Author Topic: [IC] BB40 & BBPad - Basic 40% and Numpad DIY Kits  (Read 4126 times)
Offline MechWild
« on: Tue, 10 January 2023, 10:52:49 »
Our website
MechWild Discord
Group Buy Dates: February 10th, Noon ET to March 6th, Noon-ish ET
BB40
BBPad
BB40 Prototype
Target Price: 40 USD
Hey, everyone, we’ve got a couple simple DIY kits planned to start off the new year. The BB40 and BBPad work well together and they’re both just as ready to release so we’ll be running these 2 GBs at the same time.
The BB40 is a no-nonsense 40% minimal layout featuring an optional layout to support arrow keys and a position for an encoder in the corner below the top mounted BlackPill. The BB40 is fully compatible with our upcoming wireless BlackPill alternative, the PillBug. Along with all the keys and a knob, the BB40 will also come with indicator LEDs. The BlackPill and LEDs will be protected by the acrylic guard.
Layouts
BB40 IC Form
BB40 Features
  • MX and Choc switch support
  • QMK and ZMK Support
  • Optional encoder
  • Acrylic guard
BB40 Kit Contents
  • PCB, bottom plate, switch plate
  • Assembly hardware
  • Acrylic guard
  • Knob and encoder
  • BlackPill
  • Status LEDs
BBPad Prototype
Target Price: 30 USD
The BBPad is a simple macro/number pad that can be used as a typical number pad or as a wider 5 columns by 4 row macro pad. The BBPad is powered by the BlackPill/PillBug and can make use of the larger processing power and memory to store all kinds of interesting macros and RGB LED options. Speaking of which: The BBPad sports per-key RGB LEDs and several underglow RGB LEDs around the perimeter. With the support of the PillBug, this board can be used with BlueTooth as well. Both MX and Choc switches are supported on the board, with MX spacing for both.
BBPad IC Form
BBPad Features
  • Supports grid and numpad layouts
  • Per-key and underglow RGB
BBPad Kit Contents
  • PCB, bottom plate
  • Assembly hardware
  • Acrylic guard
  • BlackPill
  • RGB LEDs
BBPad IC Form again
BB40 IC Form again
Thank you for checking these out and your continued support. We’ll be providing updates when and where we can.
« Last Edit: Fri, 10 February 2023, 07:52:47 by MechWild »
Offline MechWild
Re: [IC] BB40 & BBPad - Basic 40% and Numpad DIY Kits
« Reply #1 on: Thu, 09 February 2023, 10:51:10 »
Hey everyone, it's not much notice, but we'll be running the GB from February 10th to March 6th, starting and ending at noon ET.
