Author Topic: [GB] SP-111 Round 2 : Return of the King (of splits) - Ready to ship to vendors  (Read 106857 times)
Offline BlindAssassin111
  • I design keyboards and stuff.
    • Viktus
SP-111
Round 2
Whats new?
The wait is finally over for the return of the king of splits! Over the past few years I have spent time modifying the design, and modifying those design changes again and again until I finally got to the point I was happy. The new changes include:
  • Shorter board height.
  • Different feet that also reduce height even further.
  • Added a screw for the bezel below the F-row to help keep bowed plate/PCB assemblies sitting flat/flush.
  • Small updates all over the board (like radii, thickness and spacing) to improve upon the round 1 board.
  • MCU's on both left and right PCBs.
  • RGB Indicators with polycarbonate light pipe.
  • Important note: Plates and PCBs from round 1 WILL NOT work in the round 2 case. Plates from round 2 will work in round 1 cases without issue. PCBs from round 2 have the RGB LED indicators, so they can work in round 1 with custom light pipes or if you don't use the indicator lights at all by disabling in firmware (can use them with the indicators but the light bleed might be an issue you don't want to deal with).
What does the name mean?
The name has a lot of meanings that you may not even realize.
  • SP: Split, Southpaw, Special. 3 meanings tied to the 3 ones in the name.
  • 111: The numbers from my username. Original meaning for the numbers in my username is my b-day, November 1st, so I had to incorporate it somehow.
  • 111: There is a layout that has exactly 111 switches to tie it all together again.
Why is this board laid out like it is?
  • Southpaw to allow you to use the numpad and mouse at the same time (helpful for CAD and other data entry)
  • Split to allow placement in a comfortable manner for long sessions of data entry or work in general.
  • Right side layout to maintain the functionality of a full size in a much more compact manner. Hence the 1800 style arrows and vertical nav.
What mounting style is it?
  • Sandwich mount, with the plate visible around the edges and locating tabs for alignment on top and bottom. (meaning even without screws, the top, plate, and bottom all locate onto each other and help with alignment)
What are the specs?
  • Board has a typing angle of 7 degrees (no tenting ability built into the case)
  • Left side weights 1.27 Kg (2.80 lb) and the right side weights 1.11 Kg (2.45 lb). This is without pcbs, switches or caps, and there are no weights, just case and plate.
  • Board interconnect is Type-C.
  • Board connects to the PC via Type-C as well.
  • RGB LED indicators on the left half.
  • 32u4 MCU on both left and right PCBs, left always being the master side.
  • 1.6mm Solder PCB only (hotswap has interference issues that would prevent the option)
Layouts:
  • Mirrored Numpad 2U, and ISO enter/shift are available on the PCB only.
  • And as a side note, you can mix and match the bottom row options, they don't have to be both the same spacebar size, each side layout is independent of each other and the included plate supports 3U, 2.75U, and 2.25U options on both halves. So if you feel like a 2.25u and 3u you can go for it!
Vendors:
  • US: Space Cables
  • Canada: Ashkeebs
  • OCE: SwitchKeys
  • Europe: mykeyboard.eu
  • UK: proto[Typist]
  • SEA: ilumkb
  • Asia: zFrontier
Timeline:
  • Start: February 3rd @ Noon CST
  • End: March 3rd @ Midnight CST
  • Note: Proxy local times may be different.
  • Shipping estimate of Q3 2023
Pricing:
  • Board: $460
      • MOQ: 100
  • Note: Proxy pricing may vary.
What is included?
  • Board halves
  • Polycarbonate light pipe
  • Black anodized aluminum plates
  • Black PCBs
  • Short type-c to type-c interconnect cable
  • Carrying Case
  • Hardware and feet
Build Stream:
  • Alexotos will be doing a build stream of the lavender prototype on February 3rd.
Prototype:
Renders:
  • Wine:
  • Lavender:
  • Sea Blue:
  • Gray:
  • Feet and side profile
Special Thanks:
  • OneCreativeMind for helping me come up with this board in the beginning and the logo for the board.
  • Marco for the amazing renders.
  • Ragan aka Space Cables for helping prototype and run the buy.
  • keebnewb for making the firmware.
« Last Edit: Sun, 01 October 2023, 13:21:15 by BlindAssassin111 »
Re: [GB] SP-111 Round 2 : Return of the King (of splits) - Feb 3rd
« Reply #1 on: Fri, 20 January 2023, 16:52:11 »
Approved :thumb:
    • Viktus
GB is LIVE:
Vendors:
  • US: Space Cables
  • Canada: Ashkeebs
  • OCE: SwitchKeys
  • UK: proto[Typist]
  • SEA: ilumkb
  • Asia: zFrontier
Offline rjo21
Missed this the first time, just ordered two.  Pumped.
Offline typischt
Is this limited?
Mykeyboard doesn‘t seem to have them online yet.
Gesendet von iPhone mit Tapatalk
    • Viktus
Is this limited?
Not limited, but proxies might have slightly different start times so check back later and hopefully it will be up soonTM.
Offline iamtragic
Hell yeah, in for an extra carrying case + lavender love ya work.
Offline kiwoli
While waiting for the local vendor to go live, one question:
If I'm understanding correctly, this means the supplied plate won't work if I want to use these options on the PCB, if so will a file be provided so I can get it made locally?
    • Viktus
Correct, The included plates do not support that but a file that does will be provided for the alternate layouts.
    • Viktus
MOQ Update:
So far with just 3 of the 7 vendors having reported sales for the start, we already hit 50% of MOQ on just day 2!!!
Checkout your local vendor to join the GB!
Vendors:
  • US: Space Cables
  • Canada: Ashkeebs
  • OCE: SwitchKeys
  • UK: proto[Typist]
  • SEA: ilumkb
  • Asia: zFrontier
« Last Edit: Fri, 24 February 2023, 11:09:27 by BlindAssassin111 »
    • Viktus
Final week:
The board will be made!!!
GB closes March 3rd at midnight so don't miss your chance and order before it closes.
Checkout your local vendor to join the GB.
Vendors:
  • US: Space Cables
  • Canada: Ashkeebs
  • OCE: SwitchKeys
  • UK: proto[Typist]
  • SEA: ilumkb
  • Asia: zFrontier
    • Viktus
Re: [GB] SP-111 Round 2 : Return of the King (of splits) - FINAL DAY
« Reply #11 on: Fri, 03 March 2023, 16:10:51 »
Final day:
GB ends at midnight so don't miss your chance and order before it closes.
Vendors:
  • US: Space Cables
  • Canada: Ashkeebs
  • OCE: SwitchKeys
  • UK: proto[Typist]
  • SEA: ilumkb
  • Asia: zFrontier
Offline IOVERCALLHISTIOCYTES
« Reply #12 on: Fri, 03 March 2023, 19:46:11 »
Thanks for running again with new colors!
Offline Ghostz113
« Reply #13 on: Sun, 05 March 2023, 15:44:47 »
Has the group buy period been extended?
« Reply #14 on: Sun, 05 March 2023, 17:35:15 »
Wouldnt be the first time that a GB didn't close on some date and time because it was over a weekend and the vendor just let it go till they got back to work. Whatever the reason, space cables still seems to be open if you're interested.
Speaking of interest: anyone in the USA like their R1 brass plates and wants to order some with me once we get the R2 file?
Offline somesounds
  • Formerly gills
« Reply #15 on: Mon, 08 May 2023, 20:31:24 »
Do we think they'll be able to match that deep blue color accurately in the anodization? I'd be curious to see color prototypes as they come through. Thanks for running this very kickass board R2 style.
    • Viktus
« Reply #16 on: Mon, 08 May 2023, 21:02:02 »
Renders are based on ano samples, so yes I am confident they will match the colors.
Offline somesounds
  • Formerly gills
« Reply #17 on: Tue, 09 May 2023, 12:45:24 »
stoked :~)
Offline typischt
« Reply #18 on: Sun, 01 October 2023, 03:51:45 »
Are there any updates on this?
    • Viktus
« Reply #19 on: Sun, 01 October 2023, 13:20:49 »
Boards are ready to ship to vendors, but china has a holiday week at the moment so they will be shipping after they get back.
Offline nathanchere
If anyone finds themselves having buyer's remorse on this when it arrives and is open to sell or trade for other boards within EU please let me know. I never ended up getting the Hex6C I ordered which has left a southpaw-sized hole in my heart.
Offline nathanchere
Were there any extras for this? Even if not the case, I'd be happy just to get hold of a PCB and plate.
Space cablesyou can preorder
This hasn’t shipped to individuals yet.
Offline TimeRelapse
Received my unit, hoping to build soon! Will plate files be released for R2 or should I just go off R1 plates from your github repo if I wanted to go about getting my own cut? Have some interesting thoughts about modifying it.
    • Viktus
I already released the R2 files back in March 2023. They can be found here: https://github.com/blindassassin111/SP-111_R2_Plate_Files
Offline nathanchere
.... time for R3 yet? :D
Hey glad it’s not just me. Vendors for this board are like the defense against the dark arts teachers
    • Viktus
At this time I don't think I will do another round anytime soon. I honestly don't know if I want to go through the effort to do this again as R2 was already stressful enough. To do it again I would need to find another vendor to build a relationship with to feel comfortable with another round and I am not sure I am up for that for the foreseeable future.
Offline Nedeam
Still running my SP-111 R2 in purple since day one. Any chance pcbs are still available or files will be made available same as the plates? I think my two sets of PCBs are at the end of their lifespan and I do not dare to desolder them any further.
    • Viktus
I recently did a small PCB GB but all extras were sold. If there is enough interest I can always do that again, but the minimum is 20-25 PCBs due to tariff bs.
Offline Nedeam
Ah sadly I missed that. Where would I be able to follow such news? Is it on discord? I did not find anything in this respect on geekhack.
Blindassassin’s discord had the pcb sale there. Not sure I remember seeing it elsewhere.
