Siig minitouch
rainbow test boards:  mck-84sx
Offline HaaTa
  • Master Kiibohd Hunter
  • Kiibohds!
    • http://kiibohd.com
Overclocking
« Reply #57 on: Sun, 10 October 2010, 09:22:26 »
Quote from: chimera15;232094
Definitely motorized, or at least not hamster propelled, as the RPM don't go down at all when the hamster flies off, sorta increase actually...
Kiibohd
ALWAYS looking for cool and interesting switches
I take requests for making keyboard converters (i.e. *old keyboard* to USB).
Offline Konrad
Overclocking
« Reply #58 on: Sun, 10 October 2010, 15:32:17 »
Overclocking your hamsters is one approach.
Just using better hardware to start with will give better results.
Offline D-EJ915
Overclocking
« Reply #59 on: Sun, 10 October 2010, 16:01:56 »
Here's my Core 2 Quad I just tried overclocking...pretty good result imo...800MHz memory too.
http://browse.geekbench.ca/geekbench2/view/299161
I need to put less CPU grease on lol
« Last Edit: Sun, 10 October 2010, 23:47:17 by D-EJ915 »
Offline Konrad
Overclocking
« Reply #60 on: Sun, 10 October 2010, 16:16:42 »
That's +65% overclock on a 2.13GHz (133MHzx16) part?
Yeah, those CPU temps do look high. I hope that's not just idling on the desktop. (If it is, then I would personally scale back or get a serious cooling upgrade.  Your Vcore looks good to me, but I'm no expert.)
[Edit]
I have the same Seagate HDD ;)
« Last Edit: Sun, 10 October 2010, 17:56:53 by Konrad »
Offline D-EJ915
Overclocking
« Reply #61 on: Sun, 10 October 2010, 23:29:08 »
I'm thinking the high temp is just from my room being hot as **** , when I opened the door they dropped 4 degrees almost immediately lol.  The temp was basically the same when at stock speed too so I dunno.  I ordered some AS5 to put on so I'll see if that helps, if not I'm gonna send back this ****in tuniq cooler, it's such a pain in the ass to install who knows if it's on right.
http://valid.canardpc.com/show_oc.php?id=1427877
« Last Edit: Sun, 10 October 2010, 23:48:33 by D-EJ915 »
Offline zefrer
Overclocking
« Reply #62 on: Mon, 11 October 2010, 06:56:56 »
Quote from: Konrad;232218
[Edit]
Different guy, stock clock is 2.5Ghz on his (1Ghz overclock)
Offline zefrer
Overclocking
« Reply #63 on: Mon, 11 October 2010, 08:29:54 »
Quote from: D-EJ915;232376
Have you ran prime95/super pi etc to test stability? I very much doubt it's stable if it idles at 60C..
Offline Konrad
Overclocking
« Reply #64 on: Mon, 11 October 2010, 17:08:11 »
lol, it's only ~50C (48C-54C), not 60C.  Plus it apparently drops by ~4C when the ambient is cooled down (ie, door to the room is opened).
But that's still pretty high.  Especially if that's on idle ... run a test (super pi) to see what happens under stress load.  It's not a useful OC if it's unstable (crashes whenever you actually play games or do anything).  But hey, it's your money, go ahead and cook your CPU, it'll give you an excuse to upgrade in a few months.
AS5 is a low performer these days.  For the same money you could get Indigo Xtreme or Shin-Etsu, which both perform much better.
Offline Rajagra
Overclocking
« Reply #65 on: Mon, 11 October 2010, 17:51:41 »
Quote from: Konrad;232635
If someone sees big performance differences between pastes, I suspect they are applying them badly. Hell, you can get good results without paste provided the surfaces are properly flat and clean. Paste can do no more than fill the air gaps so there is an absolute limit to how much good they can do. There isn't a limit to how much harm they can do - put in too much and you just create an insulating layer.
My overclock seems perfectly stable - except the system can no longer come out of standby. Very odd!
Offline zefrer
Overclocking
« Reply #66 on: Mon, 11 October 2010, 18:07:39 »
Quote from: Rajagra;232648
Well yeah the difference is not huge but there is one. There is actually at least a 4C difference (hardocp.com) from the average to one of the best, in overclocked conditions.
And no you can't go without. That's like going without a condom.
Offline Konrad
Overclocking
« Reply #67 on: Mon, 11 October 2010, 18:47:37 »
A lot of research and big money goes into engineering better TIMs.
True, for consumer PCs the differences aren't that great, although they have slightly greater significance when pushing hot overclocks.
Cheap TIM pastes aren't very efficient. Save money and get poor results.
Pay a little more for better ("premium" or silver-bearing) TIMs like AS5 to get good results, though there's no need to buy into the expensive boutique brands.
Expensive performance TIMs are better still, though you'll see ever-diminishing gains.
It's about bang for the buck, right? The best TIM in the world won't give any real advantage over a cheap one if it's efficienctly conducting heat to a heatsink that's too small for the job. Still, if you're already going to pay for AS5 then why not pay the same for Indigo X?
http://skinneelabs.com/tim2010part1.html?page=1
Offline Rajagra
Overclocking
« Reply #68 on: Mon, 11 October 2010, 21:42:55 »
Interesting link. Last time I built a system TIM pads were mostly useless. I see he didn't lap the CPU. I won't criticise that, as I've never gone that far. But I wonder what results you'd get by lapping the CPU and heatsink really well, maybe using DMT diamond plates, or even Shapton stones. They are very, very flat (sandpaper on glass just can't compare) and go to insanely fine levels of abrasive, e.g. 1/2 micron. You wouldn't buy these just to lap one install, but someone who was building performance systems regularly just might get some.
The finest diamond plate I have is 3 micron/8000 grit. I may have to play with an old system. :madgrin:
« Last Edit: Mon, 11 October 2010, 21:50:16 by Rajagra »
Offline D-EJ915
Overclocking
« Reply #69 on: Mon, 11 October 2010, 22:29:42 »
FWIW it went up to around 60-4 C if I remember when doing hyperpi or whichever is the newest on all 4 cores, I don't really remember lol.
Offline Konrad
Overclocking
« Reply #70 on: Tue, 12 October 2010, 02:12:47 »
Haha, I've polished my HS and IHS to mirror shine, then applied IndigoX with a razor blade.  I seriously nerded out on it here a few months back.
And I'm a noob compared to some of those guys.  They remove the IHS entirely (with a blowtorch, lol the only way) for direct-die liquid cooling.
Offline Rajagra
Overclocking
« Reply #71 on: Tue, 12 October 2010, 03:59:54 »
Funny you got info from a laser forum, it reminds me of this article that gives a convincing argument against over-polishing the surfaces.
if we made the mating surface of the aluminum block too smooth, we lost cooling efficiency – similarly if it was too coarse. To the extent that if we polished the surface, we got significantly worse performance than when the heatsink surface was matte after lapping with, say, 400-600 grade carborundum.
It's a good reminder that sometimes what seems obviously true ... is not.
