Author Topic: GMK Modern Dolch 2 Color Codes?  (Read 14431 times)
Offline akoster15
« on: Thu, 23 February 2023, 13:02:19 »
Does anyone happen to know the color codes for GMK Modern Dolch 2?
I have trying to see the color code of the grey spacebar for the base set so I can order a replacement in a spacebar kit of a different set. I have not been able to find them anywhere online.
Offline Fraaaan
Re: GMK Modern Dolch 2 Color Codes?
« Reply #1 on: Sun, 05 March 2023, 04:29:48 »
According to the original GB thread for GMK Modern Dolch, every color in the set is a custom color.
Offline emmafrost1
« Reply #2 on: Mon, 15 May 2023, 06:11:24 »
I have trying to see the color code of the grey spacebar for the base set so I can order a replacement in a spacebar kit of a different set. I have not been able to find them anywhere online. Tutuapp Kodi
The color codes for GMK Modern Dolch 2 keycap set can vary depending on the specific manufacturer and batch.
« Last Edit: Thu, 18 May 2023, 07:48:27 by emmafrost1 »
QWERTY or bust!
